Panasonic DT 30/35 LED LCD TV
andre2201
Post Fri Oct 14, 2011 9:37 am
Hello.
My name is Andre and I am from Germany. My English is not good and I use the Google translator. :roll:
Serviio is a great program and I use it with my Sony TV (EX725). Perfect! :)
Since I'm going to buy me one soon Pansaonic TV (DT30), I have a question about Panasonic's Profile:
Be transmitted using the standard profile *.mkv Files transcode or natvie?
Thank you for your help!
Post Fri Oct 14, 2011 10:14 am
Re: Panasonic DT 30/35 LED LCD TV
using the Panasonic profile mkv is remuxed to mpegts (H264 content is kept in the original quality)
andre2201
Post Sat Oct 15, 2011 8:29 pm
Thank you for your information !
In the next week I get the TV, I'm curious if it works and will report.
andre2201
Post Sun Nov 20, 2011 10:50 pm
The profile panasonic when I use mkv files do not fit with aspect ratio. I use generic dlna it's ok.
why is this so?
Post Sun Nov 20, 2011 11:06 pm
They might have changed the firmware. Can you post the information on the TV (see signature on how).
andre2201
Post Mon Nov 21, 2011 8:13 am
Sorrx, but what information you need?
Post Mon Nov 21, 2011 11:44 am
andre2201 wrote:The profile panasonic when I use mkv files do not fit with aspect ratio. I use generic dlna it's ok.
why is this so?
it's probably transcoded with wrong aspect ratio. It seems you don't need that transcoding so either update the profile or turn off transcoding in the console (but you migh lose playback of some other files)
Return to Panasonic
