Samsung D Series Summary
Post Thu Oct 13, 2011 7:25 pm
I have a D series TV and BR player, and have opened this thread to maintain a summary of the problems and fixes that I have identified. This will allow me to keep track of all these items in one place, (I'll edit this first post as required) and hopefully it will be of value to other Samsung D series users.
Please post replies as required to ask questions or add more info, and I will respond/verify/add to this post.
File Playback
I have found that the D series can play most of my files natively. And that the Samsung manuals correctly state that capability in their "Supported File Formats" section. The Samsung C/D profile 1.6 contained in Serviio Version .6 correctly converts the file formats that are not natively supported, in particular .flv format files with H.264(avc) video codecs are simply remuxed to avc.ts and all other .flv video codecs are converted and remuxed to mpeg2video.ts which includes VP6.flv and H263.flv files. There is however a bug which prevents those transcoded VP6.flv and H263.flv files from playing back on the D series TV's, however they play back correctly on BR's. I have reported this as bug #429 https://bitbucket.org/xnejp03/serviio/issue/429/samsung-d-series-tv-wont-play-transcoded Since YouTube will utilize H263 when selecting "low quality" and fail, select "medium quality" for youtube links on D series TV's until this issue is corrected.
File Skipping
I have found that all files except mpegs (.mpg,.mpeg,.vob,.vro,.ts,.tp and .trp) will allow "skipping". Unbelievably the mpegs on the D series do not offer skipping when played over DLNA which I believe is a unique Samsung D series firmware bug in both the TV's and BR's because both the B and C series allow mpeg skipping. I have tried to raise this issue with Samsung in hopes of a future firmware fix. The significance of this is that no transcoded file can be skipped because they are all remuxed to an mpeg container. This is more fully detailed in http://forum.serviio.org/viewtopic.php?f=10&t=2714 Others should raise this issue with Samsung in order to raise the fix priority.
Since all .flv files will be transcoded and not skip, my workaround for local flv files that I want to be able to skip is to preconvert avc.flv to avc.mkv and H263/VP6.flv to divx.avi using the attached "convert FLV.bat", which I offer as is. It will need to be set up to point at your Mediainfo_CLI.exe and ffmpeg.exe.
D Button Menu Sort and Resume Support
The D Series TV's support these functions correctly, however D series BR's do not, even though they are reportedly supported on both B and C series BR's. This has been verified with Samsungs All Share server. There is however a bug in Serviio when attempting to sort the TV menus, which causes the TV to lock up and be repowered. This has been reported as bug #420 https://bitbucket.org/xnejp03/serviio/issue/420/samsung-d-series-tv-hangs-on-menu-sort
Online Files
The Samsung C/D profile 1.6 contained in Serviio Version .6 requires additions to correctly play .mp4 files on the D series. This is detailed and explained in bug report #432 https://bitbucket.org/xnejp03/serviio/issue/432/samsung-c-d-series-on-line-transcoding
When analysing profiles remember that "OnlineTranscoding" rules are inherited by profiles that extend them, while "Transcoding" rules are not, and that the local rules apply to online files as well. That means the C/D profile inherits the OnlineTranscoding rulles from profiles 1 (Generic) and 2 (Samsung B Series), but will override them with any local or online rules in the C/D profile.
YouTube Online
While not exclusive to the D Series, as reported in thread http://forum.serviio.org/viewtopic.php?f=10&t=3601 selecting "high quality" for online playback results in an error when playing resolutions > 1080p. This is due to a bug in youtube.groovy which allows fmt=38 files to be selected. This is reported in bug #431 https://bitbucket.org/xnejp03/serviio/issue/431/youtubegroovy-tries-to-play-formats-1080p and a revised groovy is attached in the thread response.
Unpopulated Online links
Servio repopulates all the online menus with each startup which requires ffmpeg to be run for each menu item. This can take a long time if one has many online links. On my D Series, if a link is opened before it has started to populate (the link url has not been replaced with the link's title), an empty menu will open and you will be kicked out of Serviio with an error message when you attempt to return out of the folder. This has been reported as part of bug #422 https://bitbucket.org/xnejp03/serviio/issue/422/2-stage-online-menu-population which also includes proposals to accelerate the population and/or populate on demand so the crash does not occur.
Convert FLV.txt
Change .txt to .bat
(7.51 KiB) Downloaded 791 times
blue bird
Post Sun Oct 16, 2011 7:27 am
Re: Samsung D Series Summary
hi
i've managed to struggle through setting my samsung D series wi fi blu ray with my mac using serviio but i am now regualarly and for no apparent reason, serviio disconnects during watching a movie... any ideas on how to make it more stable?
Post Sun Oct 16, 2011 2:35 pm
That's a network issue with nothing to do with D series or Serviio, just poor wi-fi...go wired.
Post Mon Oct 17, 2011 3:06 pm
blue bird wrote:hi
a high quality router is always suggested (netgear) and remember to turn all downloads OFF (torrents) on the pc running serviio while your streaming.
Chodberry
Post Fri Jan 06, 2012 1:36 am
i have a Samsung 40D7000. Having assumed I needed to Transcode .MKV files in order for them to play on the Samsung, i enabled Transcoding and had pretty good success with files <10GB.
However a 11GB file with DTS audio just would not play without frequent buffering. Thinking this might be an audio transcoding issue I messed about for a while not not much avail. Then i read the tv manual which suggested the D7000 supported .MKV natively.
So I turned off Transcoding and all worked fine (apart from the file does not seem to list in the 'Movies' video category (can only get to it via 'Folders').
this suggests to me the current (v0.6.1) C/D profile is invalid and needs sorting. Let me know how I can assist should you be interested. 8-)
Cheers,
Chodberry.
Post Fri Jan 06, 2012 1:57 am
Chodberry wrote:Hi,
Cheers,
Chodberry.
profile has NOTHING to do with were files are listed, so you comment is INVALID. you need to correct filename so it can be assigned correct metadata.
read this: http://wiki.serviio.org/doku.php?id=metadata
Post Fri Jan 06, 2012 9:43 am
Cerb, no need to shout, he's asking about transcoding primarily.
OP, can you post ffmpeg -i of the file?
Chodberry
Post Sat Jan 07, 2012 11:23 am
zip wrote:Cerb, no need to shout, he's asking about transcoding primarily.
Here's the ffmpeg output:
  built on Dec 14 2011 01:44:37 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[h264 @ 0x11be400] Increasing reorder buffer to 1
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from '<filename>.mkv':
    title           : <filename>
  Duration: 02:10:26.56, start: 0.000000, bitrate: 11326 kb/s
    Chapter #0.0: start 0.000000, end 178.219000
      title           : (01)00:00:00:000
    Chapter #0.1: start 178.219000, end 381.172000
      title           : (02)00:02:58:219
    Chapter #0.28: start 7826.693000, end 7826.568692
      title           : (29)02:10:26:693
    Stream #0:0: Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16, 1536 kb/s (default)
BTW - the point of my previous post was mainly to suggest (after an ironic case of RTFM on my part) that if the current C/D profile currently Transcodes a file that will play natively, then perhaps it should be modified to not do so?
What would be good to understand is the line items in the current C/D profile that result in this file being Transcoded rather than played natively.
Cheers,
Chodberry
Post Sat Jan 07, 2012 6:55 pm
can you also provide media info output for the file? I think it might be marked as profile > 4.1 which would cause the transcode to kick in.
tokenize
Post Mon Jan 16, 2012 12:18 pm
Hello guys,
I've been using Serviio together with a Samsung UE37D5500 for quite some time now and everything works flawless.
Although, after I updated to 0.6.1, after some time playing *any mkv* file, the audio goes out of sync from the picture. If I do a fast forward of just a few secs, it goes back to normal. And then again, after some time, audio out of sync. A temporary fix for the problem is, as I mentioned, to do a fast forward to sync up the audio again. But of course I'm not happy with this solution.
I can't seem to find the reason for this. Any tips?
Regards
Post Mon Jan 16, 2012 1:45 pm
tokenize wrote:Hello guys,
Regards
this may relate to samsung intergration that got broken in 0.6.1 and is fixed in 0.6.2 wait for it to be release and u should be ok again ( eta soon)
tokenize
Post Thu Jan 19, 2012 6:06 pm
Regards
I downgraded to 0.6.0.1 which had not this problem, but now it does. And because of it, I just realized something, that around the same time I upgraded to 0.6.1 I also upgraded my Samsung TV to firmware 1019 from 1016. Is it possible that the 1019 firmware is responsible for this sync issue?
Regards
Post Thu Jan 19, 2012 6:31 pm
Alot of time sync issues that crop up in a video file after it is played a little is due to a bad video frame and the sound gets off cause the player or transcoding will skip that frame. That is why pausing and restarting fixes it. The audio is resynced.
Look for a program that will key mkv files.
tokenize
Post Thu Jan 19, 2012 6:35 pm
What kind of program is that? Can't seem to find one.
Post Thu Jan 19, 2012 7:12 pm
tokenize wrote:What kind of program is that? Can't seem to find one.
http://wiki.serviio.org/doku.php?id=mkvfix
jivko
Post Wed Feb 01, 2012 8:15 am
Hi all,
I have a 32D6530. I installed serviio a few days ago, it sees the TV but the TV doesn't see the server. When I start AllShare - a message pops up on the TV asking whether to connect to the PC. Nothing happens when I start seriio. I tried using the 3 samsung TV profiles to no avail. Any ideas how to connect?
And my other query - once I get it connected - then where do I go in the smart hub menu to play the files?
Sorry if these have been discussed already in the forum but I couldn't find anything. Thanks.
Post Wed Feb 01, 2012 12:55 pm
You need to do a little more looking and reading. Serviio is a DLNA server and has nothing to do with the Smarthub menu which is a proprietary Samsung interface. Serviio is accessed thru the Video/Photos/Audio menu, as is the Samsung All-Share server. There is lots of forum info on setting up and accessing it. Start by clicking the big SERVIIO at thetop of this page. This has nothing at all to do with the D series TV's.
gormagon
Post Thu Feb 02, 2012 4:14 am
I have moved my post from "samsung" to here as it is a BD-D5100
BD-D5100 .M2TS DTS(HD) (Possible?)
First post. I am trying (via DLNA/Serviio) to play files from a demo disc. The video will play but the audio (DTS-HD) "unsupported ...". Is this possible? How? Profile issue? Player issue? Serviio issue? FFmpeg issue?
MediaInfo
Count                            : 278
Count of stream of this kind     : 1
Kind of stream                   : General
Stream identifier                : 0
Count of video streams           : 1
Count of audio streams           : 1
Video_Format_List                : AVC
Video_Format_WithHint_List       : AVC
Codecs Video                     : AVC
Audio_Format_List                : DTS
Audio_Format_WithHint_List       : DTS
Audio codecs                     : DTS-HD
Complete name                    : V:\Home Theater Demonstration Bluray v2.0\Home Theater Demonstration Bluray v2.0\BDMV\STREAM\00031.m2ts
Folder name                      : V:\Home Theater Demonstration Bluray v2.0\Home Theater Demonstration Bluray v2.0\BDMV\STREAM
File name                        : 00031
File extension                   : m2ts
Format                           : BDAV
Format                           : BDAV
Format/Info                      : Blu-ray Video
Format/Extensions usually used   : m2ts
Commercial name                  : BDAV
Codec                            : BDAV
Codec                            : BDAV
Codec/Info                       : Blu-ray Video
Codec/Extensions usually used    : m2ts
File size                         : 785.6 MiB
Duration                         : 4mn 55s 470ms
Overall bit rate mode            : VBR
Overall bit rate                 : 22.3 Mbps
Maximum Overall bit rate         : 48.0 Mbps
Count                            : 204
Kind of stream                   : Video
Menu ID                          : 1 (0x1)
Format profile                   : High@L4.1
Format settings                  : CABAC / 3 Ref Frames
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3
Internet media type              : video/H264
Codec ID                         : 27
Codec                            : AVC
Codec profile                    : High@L4.1
Codec settings                   : CABAC / 3 Ref Frames
Codec settings, CABAC            : Yes
Codec_Settings_RefFrames         : 3
Bit rate                         : 16.5 Mbps
Maximum bit rate                 : 40.0 Mbps
Width                            : 1920
Height                           : 1080
Pixel aspect ratio               : 1.000
Display aspect ratio             : 1.778
Frame rate                       : 23.976 fps
Frame count                      : 7067
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Interlacement                    : Progressive
Bits/(Pixel*Frame)               : 0.331
Delay                            : 10mn 0s 0ms
Delay, origin                    : Container
Stream size                      : 578 MiB (74%)
Proportion of this stream        : 0.73598
Writing library                  : x264 - core 115 r1995 c1e60b9
Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=1 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=1 / crf=16.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Buffer size                      : 3750000
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Count                            : 169
Kind of stream                   : Audio
Menu ID                          : 1 (0x1)
Format                           : DTS
Format/Info                      : Digital Theater Systems
Commercial name                  : DTS
Format profile                   : MA / Core
Muxing mode                      : Stream extension
Codec ID                         : 134
Codec                            : DTS-HD
Duration                         : 4mn 54s 709ms
Bit rate mode                    : Variable
Bit rate                         : 4956750 / 1509750
Bit rate                         : 4 957 Kbps / 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Channel positions                : 3/2/0.1
Samples count                    : 14146032
Frame count                      : 9210
Resolution                       : 24 bits
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Delay                            : 600000.000
Delay                            : 10mn 0s
Delay                            : 10mn 0s 0ms
Delay                            : 10mn 0s
Delay                            : 00:10:00.000
Delay relative to video          : 0
Video0 delay                     : 0
Player is Samsung BD-D5100
OS is Vista Home Basic
TV is LG 50PV400
Since I first posted i ran a few files (True HD/DTS-HD Audio) through tsremux which extracted the core audio (from 7 channel to 6 channel) and the True HD audio files played but not the DTS files. Would like to know the best way of streaming them.
Any help/pointers would be appreciated.
GoRMaGoN
