Sony W5500 Acpect Ratio problem
squadjot
Post Sun Oct 02, 2011 8:46 pm
Hi
I'm normally using PMS, and just wanted to try serviio (again). It seems some things works a bit better now, especially the ability to fast forward/backwards its superior to PMS.
One thing that would keep me from ever using serviio, is that i need an option to force 16/9 output.
This is needed for movies wider than 16/9 ( The Bravia W5500 (and some others) , seems to lack this functionality and only supports 16:9 - 14:7 - 4:3 )
Post Sun Oct 02, 2011 8:55 pm
Re: Sony W5500 Acpect Ratio problem
please search the forum this has been discussed many times.
Post Mon Oct 03, 2011 4:19 pm
On 2010 Bravia TV, I know there were an aspect ratio issue that PSM solved with extra padding option with mencoder.
I suggest a solution to Zip with ffmpeg viewtopic.php?f=11&t=2956, but its not implemented yet.
I suppose this is the same issue with 2009 models?
