planning a complete new set up help please
eddiehook
Post Thu Oct 13, 2011 7:53 pm
Hi all am new and not sure if in the right place so please bear with me.
I am planning a new set up as follows:
main lounge samsung 46 inch 5.1 surround etc
master bed samsung 32 inch
2 x beds samsung 22 inch
possibly with blu ray for all share
media cupboard - computer dedicated to film and music library networked to all samsungs with blu ray burn/rip (with serviio as the media server because seems to be the best for cover art and ease of use)
audio will be by way of a cloud dcm1 and amp wired around with ceiling speakers and wall pad controllers in each zone.
firstly would anybody like to comment on system I hope it will work :? or any suggestions would be great sorry if off topic :oops:
have looked around all over the web and here to see the Serviio UI working on a video or something but cant seem to find, could anybody point me in the right direction please
eddiehook
Post Thu Oct 13, 2011 11:25 pm
Re: planning a complete new set up help please
Hi me again,
have just downloaded serviio and set up libraries. Question do I have to have a dlna device to see the interface or can I check it out on my computer, showing no device in status at moment although did pick up windows media player first off but would not open. hope somebody can help
Post Thu Oct 13, 2011 11:40 pm
Interface is dependent on the device. You can check what folders and files Serviio serves, for example via Intel tools' AV Media Controller
Post Fri Oct 14, 2011 1:35 am
you can also use a software dlna render on a computer on the network. I use XBMC to make sure a file shows up and to watch files on my computers.
eddiehook
Post Fri Oct 14, 2011 6:46 am
Thanks guys,
downloaded xbmc and put serviio as file for movies, works great, really have to order my first samsung today to have a play and learn all about so when system goes in it is seamless,I can feel a few late nights coming on :D
forgetting the audio do you think system will work and am I missing anything and do you guys have any preference on samsung tv model that works best, have read all the threads but still cant make up my mind.
will donate i promise as it seems you have worked really hard to put an amazing bit of software together.
eddiehook
Post Fri Oct 14, 2011 2:39 pm
Just ordered the C6100 plus 3d blu ray player hope it all works :D
Post Sat Oct 15, 2011 2:11 pm
moltra wrote:you can also use a software dlna render on a computer on the network. I use XBMC to make sure a file shows up and to watch files on my computers.
i second that and to note DLNA wont work on WMP as its using one standard dlna setup that why we recommend XBMC.
eddiehook wrote:Thanks guys,
get C series ones if you can they are much better than the new D series :) (eg LE40C750)
eddiehook
Post Tue Oct 18, 2011 12:46 pm
Hi all,
have now set up with new samsung d6100 all works perfectly but a couple of questions please
is there a way of making the film thumbnails a bit bigger?
can I just have 1 or 2 files in each section
do you think it will all work when I have the other 3 tv's set up all wired cat6 and through a gigabyte switch
Ed
Post Tue Oct 18, 2011 12:48 pm
No
What do you mean?
Yes
eddiehook
Post Tue Oct 18, 2011 2:43 pm
am trying to make as user friendly as poss I have found section where I can knock off files ie actors/directors etc
Is there a way to do a search at all?
Cheers
Post Tue Oct 18, 2011 2:53 pm
no search
Post Tue Oct 18, 2011 3:25 pm
eddiehook wrote:am trying to make as user friendly as poss I have found section where I can knock off files ie actors/directors etc
Cheers
Under title it you can pick the 1st letter/number of the name and see all of the movies that start with that letter/number.
ie. "U"
Under siege
Under siege 2 Dark Territory
Return to General discussion
Users browsing this forum: Baidu [Spider] and 13 guests
