[SOLVED] serviio 0.6 and 0.6.1 no .avi or HD listing on TV
vinyldj
Post Mon Oct 17, 2011 10:39 am
Problems after serviio update on Sony Bravia KDL32EX503, Ethernet connection.
Versions 0.5 always worked and worked well recently updated to 0.6 could not see any video files, updated to 0.6.1 all worked for one day and now again I can't see any avi files and HD formats - it does however see the odd mpg video and all pictures and music register? profile is set to original Sony Bravia TV.
Ran all the diag on the TV and PC, restarted and reconnected both serviio and the TV network, changed ethernet ports, reinstalled serviio and checked all sharing options, registering as it should. Still no video listing.
Any Help appreciated - reverting back to 0.5.2 hopefully it will work.
Post Mon Oct 17, 2011 10:46 am
Re: serviio 0.6 and 0.6.1 no .avi or HD listing on TV
Could you enable detailed logging (see signature), clean the log file, restart serviio service then post log file here? (hopefully you still have 0.6.1 version installed)
What are your serviio library refresh options?
vinyldj
Post Mon Oct 17, 2011 11:24 am
illico here is the log
Post Mon Oct 17, 2011 12:19 pm
Could you confirm:
192.168.1.65 is PC IP address
192.168.1.73 is the TV IP address "BRAVIA KDL-32EX503"
"Generic DLNA profile" is used with your Bravia TV --> not good
Could you remove all devices in the serviio console, save and restart serviio service?
vinyldj
Post Mon Oct 17, 2011 1:16 pm
Removed all connected devices from list and TV is only device listed on ip 1.73 with Sony Bravia Profile selected.
Post Mon Oct 17, 2011 1:31 pm
vinyldj wrote:Removed all connected devices from list and TV is only device listed on ip 1.73 with Sony Bravia Profile selected.
So, see on log file that "Sony Bravia" profile is used and now all avi files are listed ?
vinyldj
Post Mon Oct 17, 2011 1:36 pm
decided to do full PC restart after removing all devices, serviio has restared with the TV on ip 1.73 and an unrecognised device on 1.65 need to check what this device is on my network but yes all movie files are now listing - thank you.
What went wrong?
vinyldj
Post Mon Oct 17, 2011 1:40 pm
1.65 is the serviio media server (orange)
Post Mon Oct 17, 2011 1:43 pm
vinyldj wrote:1.65 is the serviio media server (orange)
It might be another UPnP device, e.g. WMP on your PC.
Post Mon Oct 17, 2011 2:23 pm
vinyldj wrote:What went wrong?
Don't know!
Do you fix all IP address ?
Probably when you update serviio with previous "serviio library", devices list does not match so you lose profile.
A good cleanup of device list is a solution.
Topic solved.
