Need help establishing profile for Philips 42PFL7406
norrgrd
Post Tue Oct 11, 2011 9:42 am
Hello all!
I've been having struggles getting Serviio to work well with my Philips TV. I looked into how to create a profile of my own but I don't quite get the hang of it and so I'm asking for help here.
Here's the info that I've gathered this far
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:audio/x-ms-asf:*,
http-get:*:audio/wav:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/vnd.dlna.adts:*,
http-get:*:audio/mp4:*,
http-get:*:video/x-matroska:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-asf-plugin:*,
http-get:*:video/mpeg4:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/msvideo:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/h264:*,
http-get:*:video/x-ms-wmv:*
The only thing I managed to play with the "Generic Profile" is .vob but there is no sound.
If I use the REGZA profile I'm able to play all content, but from what I understand it then transcodes every single bit though the computer can keep up with it no problem.
I try to do anything except stop the movie. Let's say I rewind/forward, the movie freezes but it keeps on transcoding, I can see the file on my computer is getting bigger and bigger.
If I try to play another file it just keeps on transcoding the old one I tried and nothing happens.
I have to restart Serviio (not only by shutting down the service and restarting it) to make it delete the transcoded file and first then I can play another one.
Any tips?
Best regards,
Alex
REG02862325.pdf
(125.58 KiB) Downloaded 1281 times
Post Tue Oct 11, 2011 9:55 am
Re: Need help establishing profile for Philips 42PFL7406
Thanks for all informations.
Could you also provide "Description xml" of your device using INTEL spy tool?
Could you add this section just before the last </Profiles> element in the "profiles.xml" file?
Then restart serviio service and check in serviio console that your device is automatically detected and proper profile is selected.
   <Profile id="21" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
Post Tue Oct 11, 2011 9:59 am
norrgrd
Post Sat Oct 15, 2011 11:03 am
Hi and thanks for the help!
The TV is automatically recognized as Philips now and AVI-files are working perfectly (ff, rew, pause etc)!
Vob-files are still without sound.
Any other format is not working (TV says not supported).
I read the other threads but couldn't really figure out what you wanted me to look after?
Attached is my description xml.
nmrDescription.xml
(2.25 KiB) Downloaded 1620 times
wandro
Post Sun Oct 16, 2011 9:14 am
Hello norrgrd,
since last Monday I have a Philips 47PFL7606K/02 TV, and I'd like to play the *.mpg.avi movies that I frequently would download from OnlineTVrecorder, using a media server.
So far I have found out that the PS3MediaSever (running on my Apple iMac) is able to transcode and play these OTR movies without needing any specific configuration, but unfortunately it seems to be unable to display *.jpg/*.jpeg files.
In contrast to this the Serviio server displays my jpeg photos without specific configuration but not the *.mpg.avi movies from OTR (using the generic DLNA profile).
Now I have seen here that you, norrgrd, have managed to play *.avi videos on your Philips 42PFL7406 TV, and I hope that I could successfully use the same profile/settings as you. I'd be very grateful of you could post the required file(s) here and explain to me where I have to put them. (I'm a complete Serviio newbie!) Many thanks in advance!
Post Sun Oct 16, 2011 10:16 am
Once we get this working for this Philips device and it is verified by a couple of additional users, Zip will probably update the profiles.xml file with the information in the next revision.
norrgrd
Post Sun Oct 16, 2011 12:25 pm
Hey wandro,
Look at Illicos post above (viewtopic.php?f=5&t=3591#p23926)
I am not really sure where you can find profiles.xml on a mac.
Also have a look here to get a better understanding of profiles.xml http://www.serviio.org/index.php?option ... icle&id=16
wandro
Post Mon Oct 17, 2011 7:49 am
I have now applied the modifications proposed by illico to my profiles.xml file (btw: it is in Servio.app/Contents/Resources/Java/config on Mac OS), but that didn't help. Probably I should solve two other strange problems first:
    1. We have two iMac's. The Philips TV is listed (with a green bullet and the correct IP address) in the renderer's window on both iMac's. (I run only one Serviio server at a time, of course!) But conversely, the media server is recognized on the TV only if it runs on the second of our iMac's.
    2. In the latter case, however, the TV displays a list of movies offered by the media server that is outdated apparently: It still contains movies that I have deleted in the meantime from my movie directory on the second iMac. For each of the still existing movies the TV reports that it couldn't be found or read, just as for the non-existing ones.
Post Mon Oct 17, 2011 7:55 am
what is the IP addresses of the imacs and the Philips TV?
wandro
Post Mon Oct 17, 2011 4:25 pm
moltra wrote:what is the IP addresses of the imacs and the Philips TV?
Philips TV: 192.168.1.137
First iMac (Ethernet): 192.168.1.51
Second iMac (WLAN): 192.168.1.53
Connecting the first iMac via WLAN (192.168.1.59) makes no difference: TV doesn't recognize Serviio server.
In the attachment you find the configuration files of PS3MediaServer for PS3 (containing explanations) and Philips. Perhaps that helps to create a working Philips configuration for Serviio.
Philips.txt
(3.29 KiB) Downloaded 1192 times
PS3.txt
(14.95 KiB) Downloaded 1389 times
wandro
Post Mon Oct 17, 2011 4:55 pm
Now I have tested PS3MediaServer on my first iMac: It doesn't recognize the TV, and the TV doesn't recognize the server either.
In the attachment you find the configuration files of PS3MediaServer for PS3 and Philips (pure text files). Perhaps that helps to create corresponding Serviio profiles.
Post Mon Oct 17, 2011 7:13 pm
Try this:
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="avi" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpeg" aCodec="aac" />
            <Matches container="mpeg" aCodec="mp3" />
            <Matches container="mpeg" aCodec="dca" />
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
norrgrd
Post Mon Oct 17, 2011 7:17 pm
Should I test that aswell Illico? Or is it just for wandro?
Post Mon Oct 17, 2011 7:20 pm
norrgrd wrote:Should I test that aswell Illico? Or is it just for wandro?
47PFL7606 and 42PFL7406 should be similar, so yes.
norrgrd
Post Mon Oct 17, 2011 11:47 pm
When adding that to my profile it starts to transcode avi-files that works without transcode (all I've tried) and if I try to rw/fw the sound gets all messed up though the picture is fine, even if I wait until it's all transcoded before I try. Did not happen before without transcode.
Media that does work:
127 Hours - MKV (RW/FF will freeze it and transcoding will still continue and I am unable to chose any other media until I restart the server and TV)
UniqueID/String                  : 215195261542936816876435282079051138879 (0xA1E5198D1EDB79C0A263C8DE231FC73F)
CompleteName                     : F:\movies\hd\127.Hours.2010.720p.BluRay.x264-Felony\f-127.hours.720.mkv
Format                           : Matroska
Format_Version                   : Version 2
FileSize/String                  : 4.36 GiB
Duration/String                  : 1h 33mn
OverallBitRate/String            : 6 661 Kbps
Encoded_Date                     : UTC 2011-02-15 04:25:47
Encoded_Application              : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Encoded_Library/String           : libebml v1.0.0 + libmatroska v1.0.0
ID/String                        : 1
Format_Profile                   : High@L4.1
Format_Settings_CABAC/String     : Yes
Format_Settings_RefFrames/String : 5 frames
CodecID                          : V_MPEG4/ISO/AVC
BitRate/String                   : 5 153 Kbps
Width/String                     : 1 280 pixels
Height/String                    : 688 pixels
DisplayAspectRatio/String        : 1.860
FrameRate/String                 : 23.976 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Bits-(Pixel*Frame)               : 0.244
StreamSize/String                : 3.28 GiB (75%)
Encoded_Library/String           : x264 core 112 r1867 22bfd31
Encoded_Library_Settings         : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5153 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language/String                  : English
ID/String                        : 2
Format                           : DTS
Format/Info                      : Digital Theater Systems
CodecID                          : A_DTS
BitRate_Mode/String              : Constant
BitRate/String                   : 1 510 Kbps
Channel(s)/String                : 6 channels
ChannelPositions                 : Front: L C R, Side: L R, LFE
SamplingRate/String              : 48.0 KHz
BitDepth/String                  : 24 bits
Compression_Mode/String          : Lossy
StreamSize/String                : 1 012 MiB (23%)
And Justice For All - MKV (RW/FF will freeze it and transcoding will still continue and I am unable to chose any other media until I restart the server and TV)
CompleteName                     : F:\movies\hd\And.Justice.for.All.1979.1080p.BluRay.X264-AMIABLE\And.Justice.for.All.1979.1080p.BluRay.X264-AMIABLE.mkv
Format                           : Matroska
FileSize/String                  : 8.75 GiB
Duration/String                  : 1h 59mn
OverallBitRate/String            : 10.5 Mbps
Encoded_Application              : x264.exe
Encoded_Library/String           : mkv2rls v1.4 (date: 2011 mar 29)
ID/String                        : 1
Format_Settings_RefFrames/String : 4 frame2
BitRate/String                   : 9006 Kbps
Width/String                     : 1920 pixel3
Height/String                    : 1080 pixel3
DisplayAspectRatio/String        : 16:9
FrameRate/String                 : 23.976 fps2
ColorSpace                       : YUV
BitDepth/String                  : 8 bit3
Bits-(Pixel*Frame)               : 0.181
StreamSize/String                : 7.32 GiB (84%)
Encoded_Library/String           : x264 core 114 r1924 08d04a4
Encoded_Library_Settings         : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9006 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language/String                  : en
ID/String                        : 2
Format                           : DTS
CodecID                          : A_DTS
BitRate_Mode/String              : CBR
BitRate/String                   : 1510 Kbps
Channel(s)/String                : 6 channel3
BitDepth/String                  : 24 bit2
StreamSize/String                : 1.26 GiB (14%)
Text
ID/String                        : 3
Format                           : UTF-8
CodecID                          : S_TEXT/UTF8
CodecID/Info                     : UTF-8 Plain Text
Menu
00:00:00.000                     : en:00:00:00.000
00:07:24.819                     : en:00:07:24.819
00:13:24.262                     : en:00:13:24.262
00:20:15.506                     : en:00:20:15.506
00:27:49.835                     : en:00:27:49.835
00:31:52.869                     : en:00:31:52.869
00:41:30.697                     : en:00:41:30.697
00:47:51.911                     : en:00:47:51.911
00:54:28.098                     : en:00:54:28.098
01:04:14.350                     : en:01:04:14.350
01:12:36.519                     : en:01:12:36.519
01:16:38.010                     : en:01:16:38.010
01:22:31.989                     : en:01:22:31.989
01:29:50.218                     : en:01:29:50.218
01:38:02.085                     : en:01:38:02.085
01:47:51.256                     : en:01:47:51.256
The A-Team - MKV (RW/FF will freeze it and transcoding will still continue and I am unable to chose any other media until I restart the server and TV)
UniqueID/String                  : 252577210574677636036556676269020902898 (0xBE0499EF8DE0E7FAB1EC87641A7175F2)
CompleteName                     : F:\movies\hd\The.A-Team.EXTENDED.1080p.BluRay.x264-ZMG\The.A-Team.EXTENDED.1080p.BluRay.x264-ZMG.mkv
Format                           : Matroska
FileSize/String                  : 10.7 GiB
Duration/String                  : 2h 13mn
OverallBitRate/String            : 11.5 Mbps
Encoded_Date                     : UTC 2010-10-11 16:04:14
Encoded_Application              : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Encoded_Library/String           : libebml v0.7.7 + libmatroska v0.8.1
ID/String                        : 1
Format_Settings_RefFrames/String : 5 frame3
BitRate/String                   : 9999 Kbps
Height/String                    : 816 pixel3
DisplayAspectRatio/String        : 2.35:1
ColorSpace                       : YUV
Bits-(Pixel*Frame)               : 0.266
StreamSize/String                : 9.11 GiB (85%)
Encoded_Library/String           : x264 core 98 r1649 20cbe10
Encoded_Library_Settings         : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=16 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9999 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
ID/String                        : 2
Format                           : DTS
CodecID                          : A_DTS
StreamSize/String                : 1.41 GiB (13%)
Title                            : English DTS
Text #1
ID/String                        : 3
Format                           : UTF-8
Title                            : English - SDH
Text #2
ID/String                        : 4
Format                           : UTF-8
Title                            : English - Forced
American Dad - MKV (RW/FF will freeze it and transcoding will still continue and I am unable to chose any other media until I restart the server and TV)
UniqueID/String                  : 282940848868769917483114880635877974941 (0xD4DC6CE29A16BA518DC04AAEEADFE39D)
CompleteName                     : F:\movies\serier\american dad\s6\American.Dad.S06E01.720p.HDTV.X264-DIMENSION\American.Dad.S06E01.720p.HDTV.X264-DIMENSION.mkv
Format                           : Matroska
FileSize/String                  : 559 MiB
Duration/String                  : 21mn 11s
OverallBitRate/String            : 3690 Kbps
Encoded_Date                     : UTC 2010-10-03 17:28:04
Encoded_Application              : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Apr 19 2010 11:58:49
ID/String                        : 1
Format_Settings_RefFrames/String : 8 frame3
BitRate/String                   : 3237 Kbps
Width/String                     : 1280 pixel3
Height/String                    : 720 pixel3
ColorSpace                       : YUV
Bits-(Pixel*Frame)               : 0.146
StreamSize/String                : 480 MiB (86%)
Encoded_Library/String           : x264 core 105 r1732 2b04482
Encoded_Library_Settings         : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3237 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
ID/String                        : 2
Format                           : AC-3
Format/Info                      : Audio Coding 3
Format_Settings_ModeExtension    : CM (complete main)
CodecID                          : A_AC3
BitRate/String                   : 448 Kbps
BitDepth/String                  : 16 bit3
StreamSize/String                : 67.9 MiB (12%)
Sucker Punch - MP4 (FF/RW works fine)
CompleteName                     : F:\movies\hd\Sucker.Punch.2011.720p.BRRip.x264.AAC-ViSiON\Sucker.Punch.2011.720p.BRRip.x264.AAC-ViSiON.mp4
Format                           : MPEG-4
Format_Profile                   : Base Media
CodecID                          : isom
FileSize/String                  : 1.70 GiB
Duration/String                  : 1h 49mn
OverallBitRate_Mode/String       : VBR
OverallBitRate/String            : 2220 Kbps
Encoded_Date                     : UTC 2011-06-17 08:02:02
Tagged_Date                      : UTC 2011-06-17 08:02:02
ID/String                        : 1
Format_Profile                   : High@L5.1
CodecID                          : avc1
CodecID/Info                     : Advanced Video Coding
BitRate/String                   : 1900 Kbps
BitRate_Maximum/String           : 11.2 Mbps
Height/String                    : 528 pixel3
DisplayAspectRatio/String        : 2.40:1
FrameRate_Mode/String            : CFR
ColorSpace                       : YUV
Bits-(Pixel*Frame)               : 0.117
StreamSize/String                : 1.46 GiB (86%)
Encoded_Library/String           : x264 core 80 r1376M 3feaec2
Encoded_Library_Settings         : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1900 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded_Date                     : UTC 2011-06-17 05:11:14
Tagged_Date                      : UTC 2011-06-17 08:03:06
Material_Duration                : 143206
Material_StreamSize              : 1563586482
Material_FrameCount              : 157898
ID/String                        : 2
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format_Profile                   : LC
CodecID                          : 40
BitRate/String                   : 317 Kbps
BitRate_Maximum/String           : 468 Kbps
StreamSize/String                : 249 MiB (14%)
Title                            : Imported with GPAC 0.4.6-DEV (build 1)
Encoded_Date                     : UTC 2011-06-17 08:02:45
Walk Hard - The Dewey Cox Story - M2TS (FF/RW works fine)
ID/String                        : 1 (0x1)
CompleteName                     : F:\movies\hd\Walk Hard The Dewey Cox Story (Unrated)\Walk Hard (The Dewey Cox Story Unrated).m2ts
Format                           : BDAV
Format/Info                      : Blu-ray Video
FileSize/String                  : 4.00 GiB
Duration/String                  : 2h 0mn
OverallBitRate/String            : 4756 Kbps
OverallBitRate_Maximum/String    : 35.5 Mbps
ID/String                        : 4113 (0x1011)
MenuID/String                    : 1 (0x1)
Format_Profile                   : High@L4.0
Format_Settings_RefFrames/String : 3 frame2
CodecID                          : 27
BitRate/String                   : 4043 Kbps
BitRate_Maximum/String           : 25.0 Mbps
ColorSpace                       : YUV
Bits-(Pixel*Frame)               : 0.081
StreamSize/String                : 3.46 GiB (86%)
Encoded_Library/String           : x264 core 66 r1114M a933a3e
Encoded_Library_Settings         : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4043 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
ID/String                        : 4352 (0x1100)
Format                           : AC-3
CodecID                          : 129
StreamSize/String                : 386 MiB (9%)
Media that doesn't work:
Haven't found any yet, except unsupported file formats (I think they are) like .img and .iso, they doesn't even show up. Also no subtitles are working, neither embedded, .srt, .sub or .idx.
Post Tue Oct 18, 2011 7:45 am
norrgrd wrote:...avi-files that works without transcode (all I've tried) and if I try to rw/fw the sound gets all messed up though the picture is fine, even if I wait until it's all
Aaahhh, sorry please remove <Matches container="avi" /> element
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
norrgrd
Post Tue Oct 18, 2011 3:51 pm
Thanks, works better now :)
Any idea how to solve ff/rw with MKV's? And the subtitle support?
Post Tue Oct 18, 2011 4:10 pm
norrgrd wrote:Thanks, works better now :)
OK
norrgrd wrote:Any idea how to solve ff/rw with MKV's?
We could try remux mkv into mpegps as others container. See following profile.
norrgrd wrote: And the subtitle support?
No, if philips TV not support mkv in native format, we have to remux video/audio/subtitle into MPEGPS or MPEGTS stream. But for the moment Serviio does not support remuxing subtitle or "burn" subtitle into video stream. Serviio only support external "srt" subtitle file.
With MKVtoolnix you can try to extract subtitle into a "srt" file with same name of the movie file *.srt
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
norrgrd
Post Tue Oct 18, 2011 4:33 pm
Sweet, works absolutely flawless for me except for subtitles but I don't really give a damn :)
Thanks for all the help!
Post Tue Oct 18, 2011 7:25 pm
norrgrd wrote:Sweet, works absolutely flawless for me except for subtitles but I don't really give a damn :)
Do you mean that the latest profile is the solution for mkv ff/rw ?
norrgrd wrote:Thanks for all the help!
Regards ;)
Return to Philips
