online sources with sony set up
carwyn11
Post Thu Oct 13, 2011 5:50 pm
TV sony bravia kdw37ex401u LCD
Blu ray sony bdp-2370
sony iwa br100 USB wireless LAN adapter
windows vista with netgear WG111v3 adapter (soon to be a 300 Mbps vesion)
Hi, I have read through the online sources folder and copy and pasted the links to my online source folder in my console.
They show up on my blu ray drop down list along with the other shared films folders,
but do not do anything when I click on them... it just says that there are no playable files?
Am I doing something wrong here?
Carwyn
sony Uwa br100 Wireless Lan adapter
Post Fri Oct 14, 2011 1:32 am
Re: online sources with sony set up
Can you post your serviio.log file?
carwyn11
Post Fri Oct 14, 2011 6:20 am
not sure how to post a log file?
Carwyn
Post Fri Oct 14, 2011 8:25 am
Look at signature links :
HowTo: Turn on detailed logging
carwyn11
Post Fri Oct 14, 2011 12:25 pm
Hi, thanks for the reply but... I dont understand what to do ?
You can enable DEBUG level for the logger to see detailed logs. Edit file log4j.xml in config folder and change this:
<category name="org.serviio">
<priority value="INFO"/>
</category>
to:
<priority value="DEBUG"/>
</category>
this does not mean much to me... can you tell me where to go to change this setting? I realise this may be obvious to most :?
thanks
Carwyn
carwyn11
Post Sat Oct 15, 2011 7:52 am
ok found it... but get this mesage?
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
The system cannot locate the resource specified. Error processing resource 'log4j.dtd'. Error processing resource 'file://...
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
any ideas??
Carwyn
Post Sat Oct 15, 2011 10:11 am
Yes, when you edited the log4j file something was typed wrong. Can you copy and paste the file here or attach it.
carwyn11
Post Sat Oct 15, 2011 11:07 am
hi , I was not sure I went far enough to even edit it as i cannot open it. I can open the profile xml file below it though. When I try to open the log4j file it just pops up this;
Carwyn
Post Sat Oct 15, 2011 2:14 pm
Use "Windows Notepad" for editing xml files. (better use notepad++)
Post Sat Oct 15, 2011 2:16 pm
carwyn11 wrote:...
Could you provide here the url link you copy/paste?
carwyn11
Post Sat Oct 15, 2011 4:12 pm
it's odd that it'll open the "profile" xml file below the log4j no problem but just not the log4j.
I have copied and pasted some links from here to put in my online cources folder in the serviio console..
heres one,
http://revision3.com/geekbeattv/feed/MP4-hd30
but it does not show up on my tv?
Carwyn
carwyn11
Post Sun Oct 16, 2011 5:35 pm
heres one,
Carwyn
Post Sun Oct 16, 2011 6:43 pm
carwyn11 wrote:I have copied and pasted some links from here to put in my online cources folder in the serviio console..
heres one,
Sorry, but this link is ok for me with my Sony KDL-46EX501 and BDP-S373.
Do you try the same link into your IE/Firefox browser?
Do you have the "Online Feed" folder into the XMB->Video sony menu ? check on serviio console the presentation tab setting.
