[SOLVED] MKV Movie wont play audio or video
mudplug
Post Sun Oct 02, 2011 6:08 am
Hiya guys and gals
Been using serviio for ages now, this is the first time it would not play a movie for me. My son is driving me crazy he wants to watch it :roll: It tells me unsupported audio and then unsuppoerted video on the TV. I attached the movie info Im using WIN 7 64bit edition. Any help would be appriciated. Thanks in advance
fmpeg -i Transformer.3.Dark.Of.The.Moon.2011.1080p.mkv
ffmpeg version N-33195-gedf1a8e, Copyright (c) 2000-2011 the FFmpeg developers
built on Oct 1 2011 16:32:11 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 18. 0 / 51. 18. 0
libavcodec 53. 19. 0 / 53. 19. 0
libavformat 53. 13. 0 / 53. 13. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 6 / 2. 43. 6
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/1
25) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'Transformer.3.Dark.Of.The.Moon.2011.1080p.mkv':
Duration: 02:34:23.29, start: 0.000000, bitrate: 25652 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32
Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s (default)
Stream #0:3(fre): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s
Stream #0:4(eng): Subtitle: text (default)
Stream #0:5(fre): Subtitle: text
Unique ID : 243546024182385447541217738491110598006 (0xB7394211978815E98A6DE84F9147A576)
Complete name : D:\Transformer.3.Dark.Of.The.Moon.2011.1080p.mkv
Format : Matroska
Format version : Version 2
File size : 27.7 GiB
Duration : 2h 34mn
Overall bit rate : 25.7 Mbps
Encoded date : UTC 2011-09-27 04:21:43
Writing application : mkvmerge v5.0.0 ('Die Wahre Liebe') built on Sep 25 2011 20:33:49
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 34mn
Nominal bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.543
Writing library : x264 core 115 r1947 b5a8ad7
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=20000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 34mn
Bit rate mode : Variable
Maximum bit rate : 6 048 Kbps
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossless
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 34mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 707 MiB (2%)
Language : English
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 34mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Language : French
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Text #2
Format : UTF-8
Language : French
Post Sun Oct 02, 2011 10:34 am
Re: MKV Movie wont play audio or video
find
and add this under it
now restart serviio COMPLETELY or restart pc/server running serviio
mudplug
Post Mon Oct 03, 2011 5:25 am
Thankyou done that,
Now I get "not supported file format" Any ideas thanks.
Post Mon Oct 03, 2011 5:28 am
mudplug wrote:Thankyou done that,
restart serviio completely cause that file should be supported now as we have transcoded it.
mudplug
Post Mon Oct 03, 2011 5:33 am
Thanks I did do a complete shutdown and restart of the computer as recommended from your first post. I will try again thanks for your help.
Grumpa
Post Mon Oct 03, 2011 3:44 pm
My Samsung C series player won't play any files with header stripping. So far the only solution for me has been to remux with mkvmerge v4.0 Later versions all enable header stripping by default and I haven't figured out how to tunr it off yet. :(
Post Mon Oct 03, 2011 4:24 pm
Grumpa wrote:... with mkvmerge v4.0 Later versions all enable header stripping by default and I haven't figured out how to tunr it off yet. :(
viewtopic.php?f=6&t=1132
Post Mon Oct 03, 2011 4:58 pm
Seems to me there are a number of problems:
1. A bit rate of 25Mbps for an AVC video is excessive, and will not play across a network. 6-8Mbps will hold the quality and play across a network.
2. The framerate of 47 does not match the stream. My samsung BR will not play .mkv files > 30fps
3. All the streams are header stripped which creates problems.
Grumpa
Post Mon Oct 03, 2011 6:19 pm
Thanks Illico, setting Compression to "none" under mkvmerge 5.0 solved the header stripping problem and allowed the file to be played. There was another issue which will be another subject.
Post Mon Oct 03, 2011 7:09 pm
jhb50 wrote:Seems to me there are a number of problems:
1. The file is transcoded so thats not an issue.
2/3. Bugger i didnt notice it had header compression my bad :oops:
mudplug
Post Tue Oct 04, 2011 5:10 am
This is great info thanks, so I can remove the header with mkvtoolnix?? What do I do about the framerate??
Post Tue Oct 04, 2011 5:18 am
framerate wont be an issue as we are transcoding the file to make it play anyways.
mudplug
Post Tue Oct 04, 2011 8:33 am
OK got a bit of headway, used mkvmerge to sort out headers and got the movie to play. But Im getting audio codec not supported, Im so close I can smell it :roll: :roll: Any Ideas.
Post Tue Oct 04, 2011 8:52 am
mudplug wrote:OK got a bit of headway, used mkvmerge to sort out headers and got the movie to play. But Im getting audio codec not supported, Im so close I can smell it :roll: :roll: Any Ideas.
Truehd must be transcoded....(see cerberus previous post)
or
re-use mkvmerge and remux the audio tracks to put the ac3-5.1 in first position.
Post Tue Oct 04, 2011 6:52 pm
in profile.XML file
find
or just replace your old Profiels.xml file with this one
profiles.xml
(55.14 KiB) Downloaded 994 times
mudplug
Post Wed Oct 05, 2011 6:02 am
Thank you cerb replaced the proileand restarted serviio, video works still audio not supported. Remuxed and put the AC3 audio tracks at the top now I get unsupported video data?? Argggggh
Post Wed Oct 05, 2011 12:58 pm
mudplug wrote:Thank you cerb replaced the proileand restarted serviio, video works still audio not supported. Remuxed and put the AC3 audio tracks at the top now I get unsupported video data?? Argggggh
Could you enable detailed logging (see signature), clean log file, restart serviio then start to stream the file (with cerb replaced profile), then post the log here?
Could you post "ffmpeg -i" of your remuxed file (the one with ac3 in first position)?
mudplug
Post Fri Oct 07, 2011 9:05 am
Thank all for your help got it working after a little remuxing and updating the Profile.
Post Fri Oct 07, 2011 10:29 am
mudplug wrote:Thank all for your help got it working after a little remuxing and updating the Profile.
Cool, but:
Please, could you explain in details?
little remuxing ?
updating profile?
Post Fri Oct 07, 2011 11:17 am
sounds like teh trueHD intergration isnt working, maybe i need to test that but i dont have a trueHD file to play with.
Users browsing this forum: Baidu [Spider] and 25 guests
