Sony KDL-40NX711 stutters playing MPEG transport streams
Anybody have any ideas?
AeroSC wrote:I'm having a problem with constant stuttering during playback of recorded HD TV shows encoded as mpeg transport streams. Regular mpeg2 files from standard def shows play fine with no hiccups. I thought I could lower the bitrate settings in the device profile, but it doesn't seem to make a difference. Reading the forum, it seems that parameter is only invoked if the file has to be transcoded.
AeroSC wrote:... I could make a long ethernet cable and wire the Sony in to the wired network and test that to make sire it's not just a bandwidth issue. If it is, I guess all I'm looking for is a way to transcode these files into a lower bitrate suitable for the bandwidth of my network.
AeroSC wrote:I have my HTPC set to hibernate if there is no activity going on. It seems that Serviio (unlike some other applications such as XBMC and BeyondTV) does not prevent hibernation if it is streaming to another device. Can anyone confirm this? If so, what solutions are available?
