Synology and network setup
patters
Post Mon Oct 17, 2011 4:04 pm
Re: Synology and network setup
If you're using my Synology package, you'll find the log at /volume1/@appstore/Serviio/log/serviio.log
It's mentioned on the download page for it:
DSM Package Center installs the application to /volume1/@appstore/Serviio though from what I understand, on multi-volume systems the user is prompted for a destination volume.
ccmgc
Post Tue Oct 18, 2011 9:37 am
Thanks, but i must be being stupid here - but i dont know how to navigate to this,
I dont see the folder appstore in the DSM file browser, and i dont seem to be able to navigate to it with windows browsers.....
Synology DS211J 2TB - Panasonic Viera TX-L42E30B - Netgear Homeplug XAV101 - BT Home Hub 2 - Infinity
patters
Post Tue Oct 18, 2011 8:11 pm
You can't navigate to it in the DSM. It's available by telnet or SSH terminal sessions only.
You'd need to connect, then copy the log to the public folder like so:
cp /volume1/@appstore/Serviio/log/serviio.log /volume1/public
Then you can download it from the public shared folder.
ccmgc
Post Wed Oct 19, 2011 9:06 am
Thank you - your patience is appreciated, all now much clearer - i have some more learning to do :-)
I have the log from the NAS here now
The TV still does not 'see' serviio - and neither does 'Device Spy' - andentering the ip address 192.168.1.50 of the 211j receives the message 'could not load device'
(237.03 KiB) Downloaded 919 times
Post Wed Oct 19, 2011 10:28 am
Did you use 192.168.1.50 as the bound IP address?
ccmgc
Post Wed Oct 19, 2011 3:02 pm
Hello - yes 192.168.1.50 is the bound ip address (in the serviio windows remote console)
serviio windows remote consle does see this ip address as an 'unrecognised device' with orange dot, and the TV ip address red dot, in the Status tab.
ccmgc
Post Wed Oct 19, 2011 7:19 pm
An update - the TV can now 'see' serviio in its media servers list, with a green dot in windows serviio remote console. And i can see photos and navigate to music folders, but nothing at all in the video folders on the TV yet....
Not sure why it is now visible, i dont think that i changed anything.... will leave it indexing.....
ccmgc
Post Fri Oct 21, 2011 5:38 pm
patters wrote:You can't navigate to it in the DSM. It's available by telnet or SSH terminal sessions only.
Thank you for this - newbie question again , new to putty too..... never knowingly used a terminal before...
Looking at plugins now, and i have put the iplayer.groovy file into the synology public folder, but a similar command doesnt mofie it to the serviio/plugins folder - returning a 'cannot create - permission denied' message - i obviously have the sntax incorrectly - but cant find reference to plugins installation on synology here...
Thanks again for your patience.
patters
Post Fri Oct 21, 2011 11:26 pm
I released a new version of my package today. You can upgrade an existing install with it using the Package Centre. The new version will automatically import plugins found in the 'public' shared folder, as yours are.
ccmgc
Post Sat Oct 22, 2011 10:26 am
That should be Serviio 0.6.0.1 v2 on the NAS? - this is the version i have shown now.
patters
Post Sat Oct 22, 2011 5:15 pm
Yeah, I only put that version up yesterday evening.
Since you've already installed it though, if your groovy plugins weren't installed you'll need to copy them via SSH as the user root, using the same password you set for the admin account on your NAS. Then:
cp /volume1/public/*.groovy /volume1/@appstore/Serviio/plugins
chown -R serviio /volume1/@appstore/Serviio/plugins
That second command sets the owner back to the serviio user on those files.
The admin account's privileges aren't as high as root which is why you had that permission error before.
ccmgc
Post Sun Oct 23, 2011 2:45 pm
Thank you - done.
ccmgc
Post Wed Oct 26, 2011 1:31 pm
This morning i experimented and stopped the serviio server embedded on the DS211j from running, and installed serviio as server onto one of the Windows XP machines, and hey presto, the TV see this XP serviio server quickly, finds files, audio video and photo quickly and plays most of them, quickly and cleanly... (from first short look it seems excellent), so the issue with finding the files with the TV and slowness is the embedded NAS implementation of serviio)
I hoped that this NAS embedded solution would be quick and mean that i did not need to have a PC running, but it seems not.
And stopping the embedded serviio running has speeded up other access to unrelated data files on the NAS hugely too.....
When serviio was running on the NAS i did not see excessive (it was 40-60%) CPU or memory useage , but this is now showing as 20-40%
gedno
Post Mon Jan 28, 2013 4:40 pm
i am trying to enter the library location of my synology nas (/volume1/music) but the consle changes it to (for example) c:\\volume1\music. i have no clue how to make the proper connection. do i need to write the nas ip adres on the first tab as boubd adress?
Previous
