[SOLVED] No MKVs are working with Samsung UE46D6500?!
smaxer
Post Sun Oct 16, 2011 2:15 pm
HI Everyone,
I'm having trouble playing any MKV video files with serviio on my Samsung ue46d6500. The Tv recognizes serviio and serviio detects the TV as renderer successfully as: Samsung TV / player (c/d series). I also can play the standard avi files - this worked out of the box, I just added my Video Folder and I didn't change any settings.
Since no MKVs are working I've just picked one as example. Please find attached the metadata. I removed the compression with mkvmerge but it didn't work either...
ffmepg -i file.mkv:
ffmpeg version 0.7.6, Copyright (c) 2000-2011 the FFmpeg developers
  built on Oct  3 2011 13:06:32 with gcc 4.6.1 20110819 (prerelease)
  configuration: --prefix=/usr --enable-libmp3lame --enable-libvorbis --enable-libxvid --enable-libx264 --enable-libvpx --enable-libtheora --enable-postproc --enable-shared --enable-x11grab --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libschroedinger --enable-libopenjpeg --enable-librtmp --enable-gpl --enable-version3 --enable-runtime-cpudetect --disable-debug
  libavutil    50. 43. 0 / 50. 43. 0
  libavcodec   52.122. 0 / 52.122. 0
  libavformat  52.110. 0 / 52.110. 0
  libavdevice  52.  5. 0 / 52.  5. 0
  libavfilter   1. 80. 0 /  1. 80. 0
  libswscale    0. 14. 1 /  0. 14. 1
  libpostproc  51.  2. 0 / 51.  2. 0
[matroska,webm @ 0x819be00] max_analyze_duration 5000000 reached at 5002000
[matroska,webm @ 0x819be00] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'file.mkv':
  Duration: 01:55:38.47, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0: Video: h264 (High), yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: dca (DTS-HD MA), 48000 Hz, 5.1, s16, 1536 kb/s (default)
    Stream #0.2(eng): Subtitle: dvdsub (default)
    Stream #0.3(fre): Subtitle: dvdsub
    Stream #0.4(spa): Subtitle: dvdsub
mkvinfo file.mkv:
+ EBML head
|+ EBML version: 1
|+ EBML read version: 1
|+ EBML maximum ID length: 4
|+ EBML maximum size length: 8
|+ Doc type: matroska
|+ Doc type version: 2
|+ Doc type read version: 2
+ Segment, size 12918212310
|+ Seek head (subentries will be skipped)
|+ EbmlVoid (size: 4043)
|+ Segment information
| + Timecode scale: 1000000
| + Muxing application: libebml v1.2.2 + libmatroska v1.3.0
| + Writing application: mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 20:30:32
| + Duration: 6938.475s (01:55:38.475)
| + Date: Sun Oct 16 12:51:13 2011 UTC
| + Segment UID: 0x42 0xcf 0x48 0x98 0x3b 0xdd 0x4f 0x05 0x0b 0x6f 0x59 0xb1 0x50 0xcf 0x5c 0x2a
|+ Segment tracks
| + A track
|  + Track number: 1
|  + Track UID: 594565278
|  + Track type: video
|  + Lacing flag: 0
|  + MinCache: 1
|  + Codec ID: V_MPEG4/ISO/AVC
|  + CodecPrivate, length 40 (h.264 profile: High @L4.1)
|  + Default duration: 41.708ms (23.976 fps for a video track)
|  + Language: und
|  + Video track
|   + Pixel width: 1920
|   + Pixel height: 816
|   + Display width: 1920
|   + Display height: 816
| + A track
|  + Track number: 2
|  + Track UID: 2632187061
|  + Track type: audio
|  + Codec ID: A_DTS
|  + Default duration: 10.667ms (93.750 fps for a video track)
|  + Audio track
|   + Sampling frequency: 48000
|   + Channels: 6
| + A track
|  + Track number: 3
|  + Track UID: 3379420077
|  + Track type: subtitles
|  + Lacing flag: 0
|  + Codec ID: S_VOBSUB
|  + CodecPrivate, length 348
| + A track
|  + Track number: 4
|  + Track UID: 3841098649
|  + Default flag: 0
|  + Lacing flag: 0
|  + Language: fre
| + A track
|  + Track number: 5
|  + Track UID: 3372616353
|  + Default flag: 0
|  + Lacing flag: 0
|  + Language: spa
|+ EbmlVoid (size: 1180)
|+ Cluster
mediainfo file.mkv:
Unique ID                                : 88805325566220483364810952124348073770 (0x42CF48983BDD44234230B6F59B150CF5C2A)
Complete name                            : file.mkv
File size                                : 12.0 GiB
Duration                                 : 1h 55mn
Overall bit rate                         : 14.9 Mbps
Encoded date                             : UTC 2011-10-16 12:51:13
Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 20:30:32
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 55mn
Bit rate                                 : 13.0 Mbps
Nominal bit rate                         : 11.4 Mbps
Height                                   : 816 pixels
Display aspect ratio                     : 2.35:1
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 10.5 GiB (87%)
Writing library                          : x264 core 112 r1867 22bfd31
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=36 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=11352 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Codec ID                                 : A_DTS
Duration                                 : 1h 55mn
Bit rate                                 : 1 576 Kbps / 1 510 Kbps
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Text #1
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Text #2
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Language                                 : French
Text #3
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Language                                 : Spanish
serviio is used under linux as version 0.6.
Samsung Firmeware: 001014
Post Sun Oct 16, 2011 2:44 pm
Re: No MKVs are working with Samsung UE46D6500?!
Nothing obvious to me. What do you mean by "trouble playing"? Whats the error?
smaxer
Post Sun Oct 16, 2011 2:49 pm
jhb50,
thanks for your reply. The error is "Not supported File Format". This appears instantly, in less than a second. So I don't know if he is even transferring data...
Best,
smax
Post Sun Oct 16, 2011 5:37 pm
What profile does the console say the UE is using?
smaxer
Post Sun Oct 16, 2011 6:37 pm
I'm not sure what you mean but if its the profile column in the Status tab it says: Samsung TV / player (c/d series)
Post Mon Oct 17, 2011 1:10 am
Nothing obvious to me. It should play natively with that profile. Shot in the dark..remux with just the vido and audio..drop the others.
Post Mon Oct 17, 2011 10:17 am
The audio track is DTS-MA, I'm not sure if the TV supports that (or just DTS).
smaxer
Post Mon Oct 17, 2011 8:50 pm
Zip & Jhb50,
Thanks for your support! But for some reason, today every mkv worked - i know this sound ridiculous because I havn't changed anything. The only thing that changed was: I resaterted my PC. Maybe the problem was that I've tested too many dlna servers in one session... I don't know... (I didn't run dlna servers parallel.. but I treid them one after the other... so maybe one didn't shoutdown correctly...
Anyway mkvs are working now! Some need to be transcoded and my PC (laptop) is too slow - but thats not an serviio issue... so I'm think about buying an external media player that is able to play *any* video file I provide. Do you guys know such a device that would also work smoothly with serviio?
Btw: serviio was the only dlna server that worked just out of the box for me so keep up the excellent work!
Best,
smax
Users browsing this forum: Baidu [Spider] and 5 guests
