[Solved] Here is how to get Online Links Info
Post Thu Oct 06, 2011 12:23 pm
Some of my Online links play on my BR Player, but on the TV get an invalid Video Codec message. The TV Details screen says they are mpeg, but how do I get more info like ffmpeg -i and Mediainfo give me for PC library files, so I can fix them on the TV?
Post Thu Oct 06, 2011 1:20 pm
Re: How do I get Online Links Info
You might try playing the file on your computer or seeing if you can down load it and then check the ffmpeg -i.
Post Thu Oct 06, 2011 7:57 pm
Ah now I see, thanks.
But Here's how I eventually did it.
1. Open RSS Feed in Explorer eg: http://feeds.feedburner.com/earth-touch_featured_720p?format=xml
2. Right click the "play" link for the selected video, and save the "link".
3. Run ffmpeg -i "link"
Post Sun Oct 09, 2011 5:55 pm
Re: [Solved] Here is how to get Online Links Info
This only works for some, the best is to enable detailed log and find the URL there.
