Connetion problem
philokokus
Post Fri Oct 07, 2011 8:36 pm
Connetion problem
Hi
I have a router (tp-link) and a range extender (also tp-link).
Almost all the time everything is working fine, but sometimes the tv doesn't connect to serviio. In serviio the tv (samsung ue46c5100) appears with the green dot (activ) but tv sais "no external storage device found. Check the connection status".
TV is wireless connected.
Any help?
Best Regards
Jose
Post Sat Oct 08, 2011 6:36 am
Re: Connetion problem
if you go to serviio to quickly after turning on TV you will get this message as teh tv hasnt recieved teh announcement from serviio to say it there yet.
philokokus
Post Sat Oct 08, 2011 9:07 am
Yes, I know that. But after 10, 20 min it still doesn't show in tv. That is not normal.
rabdo
Post Sat Oct 08, 2011 10:14 am
Connetion problem
It happens to me sometimes, I usually fix it by turning the TV off an on. I don't think it is a serviio issue as during these times when my TV is not finding serviio, my iPhone and iPad find serviio without any problems.
(Samsung UE40C5100)
philokokus
Post Sat Oct 08, 2011 11:23 am
Ok. Well, a minor problem!
Tks
Users browsing this forum: Google [Bot] and 21 guests
