Support for *.m2t files
Parka Boy
Post Wed Sep 28, 2011 6:45 pm
it is possible to add support for *.m2t files, generated by Kaffeine (KDE MediaPlayer) when recording TV shows. In this case it is german HDTV programm streams.
The files are not displayed in the list. The TV is an Panasonic and i use the pana Viera profil. I can play those files by miniDLNA.
This is an header of an typical filel:
ffmpeg version N-32226-ga9c6936, Copyright (c) 2000-2011 the FFmpeg developers
  built on Aug 31 2011 22:24:08 with gcc 4.5.2
  configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-runtime-cpudetect --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-avfilter --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-x11grab --enable-libdc1394 --enable-libdirac --enable-libschroedinger --enable-libopenjpeg --enable-libspeex --enable-avfilter --enable-shared
  libavutil    51. 14. 0 / 51. 14. 0
  libavcodec   53. 12. 0 / 53. 12. 0
  libavformat  53. 10. 0 / 53. 10. 0
  libavdevice  53.  3. 0 / 53.  3. 0
  libavfilter   2. 37. 0 /  2. 37. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Input #0, mpegts, from 'The Killing 7_8.m2t':
  Duration: 02:10:00.26, start: 72468.037444, bitrate: 7330 kb/s
  Program 11120
    Stream #0.0[0x184d](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.1[0x184e](fra): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.2[0x184c](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.3[0x1856](ger): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006) (clean effects)
    Stream #0.4[0x1857](fra): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
    Stream #0.5[0x1842]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 51 fps, 50 tbr, 90k tbn, 100 tbc
Thank You!
Panasonic TX-L37EW30, Arcam solo movie 5.1, Logitech Squeezebox Touch Classic, Ubuntu Server 12.04, Serviio 6.2, Logitech Mediaserver, Huawei MediaPad
Post Wed Sep 28, 2011 9:14 pm
Re: Support for *.m2t files
rename the file to .ts or .mpg
Sebanisu
Post Thu Sep 29, 2011 1:35 pm
You might need to remux those. My blu ray player has issues if the Audio streams are before the Video streams. Good luck :D
Samsung BD-C5500 And XBOX 360| Windows 7)
Post Thu Sep 29, 2011 3:59 pm
Sebanisu wrote:You might need to remux those. My blu ray player has issues if the Audio streams are before the Video streams. Good luck :D
+1 to that
Parka Boy
Post Thu Sep 29, 2011 4:30 pm
Hi zip,
by rename the file into *.ts it works! Thank you!
@ Sebanisu
That is not really a problem, i use ffmpge to cut unneeded parts at the beginning and end and also remove some audio streams by this command (Linux):
ffmpeg -ss 00:00:00 -t 00:00:00 -i ".m2t" -vcodec copy -map 0:0 -acodec copy -map 0:1 ".m2t"
ffmpeg -ss 00:00:30 -t 00:59:00 -i "The Killing 7_8.m2t" -vcodec copy -map 0:5 -acodec copy -map 0:2 "The Killing 7.ts"
  Program 11120
[mpegts @ 0x1592d40] muxrate VBR, pcr every 5 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to 'The Killing 7.ts':
    encoder         : Lavf53.10.0
    Stream #0.0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 90k tbn, 50 tbc
    Stream #0.1(deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, 256 kb/s
Stream mapping:
  Stream #0.5 -> #0.0 (copy)
  Stream #0.2 -> #0.1 (copy)
:mrgreen:
Return to Feature requests
