Issue with an mkv not playing
Malic
Post Sun Oct 16, 2011 11:21 am
OS is Kubuntu 11.10
Player is Samsung BD-C5500
ffmpeg info:
ffmpeg -i \[Mazui\]_Boku_Ha_Tomodachi_Ga_Sukunai_-_02_\[D4FFD0B0\].mkv
ffmpeg version 0.7.2-4:0.7.2-1ubuntu1, Copyright (c) 2000-2011 the Libav developers
  built on Oct  2 2011 15:13:26 with gcc 4.6.1
  configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=amd64 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-li    bdc1394 --enable-shared --disable-static
  libavutil    51.  7. 0 / 51.  7. 0
  libavcodec   53.  5. 0 / 53.  5. 0
  libavformat  53.  2. 0 / 53.  2. 0
  libavdevice  53.  0. 0 / 53.  0. 0
  libavfilter   2.  4. 0 /  2.  4. 0
  libpostproc  52.  0. 0 / 52.  0. 0
[matroska,webm @ 0xad2340] max_analyze_duration reached
[matroska,webm @ 0xad2340] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '[Mazui]_Boku_Ha_Tomodachi_Ga_Sukunai_-_02_[D4FFD0B0].mkv':
  Duration: 00:24:29.90, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.000000, end 50.007000
      title           : Prologue
    Chapter #0.1: start 50.007000, end 149.940000
      title           : OP
    Chapter #0.2: start 149.940000, end 694.985000
      title           : Part 1
    Chapter #0.3: start 694.985000, end 1339.921000
      title           : Part 2
    Chapter #0.4: start 1339.921000, end 1429.927000
      title           : ED
    Chapter #0.5: start 1429.927000, end 1469.909000
      title           : Preview
    Stream #0.0(jpn): Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(jpn): Audio: aac, 48000 Hz, stereo, s16
    Stream #0.2(eng): Subtitle: ass (default)
    Stream #0.3: Attachment: [0][0][0][0] / 0x0000
      filename        : AdobeHeitiStd-Regular.otf
    Stream #0.4: Attachment: [0][0][0][0] / 0x0000
      filename        : aquafont.ttf
    Stream #0.5: Attachment: [0][0][0][0] / 0x0000
      filename        : arial.ttf
    Stream #0.6: Attachment: [0][0][0][0] / 0x0000
      filename        : BADABB__.TTF
    Stream #0.7: Attachment: [0][0][0][0] / 0x0000
      filename        : bonzai.ttf
    Stream #0.8: Attachment: [0][0][0][0] / 0x0000
      filename        : Montara-Gothic.otf
    Stream #0.9: Attachment: [0][0][0][0] / 0x0000
      filename        : MyriadPro-Semibold.otf
    Stream #0.10: Attachment: [0][0][0][0] / 0x0000
      filename        : MyriadPro-SemiboldIt.otf
    Stream #0.11: Attachment: [0][0][0][0] / 0x0000
      filename        : Stoobs.ttf
And I've attached the mediainfo. Funny thing is, as far as I can tell, the encode for this file is effectively the same as another one that I could play. I can provide the ffmpeg and the mediainfo on the other one if it's needed.
mediainfo.txt
(2.55 KiB) Downloaded 648 times
Post Sun Oct 16, 2011 2:40 pm
Re: Issue with an mkv not playing
Nothing obvious to me. Whats the error you get?
Malic
Post Sun Oct 16, 2011 6:14 pm
It was something along the lines of the file was not supported. I went and tried it again to see if I can get the specific error message, but it plays the file fine now. I guess restarting the machines fixed it somehow? Anyway, sorry about that.
