Panasonic Viera G20 and Online feeds
Neoromancer
Post Wed Oct 12, 2011 5:56 am
Panasonic TX-P42G20E + Serviio 0.6 all files play well but there are problems with online feeds.
Problem: I installed TV3Play (Lithuania) but my Panasonic Viera does not want to play. If I choose the Samsung (C / D) profile then playing well, but does not play MKV and several other files. I tried to edit my Panasonic Viera but I fail to make that play. Help write the correct profile.
Sorry for bad English.
Panasonic TX-P42G20E | Ubuntu server 10.04.3 64-bit | Serviio 0.6.2
Post Wed Oct 12, 2011 8:53 am
Re: Panasonic Viera G20 and Online feeds
try to copy OnlineTranscoding section from Samsung B series to the Viera profile
Neoromancer
Post Wed Oct 12, 2011 2:52 pm
zip wrote:try to copy OnlineTranscoding section from Samsung B series to the Viera profile
It did not help. Only works with Samsung, B, C, D, and Direct TV HD DVR profiles. What ideas?
Now my profile is:
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
      <MediaFormatProfiles>
      </MediaFormatProfiles>
         <!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
            <Matches container="matroska" vCodec="h264" aCodec="dca" />
            <Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
         <!-- Remux all h264 video to MPEG-TS stream -->
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Audio targetContainer="mp3">
            <Matches container="mp4" />
            <Matches container="flac" />
         </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="mp4"/>
            <Matches container="flv"/>
         </Audio>
      </OnlineTranscoding>
Post Wed Oct 12, 2011 3:12 pm
did you restart Serviio service after editing the profile? what exactly does not work? any error in detailed log?
Neoromancer
Post Wed Oct 12, 2011 4:00 pm
zip wrote:did you restart Serviio service after editing the profile? what exactly does not work? any error in detailed log?
Yes, I restart service.
If chosen the Panasonic Viera TV says file is not supported and does not play.
If I select Samsung, B, C, D, or Direct TV HD DVR profiles TV3 Play work wery well. But then not playing local mkv files.
Attaching the log file
neoromancer_log.zip
Panasonic Viera profile not work with TV3 Play online source
(44.16 KiB) Downloaded 635 times
Post Wed Oct 12, 2011 4:41 pm
Ok, it's because it's FLV with a different codec than h264. Some changes need to go to the Generic profile online transcoding which should hopefully fix this.
Keep an eye on this: https://bitbucket.org/xnejp03/serviio/i ... ent-705614
EDIT: actually that might be related to the Samsung profiles. I'll need a detailed log showing only the Viera profile playback.
Neoromancer
Post Wed Oct 12, 2011 5:48 pm
I reinstalling Serviio and ten edited Viera profile. Now working fine. Before that I was done editing error.
My working profile:
         </Audio>
      <OnlineTranscoding>
         </Audio>
Neoromancer
Post Wed Oct 12, 2011 8:00 pm
How to correctly put the Earth-Touch feeds in Serviio? If I add http://www.earth-touch.com/rss/ then in Panasonic TV show empty "folder" caled http://www.earth-touch.com/rss/ without video contents.
Post Wed Oct 12, 2011 9:55 pm
You can get the links on the right hand side on the (above linked) page
Neoromancer
Post Thu Oct 13, 2011 4:48 pm
Thank you! Works fine.
andriusd
Post Thu Mar 14, 2013 5:45 pm
Hello, all,
I want have Lithuanian tv3play too.I added this plugin but without success. Then I changed my profile to Neoromancer's working profile and again without success.
Please see bellow:
1. As can be seen I have tv3play icon on my tv:
2. But tv3play is empty:
Please help me! If it helps I am using P42ST50E TV.
Return to Panasonic
