Shut Down PC
• Page 1 of 1
my server and my tv are in different rooms. so when i finish watching a movie, i always have to go to the other room and shut down the server manually. it would be superawesome if i could shut down the pc via the remote control of my tv. serviio has so many menus, another one wouldn't hurt for this feature
Re: Shut Down PC
nope zip has said he wont be adding this.
Re: Shut Down PC
thanks for the reply! is there some way that i could do this myself? eg via plugin?
Re: Shut Down PC
Lofi wrote:thanks for the reply! is there some way that i could do this myself? eg via plugin?
nope as serviio is closed source.
Re: Shut Down PC
You could probably find a third party program that is not related to serviio to do this. Do a google search and you might find one.
Re: Shut Down PC
moltra wrote:You could probably find a third party program that is not related to serviio to do this. Do a google search and you might find one.
Yes in fact for example PS3 Media Server add a virtual folder that include somes tips like:
For windows:
POWEROFF: runtime.exec("ShutDown /s /f");
RESTART: runtime.exec("ShutDown /r /f");
HIBERNATE: runtime.exec("ShutDown /h");
For Linux:
POWEROFF: runtime.exec("shutdown -h now");
RESTART: runtime.exec("shutdown -r now");
HIBERNATE: runtime.exec("sudo hibernate-ram --force");
For MAC ??
• Page 1 of 1
Users browsing this forum: Baidu [Spider] and 13 guests
