More trouble with MKV Playback
M0RPH
Post Wed Oct 05, 2011 11:14 pm
So I have this MKV and it gets seen on my Bravia, but when I go to play I get the dreaded "The server is Temporarily unavailable" message. Is my TV just not able to play this file?
I have added the log from ffmpeg that serviio is executing here:
ffmpeg -i /media/data/Videos/Friday_Night_Lights/Season_01/Friday.Night.Lights.1
x01.Pilot.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec copy -sn -f
 mpegts /tmp/Serviio/transcoding-temp-7710-MPEG2TS.stf
ffmpeg version N-33299-gd7366d9, Copyright (c) 2000-2011 the FFmpeg developers
  built on Oct  5 2011 23:25:05 with gcc 4.5.2
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libo
pencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis -
-enable-libx264 --enable-libxvid --enable-nonfree --enable-postproc --enable-ver
sion3 --enable-x11grab
  libavutil    51. 19. 0 / 51. 19. 0
  libavcodec   53. 19. 0 / 53. 19. 0
  libavformat  53. 14. 0 / 53. 14. 0
  libavfilter   2. 43. 6 /  2. 43. 6
  libpostproc  51.  2. 0 / 51.  2. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/1
25) -> 23.98 (24000/1001)
Input #0, matroska,webm, from '/media/data/Videos/Friday_Night_Lights/Season_01/
Friday.Night.Lights.1x01.Pilot.mkv':
    title           : 01 Pilot.m4v.mp4 - by LinkinPark for HDBits.org <3
  Duration: 00:45:56.19, start: 0.000000, bitrate: 4308 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
[mpegts @ 0x17924e0] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
 40 pkts
Output #0, mpegts, to '/tmp/Serviio/transcoding-temp-7710-MPEG2TS.stf':
    encoder         : Lavf53.14.0
    Stream #0:0(eng): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31,
 90k tbn, 23.98 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), 384 kb/s (default)
Stream mapping:
  Stream #0.0 -> #0.0 (copy)
  Stream #0.1 -> #0.1 (copy)
[mpegts @ 0x17924e0] pts < dts in stream 0
av_interleaved_write_frame(): Invalid argument
M0RPH
Post Wed Oct 05, 2011 11:47 pm
Re: More trouble with MKV Playback
Just to add, I can play the file fine using Windows Media Player, although serviio is doing nothing for this as it just picks it straight off the network. Leads me to thinking the file is not corrupt.
Post Thu Oct 06, 2011 12:03 am
please provide ffmpeg of the file. ( ffmpeg.exe -i "filename" ) and mediainfo of the file too please.
Post Thu Oct 06, 2011 9:49 am
It seems that ffmpeg could not transcode your mkv file :
M0RPH
Post Thu Oct 06, 2011 12:09 pm
Illico wrote:It seems that ffmpeg could not transcode your mkv file :
Yes, but is there anything that can be done in the settings/options to try and make it work? I am running ubuntu server 11.04 and re-installed ffmpeg last night so it should be the latest.
Post Thu Oct 06, 2011 3:02 pm
Could you post MediaInfo result here?
M0RPH
Post Thu Oct 06, 2011 3:46 pm
Illico wrote:Could you post MediaInfo result here?
Will do so tonight when I get home, thanks.
M0RPH
Post Thu Oct 06, 2011 8:23 pm
Here is the mediainfo results:
mediainfo /media/data/Videos/Friday\ Night\ Lights/Season\ 01/Friday.Night.Lights.1x01.Pilot.mkv
Unique ID : 64330283661796892487364661518720851200 (0x30658FDCD7532E86D20F07EBA7585D00)
Complete name : /media/data/Videos/Friday Night Lights/Season 01/Friday.Night.Lights.1x01.Pilot.mkv
Format : Matroska
Format version : Version 2
File size : 1.38 GiB
Duration : 45mn 56s
Overall bit rate : 4 308 Kbps
Movie name : 01 Pilot.m4v.mp4 - by LinkinPark for HDBits.org <3
Encoded date : UTC 2010-03-25 14:13:31
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 23:02:51
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 45mn 56s
Bit rate : 3 839 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.174
Stream size : 1.23 GiB (89%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 45mn 56s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 126 MiB (9%)
Language : English
M0RPH
Post Fri Oct 07, 2011 11:10 am
Anyone got an idea about this or do I just need to watch it on my PC?
Post Fri Oct 07, 2011 11:19 am
ok looks like a broken file cause i have a copy of this i just aquired and it works fine ;)
M0RPH
Post Fri Oct 07, 2011 12:15 pm
Cerberus wrote:ok looks like a broken file cause i have a copy of this i just aquired and it works fine ;)
Plays fine on XBMC on my PC, and all subsequent episodes have the same problem when playing through the Sony TV.
It definitely looks like an unsupported format for my TV :(
Post Fri Oct 07, 2011 12:25 pm
xbmc will play even the most broken files, even when all other players wont thats why it work in there and not on your sony.
M0RPH
Post Fri Oct 07, 2011 12:41 pm
Since XBMC can play this file, does anyone know if there is a way to have this play the file and broadcast it over the network to my Sony TV?
brigadier
Post Sun Oct 09, 2011 7:25 pm
I too am unable to play any mkv file through serviio on my bravia ex503. On the x media bar, the unplayable files come up as "AVC", whereas the playable (usually avi files) come up as "MPEG2". I run ubuntu 10.04, and have had to convert the mkv files to avis with winFF - this works, although there is some pixellation and loss of audio sync from time to time.
All mkvs play absolutely beautifully on my pc through GNOME player.
Any simple fixes would be greatly appreciated :)
Post Sun Oct 09, 2011 7:30 pm
what is your ffmpeg version?
M0RPH
Post Sun Oct 09, 2011 8:58 pm
zip wrote:what is your ffmpeg version?
I am using ffmpeg version N-33299-gd7366d9
It has done the same error on 5 episodes of this series and also one episode of a completely different program (which is also MKV H264). I don't think it is a corrupt file therefore. All plays fine through XBMC and I can play other files (avi anyway) on the Bravia using serviio no probs.
Post Sun Oct 09, 2011 10:46 pm
I think it's related to this ffmpeg issue: http://roundup.libav.org/issue807
M0RPH
Post Mon Oct 10, 2011 8:30 am
zip wrote:I think it's related to this ffmpeg issue: http://roundup.libav.org/issue807
Sounds very similar, any idea how to apply the patch that is mentioned there?
Post Mon Oct 10, 2011 8:57 am
It's a patch against quite an old version of FFmpeg source. You'd have to get FFmpeg sources from serviio download page, try applying the patch on it and then compile FFmpeg from those patched source files.
M0RPH
Post Mon Oct 10, 2011 9:04 am
Ok thanks, sounds like a lot of hassle for no guarantees. Maybe I will try out a different server and see if I have any more success.
