Re: Problems with MKV / H.264 on Sony BDP-S370 Bluray-Player
viewtopic.php?f=5&t=326&p=3684#p3684
if I save it as a link above, gets
soryy for my language, just started to learn English
2011-10-17 08:11:09,625 INFO [ServiioConsole] Leaving Serviio Console
2011-10-17 08:11:16,796 INFO [MediaServer] ------------------------------------------------------------------------
2011-10-17 08:11:16,796 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-10-17 08:11:16,796 INFO [MediaServer] Petr Nejedly 2009-2011
2011-10-17 08:11:16,796 INFO [MediaServer] http://www.serviio.org
2011-10-17 08:11:16,796 INFO [MediaServer] Java 1.6.0_27-Sun Microsystems Inc.
2011-10-17 08:11:16,796 INFO [MediaServer] OS Windows XP x86 5.1
2011-10-17 08:11:16,796 INFO [MediaServer] File encoding: windows-1250
2011-10-17 08:11:16,796 INFO [MediaServer] Headless mode enabled: true
2011-10-17 08:11:16,796 INFO [MediaServer] User home dir: C:\
2011-10-17 08:11:16,796 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2011-10-17 08:11:16,921 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-10-17 08:11:16,984 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-10-17 08:11:18,281 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.4.a: Invalid content was found starting with element 'X-AV-Client-Info'. One of '{UPnPSearch, HttpHeaders}' is expected.
2011-10-17 08:11:18,281 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
at org.serviio.MediaServer.main(MediaServer.java:105)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:693)
at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:128)
at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:154)
... 7 more
2011-10-17 08:11:20,453 INFO [ServiioConsole] Starting Serviio Console
2011-10-17 08:11:20,531 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-10-17 08:11:27,968 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-10-17 08:11:34,890 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-17 08:11:35,000 INFO [Messages] Loaded console message bundle for locale: en
2011-10-17 08:11:42,031 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-17 08:13:16,125 INFO [ServiioConsole] Leaving Serviio Console
Lowlander wrote: there's a good chance that the xml's format has changed as well.
wicked666 wrote:ok, thanks.
Is there a way to play MKV in S370 without transcoding? Or at least mkv with the original soundtrack of DTS 1.5 MB?
blm wrote:Now I have another problem.. subtitles are "half" working - I think there is a problem with display time of each text - player skips some of the texts. I have checked srt file before muxing and in my opinion is fine.
darisil wrote:I had tried to mux the same .srt in the same .mkv before, but the player didn't show the subs in any media server (don't ask me why). Then I did the following: 1) set to 'yes' the 'Default track flag' and 'Forced track flag' in the srt track; and 2) selected 'none' to 'Compression' under the 'Extra Options' tab for ALL the tracks.
BINGO!! The BDP played the file and showed the subs. But only from PMS, not from Serviio. Furthermore, the same result was observed in my Samsung D6900 TV and PS3, which makes me think Serviio didn't make it happen.
