Serviio Online Feeds Questions...
Christopher_Povey
Post Sun Sep 25, 2011 10:50 am
Is there anyway of streaming the HD versions of programmes (or BBC HD channels) via Serviio?
My Sony BDP-S570 has BBC iPlayer integrated and when I selected programme I can then switch it to the HD version if I wish.
In order to watch an online "channel", I assume they have to have a RSS feed to their content? Does 4OD, ITV iPlayer, 5OD have such a feed?
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
Post Sun Sep 25, 2011 11:02 am
Re: Serviio Online Feeds Questions...
Yes you can, just select the required quality in the console.
We will need to write a plugin for those.
Christopher_Povey
Post Sun Sep 25, 2011 2:18 pm
I have set them all to high. The RSS feed does not completely match the built in iPlayer in the Sony BDP-S570. I had to hunt round for a HD programme on both to compare. They seem okay on my Sony. The Panasonic looks a bit fuzzy so it might be transcoding it.
Of those listed the ITV iPlayer would be good as the Sony BDP-S570 does the others.
I assume Sky iPlayer/Go (or what ever it is called this week) is a no go? It is integrated into the XBox 360 though apparently? How though, I do not know... :(
Chris
NX3
Post Tue Sep 27, 2011 4:55 pm
Don't sky use MS and thus MS DRM ?
Post Tue Sep 27, 2011 6:51 pm
NX3 wrote:Don't sky use MS and thus MS DRM ?
nope sky use nagra3
Return to General discussion
