Stream >=2.5 Mbps - ROUTER was the problem! Can you help?
turnig56
Post Tue Oct 04, 2011 11:00 pm
I was streaming full featured MKV file, which was using ~4Mbps bandwidth.
The playback was discontinuous. After direct ethernet connection RENDERER <=> COMPUTER, the problem disappeared.
I have a question: do you know good WiFi routers that can play high bitrate AV files "steadily"?
What is in fact the problem with such playback and configuration? Do I have a crap router?
Regards,
Turnig
Post Tue Oct 04, 2011 11:34 pm
Re: Stream >=2.5 Mbps - ROUTER was the problem! Can you help
I use a Belkin N gaming router. You also should look at this post http://forum.serviio.org/viewtopic.php?f=17&t=2439. It will tell you what your neighbors are using and if they could be affecting you.
Post Tue Oct 04, 2011 11:44 pm
i have posted this before but i will do it again for you cause i feel generious.
Virgin internet Compatible. ( RJ45 Connection )
http://www.netgear.co.uk/home/products/ ... R4000.aspx <-- best router i have ever used :) HINT HINT
BT internet Compatible. ( ADSL/RJ11 Connection )
http://www.netgear.co.uk/home/products/ ... D3700.aspx <-- million times better than the home hub.
NX3
Post Wed Oct 05, 2011 7:39 am
I use a WZR-HP-G300NH with DD-WRT and stream HD but a lot of variables in getting good wifi speed.
Homeplugs 200mpg+ or cable might be a better option.
turnig56
Post Wed Oct 05, 2011 3:07 pm
Thanks guys for the tips. I performed one more test yesterday: COMPUTER <=> router <=> RENDERER but with regular Ethernet cable instead of WiFi. It worked.
I have a docking station for my laptop (Sony Vaio) so currently I will use Ethernet cable when docked.
This is not best choice, as I was thinking about putting the laptop in other room while watching HD movie, to not hear its fan :S Maybe the homeplugs then? Hmm.
I am overall very happy that my HTheater (bdv e870) is capable of >20Mbps playback through DLNA (some scenes were in fact 20Mbps..).
These routers that you recommended are not cheap :S I just bought Pentegram Cerberus for my brother I hope it is not a peace of crap.
Regards,
Turnig
Post Wed Oct 05, 2011 6:43 pm
i would never recommend homeplugs as they cause way to many issues to ber worth the bother, get a decent router like the 2 i suggested and you can stream HD movies over wifi from 2 house away ;) ( yes i have done this as a test )
NX3 wrote:Homeplugs 200mpg+ or cable might be a better option.
you would still only get 100mbps as it would be limited by the device, so 500mbps dual band wifi will still be a better option.
turnig56
Post Wed Oct 05, 2011 7:12 pm
How many Mbps does HD movie require? I saw 20Mbps, so I think 50Mbps are possible?
PS. I am quoting Mbps values shown by HTheater (it shows audio format, kbps, video format (AVC) and its Mbps).
Post Wed Oct 05, 2011 7:20 pm
yes correct but you have to factor in what other thing your network is doing at the same time ;) and bottenecks in your network will also cause issues
turnig56
Post Sun Oct 23, 2011 12:29 pm
I am using cables and everything works but recently I occurred a MKV that in some moments has like >= 40 Mbps and in those moments the playback gets disturbed. Wonder what is the bottleneck in this situation. I suspect my Sony e870.
Post Sat Nov 05, 2011 7:47 am
turnig56 wrote:I am using cables and everything works but recently I occurred a MKV that in some moments has like >= 40 Mbps and in those moments the playback gets disturbed. Wonder what is the bottleneck in this situation. I suspect my Sony e870.
yep sony cant copy with it that high, see the sony section for more advise.
Return to User experiences
