Samsung C/D Series Youtube transcoding
FRisma
Post Tue Sep 27, 2011 1:40 am
Hi everyone,
Im writing because I've installed serviio 0.6 for streaming content to my Samsung 5Series. The problem is that my TV shows me the message "Formato no compatible" (in spanish), in english it would be like "Not compatible file type". I've tried also on another TV, a Phillis one (that hasn't an ethernet interface, but I have a generic media player, and the result is the same. However, when I strem ti my iPod touch 4, Everything works great. I wonder why cant I watch videos in my Samsung or Phillips TV If I had enabled the transcoding. Thank you!! Greetings from Argentina. Franco
FRisma
Post Tue Sep 27, 2011 1:43 am
Re: Samsung C/D Series Youtube transcoding
I have to Advise you that my movies works great on both TVs, the problem of "Filetype Not supported" is when I streaming content from YouTube.
Thank you
luigui
Post Tue Sep 27, 2011 7:54 pm
I have the same problem. I have a TV Samsung 40D8000 and I can't view online video feeds. I try to view for example the top rated videos, I select one of them, and for 5-10 seconds the TV shows "Loading...", and after that "Not Supported File Format".
I think that the error in the log file is at this part:
2011-09-27 21:37:58,841 DEBUG [FeedItemUrlExtractor] YouTubeUrlExctractor: 1317175200
2011-09-27 21:37:58,841 DEBUG [FeedItemUrlExtractor] YouTubeUrlExctractor: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://o-o.preferred.tiws-par1.v1.lscache6.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Calgorithm%2Cburst%2Cfactor%2Ccp&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=4FF5B73EB98950F493925E867BA967B867081620.256F76692020F57F507178BBC4F2D6DCFE113D08&expire=1317175200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTFFSU19FSkNOMF9JTFdDOkh1SWQwM0ZDbHdv&id=fd9e7e3fdbf717cc, thumbnailUrl=http://i4.ytimg.com/vi/_Z5-P9v3F8w/default.jpg, expiresOn=Tue Sep 27 19:00:00 PDT 2011, expiresImmediately=false]
2011-09-27 21:37:58,841 DEBUG [FeedParser] Added feed item 20: 'Justin Bieber - Never Say Never ft. Jaden Smith'
2011-09-27 21:37:58,841 DEBUG [FeedCacheDecorator] Stored entry in the cache (online_feeds), returning it
2011-09-27 21:37:58,841 DEBUG [OnlineLibraryManager] Feed http://gdata.youtube.com/feeds/api/standardfeeds/top_rated will expire in the cache on Wed Sep 28 21:37:58 PDT 2011
2011-09-27 21:37:58,841 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000010002, format AVC_TS_MP_SD_AC3_ISO and profile Samsung TV / player (C/D-series)
2011-09-27 21:37:58,842 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Video http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=908522%2C907605%2C901802&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=A2EEC2BFB3145893A46F04FE0E4A23BDFAE95450.5BEFE2B80BC145CE65499EABADBC49CF2E125A03&expire=1317175200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTFFSU19FSkNOMF9JTFdDOmtlYkI2clpsc0hN&id=8f9fb22a10ddeb8b does not match any supported DLNA profile
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: Video http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=908522%2C907605%2C901802&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=A2EEC2BFB3145893A46F04FE0E4A23BDFAE95450.5BEFE2B80BC145CE65499EABADBC49CF2E125A03&expire=1317175200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTFFSU19FSkNOMF9JTFdDOmtlYkI2clpsc0hN&id=8f9fb22a10ddeb8b does not match any supported DLNA profile
   at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoFormat(MediaFormatProfileResolver.java:106)
   at org.serviio.dlna.MediaFormatProfileResolver.resolve(MediaFormatProfileResolver.java:48)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:71)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:37)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:109)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:152)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:122)
Thanks in advance.
Luis
FRisma
Post Tue Sep 27, 2011 9:13 pm
Dear Friend,
I've solved the issue. Actually it was very silly. I haven't set the correct profile for my Samsung TV, it was in GENERIC DLNA, so for that reason it wasn't transcoding.
Post Tue Sep 27, 2011 10:24 pm
FRisma wrote:Dear Friend,
lol dont worry we have all done that atleast once in our time lol.
luigui
Post Wed Sep 28, 2011 5:27 am
Thanks, but in my case I have the profile "Samsung TV / player (C/D-series)" with no luck...
Any ideas? What's wrong with my configuration?
Thanks!
Post Wed Sep 28, 2011 5:45 am
Thanks!
Remove all renderers from the console and restart serviio completely ( you can even restart pc running serviio to be certain ) now go back and check that your TV has been correctly detected by serviio and the correct profile assigned.
luigui
Post Wed Sep 28, 2011 7:41 pm
Thanks!
I have done those steps, and the TV is detected with device name UE40D8000 but with profile "Generic DLNA profile". I tried youtube videos with no luck. I change the profile to "Samsung TV / player (C/D-series)", restart computer and the same, no youtube videos...
More things to try?
Post Wed Sep 28, 2011 10:48 pm
check you have latest firmware.
moltra: can you confirm youtube links work for u on your D series device?
luigui
Post Thu Sep 29, 2011 7:08 pm
Cerberus wrote:check you have latest firmware.
Yes, I have the latest firmware 1016.3, updated few days ago.
Anybode with Samsung D series can help?
Post Thu Sep 29, 2011 7:13 pm
I will check tonight.
Can you post the exact RSS URL that you are using?
luigui
Post Thu Sep 29, 2011 7:24 pm
Yes, I tried videos of this RSS URL:
Thanks!
Post Thu Sep 29, 2011 10:20 pm
ok tried the feed you posted and on C series it work flawlessly without any issues, i did put the newest youtube plugin into my install though.
viewtopic.php?f=20&t=3276
Users browsing this forum: Baidu [Spider] and 10 guests
