Pure EVOKE Flow - Transcoding profile
Post Wed Oct 05, 2011 12:20 am
Re: Pure EVOKE Flow - Transcoding profile
i dont mind if teh makers want to send me one of each of their device to test and make working profile for them all ;) for free of course.
BongMong
Post Wed Oct 05, 2011 12:33 am
Cerberus wrote:i dont mind if teh makers want to send me one of each of their device to test and make working profile for them all ;) for free of course.
I'm sure you wouldn't :)~
Back to reality...
Wouldn't we simply be able to add a couple of lines to the current Pure profile to handle images? I realise most Pure radios won't show images, but surely that will mean the image handling lines will not impact their operation at all as they would never come in to play. I thought the following would work, adjusting the image lines (taken from the Serviio generic profile) as per the Sensia spec. (if we knew it), after all using the generic profile on the Evoke Flow doesn't break it though of course it won't transcode audio that way. This code already detects the Sensia as confirmed by Aslan in this thread.
   <Profile id="17" name="Pure Flow" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>.*PURE.*</User-Agent>
         </HttpHeaders>
      </Detection>
         <Audio aBitrate="256" targetContainer="mp3">
            <Matches container="lpcm" />
            <Matches container="flac" />
            <Matches container="ogg" />
         </Audio>
      <AutomaticImageRotation>false</AutomaticImageRotation>
      <LimitImageResolution>true</LimitImageResolution>
Post Wed Oct 05, 2011 12:57 am
yes exactly but i need the information to know exactly what formats the device supports so it will work.
depending if the device does have limited resolution or already rotates the file we have to add teh follwoing lines
<AutomaticImageRotation>false</AutomaticImageRotation> or <LimitImageResolution>true</LimitImageResolution>
we have set the pure profile to inherit the MIME types for image from generic profile
<MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
<MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
<MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
hopefully they have used these MIME-TYPES other wise we will have to add custom ones to the pure profile and thats why i need the sink info
now if they support video files to and i think from our conversation so far none of them do then we would have to go into do video transcoding section.
BongMong
Post Wed Oct 05, 2011 1:05 am
Cerberus wrote:yes exactly but i need the information to know exactly what formats the device supports so it will work.
hopefully they have used these MIME-TYPES other wise we will have to add custom ones to the pure profile and thats why i need the sink info :)
now if they support video files to and i think from our conversation so far none of them do then we would have to go into do video transcoding section. :)
Ah, well I don't believe it shows video so no work to do there. We already know from Aslan that the current Pure profile appears to stream photos to the Sensia, so it can show JPEGs and obviously uses the right mime type for them.
So, can anyone else fill in the gaps we don't know? Especially providing the sink info, aquired as described earlier in this thread? I have PMed Aslan in case he is still visiting, but to be sure Sensia owners, we need your testings please...
Post Wed Oct 05, 2011 1:23 am
sorry i just reread what Aslan put and what he actual says is image work with current profile so we dont need to do anything, except test it we need to rotate or limit resolution on image files and that can be done by any user.
Aslan
Post Wed Oct 05, 2011 10:43 am
I can do this if someone tells me how.
Tried a couple of videos, avi and mpg, they didn't play.
Hven't got a photo larger than 4096x4096 so can't try that.
Post Wed Oct 05, 2011 6:48 pm
do this with each of the 3 profiles at bottom on this post and tell me which one show both files corectly.
heres one ;) see if that file gets added to library and shows on your device it very big in size
http://wp-b.com/media/images/2010/3/3/1267586199477.png
to test rotate just take an image and manualy in window rotate it so its on its side and then add it to serviio and see if when viewed on teh device it is the correct way up and not on its side :)
number 1 (original unmodfied profile)
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         </Audio>
Number 2 (auto rotating image and limiting resolution)
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         </Audio>
Number 3 (not rotating image but we are limiting resolution )
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         </Audio>
BongMong
Post Wed Oct 05, 2011 7:46 pm
Heh, got there before me :)~
Actually, I'm not sure the Sensia can handle png files. In case it helps, here's a large JPEG I've just made that is big enough and has the correct EXIF rotation info in place whilst being in landscape natively.
http://www.andycalling.webspace.virginm ... Cooker.jpg
May be better than the png for testing if the png just fails due to the format.
Post Wed Oct 05, 2011 7:51 pm
using a PNG was deliberate to see if it would fail ;)
BongMong
Post Wed Oct 05, 2011 8:00 pm
Ah, well, if it does fail, the JPEG can be used for testing phase 2. Also, you can marvel at my ancient cooker.
I have been contacted by Jason Voice (Pure tech suprimo) and he is taking a squiz at Serviio 0.6 for the promoting of. I imagine getting the photos perfect would help this along so ta Aslan, you're great for helping with your swanky high-end Pure set. Us humble Evoke owners won't see the improvement directly, but if it gets Serviio promoted better then more Pure users will find Serviio whatever set they can afford. So ta, you're a real gent (or a real lady of course...).
Post Sun Oct 09, 2011 4:17 pm
Does Serviio auto-rotate your image based on EXIF info? Does the Sensia do this natively? If not, would you like Serviio to auto-rotate photos?
No, but can be made by adding this to the profile:
That is only useful if the client doesn't do this automatically, as it takes long to show the picture and also loses quality.
What happens if you try to use a photo over 4096x4096 in resolution? I think Serviio defaults to limiting photos to 4096x4096. If not, it might be made to. Can the Sensia show photos over 4096x4096 natively? I can find no specifications on the Sensia that would inform me.
DLNA restricts to 4096x4096, so Serviio follows that. This can be turned off by adding this to the profile:
EDIT: just noticed some of this has been said, so either ignore this or use it to shed some more light if necessary
stephendhill
Post Sat Dec 15, 2012 7:42 pm
I have all my mp3's ripped at 320kbps. This causes glitching with the shipped profile. I have added mp3 as a source, to the existing transcoding section which transcodes to 256kbps, which fixes this issue. It would be a good idea to make this the default in the shipped profile.
Avid Serviio user
Pure Flow One | Samsung LE40B650 | Samsung UE40F6320 | Sony PS3 | Ubuntu 14.04
Previous
