Web UI in PHP
mpemberton5
Post Tue Oct 18, 2011 12:31 pm
Re: Web UI in PHP
patters wrote:Thing is, then we get problems with recursive substitution if you then add another feed with the Web UI - resulting in &amp;amp; for the first feed since the data for all feeds is resubmitted via REST.
Did you experience this or was this theory? In my system, the results from getRepositories() returns the actual ampersand symbol and not &amp; which is what was submitted.
patters
Post Tue Oct 18, 2011 4:08 pm
Re: Web UI in PHP
Last night I was testing manually entering feeds using the "&amp;" encoding. The first time they were saved they were added to the database fine, then upon a second edit to the feed list they got broken so I figured it would be similar. Anyhow, the other issue with the simple string swap is that it would mess up URLs that already contain encoded HTML entities (which I expect are fairly common). The solution I arrived at should prevent that.
cburbs
Post Fri Oct 21, 2011 2:16 pm
Re: Web UI in PHP
Another thing I noticed with my install. When I go to Add Local for library my /storage folder doesn't show up in Firefox but does In IE9.
Any reason for this?
patters
Post Sat Oct 22, 2011 11:42 am
Re: Web UI in PHP
I can't personally help with those errors as I find it works for me. My changes to the code are only minor.
Anyway, I've made some more improvements and this is the version I built into my Synology NAS package:
http://dl.dropbox.com/u/1188556/serviio ... -v2.tar.gz
Changes from my last version:
. added Greek language support, using the new translation from the forum
. included the updated 0.6 translations from the forum for Italian and Chinese (simplified and traditional)
. fixed Brazilian Portuguese and Chinese language support (the code was rejecting locale names longer than 2 chars for some reason)
. fixed display of double instances of single quote (apostrophe) characters in the language files. These are escaped for Java, but they are meant to be single (see metadata tab for examples).
. fixed localization for more UI elements (buttons, dropdowns). Still need to do the file requestors though
. improved CSS for button and text alignment to match the fieldset borders.
. improved the Transcoding audio downmixing option spacing
. removed a superfluous </fieldset> tag on the Metadata tab (I think) that was messing up the display in IE.
mpemberton5
Post Sat Oct 22, 2011 1:23 pm
Re: Web UI in PHP
cburbs wrote:Another thing I noticed with my install. When I go to Add Local for library my /storage folder doesn't show up in Firefox but does In IE9.
What version of FF are you using? I just tried with 6.0 and it worked. I also just upgraded to 7.0.1 and that works as well. Do you have any add-on's that might be conflicting with it? Try running FF with all disabled to see what you get.
Post Mon Oct 24, 2011 12:36 pm
Re: Web UI in PHP
Hi all,
I am just beginning to get interested in the web interface in PHP.
So on my Windows XP, I'm using xamp (Apache / MySQL / PHP).
On php.ini, I added "extension=php_curl.dll"
But when I try "localhost/serviio" in Firefox browser, I have errors, for example :
Notice: Use of undefined constant tab - assumed 'tab' in D:\xampp\xampp\htdocs\serviio\index.php on line 40
I'm stupid with php, so this is probably an easy php.ini configuration.
Any idea ?
Post Mon Oct 24, 2011 6:48 pm
Re: Web UI in PHP
Its ok now with Wamp.
Install process:
- Wamp installed on Windows XP Home Edition(C:\wamp)
- Unzip "Web UI in PHP" into "C:\wamp\www\serviio"
- Serviio install version must be the same than Web UI in Php (0.6.0.1)
- php curl extension must be enabled
- On Browser type: http://localhost/serviio/
Neoromancer
Post Tue Nov 01, 2011 12:55 pm
Re: Web UI in PHP
Windows 7 64-bit
Wamp for 64-bit
Serviio 0.6.0.1 and WebUI http://dl.dropbox.com/u/42061/serviio-0.6.0.1.zip
Curl extension enabled
In Status section and Library I get error:
Panasonic TX-P42G20E | Ubuntu server 10.04.3 64-bit | Serviio 0.6.2
Post Wed Nov 02, 2011 9:32 am
Re: Web UI in PHP
Neoromancer wrote:In Status section and Library I get error
On "PHP settings" disable "display errors" and restart wamp services then retry.
Neoromancer
Post Wed Nov 02, 2011 12:21 pm
Re: Web UI in PHP
Ok. Now page loading without errors.
Problem:
I can not make changes. Does not allow editing of content.If I try to remove or add a value and then press buttons Save getting the following error messages in Status "Cannot put status"or in Library "Cannot put repository"
Post Wed Nov 02, 2011 12:38 pm
Re: Web UI in PHP
Neoromancer wrote:Problem:
+1
I have not had time to correct this problem too.
Any ideas?
Xmantium
Post Sun Nov 06, 2011 1:26 pm
Re: Web UI in PHP
Is there any way that php sys info can be integrated on an extra tab, this looks really good and I can see how my linux server is doing while transcoding.
http://sourceforge.net/projects/phpsysinfo/
Post Sun Nov 06, 2011 4:41 pm
Re: Web UI in PHP
Xmantium wrote:Is there any way that php sys info can be integrated on an extra tab, this looks really good and I can see how my linux server is doing while transcoding.
how ironic i was looking for that program for another project im working on thanks for that Xmantium. :D
pepa.sajdler
Post Tue Nov 15, 2011 7:53 pm
Re: Web UI in PHP
My quick dirty fix to forbid access from other IPs than my LAN. I don't really want anyone poking in my Serviio. If you have different LAN setup just change those two IPs
Put at the begining of index.php (but after <?PHP)
$ip=$_SERVER['REMOTE_ADDR'];
$ip_min = ip2long('192.168.0.100');
$ip_max = ip2long('192.168.0.200');
$continue = (ip2long($ip)>=$ip_min) && (ip2long($ip)<=$ip_max) || $ip=='127.0.0.1' || $ip=='::1' ? true:false;
if (!$continue) die ("Your IP is forbidden!");
It might be a bit clumsy - if anyone knows more elegant way let me know. It's been quite some time I did something in PHP...
Edit:
Actually - easier way is to create file .htaccess with:
order deny,allow
deny from all
allow from 192.168.0.
allow from 127.0.0.1
allow from ::1
Still learning ;)
mrfusker
Post Fri Nov 25, 2011 5:06 pm
Re: Web UI in PHP
After I have upgraded the serviio web gui/ui to version 0.6b, I get this white screen after clicking the icon on my synology "desktop".
What is wrong?
patters
Post Sun Dec 04, 2011 10:22 pm
Re: Web UI in PHP
0.6b isn't the current version.
Make sure you have DSM 3.2 build 1955 or 1922 (1944 had problems apparently)
Open Package Center, in Settings add this repository http://pcloadletter.comlu.com and your NAS will automatically show the latest versions of the packages I made.
Also, try rebooting the NAS. It seems that sometimes during an upgrade, the old version doesn't quit properly.
mrfusker
Post Mon Dec 05, 2011 6:35 pm
Re: Web UI in PHP
I will give it a try :)
mrfusker
Post Mon Dec 05, 2011 6:57 pm
Re: Web UI in PHP
After installing JAVA SE for Embedded 6, I get:
Required Serviio 0.6 but found ''
Cannot connect to Serviio server, it does not seem to be running. Exiting...
Rather strange, since ps shows Serviio running ffmpeg
Scouser
Post Tue Dec 06, 2011 5:15 pm
Re: Web UI in PHP
Brilliant!
Got it working on my ReadyNas Pro 6 serving up DLNA to my Panasonic Viera TV.
Really cool.
The only problem I am seeing that every time I start the serviio server from wihin the GUI the library entries are duplicated. So I get multiple copies of the same files listed on the Panasonic. Not sure if this is a serviio problem though.
But great work. This far beats the ReadyDLNA solution.
Scouser
Post Wed Dec 07, 2011 6:19 pm
Re: Web UI in PHP
How do you stop webUI once it is running? Kill -TERM causes it to restart. Adding "-stop" to the java command doesn't seem to do anything....well, sometimes I get java to blow out with an Exception doing this.
