TV LD LG840 youtbe plugin not works
xpto09
Post Tue Oct 18, 2011 8:46 pm
In online services I put the url:
http://gdata.youtube.com/feeds/apl/standarfeeds/top_rated
When I try to play a video, there is the message "invalid file".
However, inside the /tmp I can see a file, for example, transcoding-temp-1000000000090012-MPEG2TS.stf
If I copy it inside the Folders and rename it to transcoding-temp-1000000000090012-MPEG2TS.avi,
I can play it.
I read that "transcoding only works with a specific Render Profile".
The profle is:
   <Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" aCodec="ac3" />
I tried other profiles (I changed the <Detection> to get this), but until now I can not play the youtube videos.
What can I do to solve this?
Post Tue Oct 18, 2011 9:13 pm
Re: TV LD LG840 youtbe plugin not works
The LG devices have problems playing any transcoded (incl online) content because of a bug in their firmware. Not sure if it's all of them, but some definitely do. You might be one affected. We can confirm this by you providing the detailed log of playing the file.
xpto09
Post Tue Oct 18, 2011 11:37 pm
Post Wed Oct 19, 2011 10:51 am
Yep, that's the case where the TV asks for bytes range even though Serviio says it doesn't support it. :(
xpto09
Post Wed Oct 19, 2011 7:04 pm
Could you explain this issue?
1) Serviio gets to download the youtube file and save it like xxxx.stf;
2) Serviio does not get to transcode it.
3) Invalid file.
Then this is a firmware or transcodng problem?
Post Wed Oct 19, 2011 10:16 pm
1) Serviio downloads the file and transcodes to .stf
2) the TV then asks for another chunk of the file, but in an invalid way (for non-existent portion of the file) so Serviio rejects the request
3) TV doesn't try again and stops the playback
-> TV firmware bug
xpto09
Post Wed Oct 19, 2011 10:50 pm
This is very interisiting.
I can play youtube files when I access the Netcast.
Serviio always download all the youtube file.
A stupid question:
Is it possible to serviio rename the files from .sft to .avi?
If it was possible, the tv could play the file!
Post Thu Oct 20, 2011 10:45 am
Extension doesn't matter, the file is not completely written when you start watching. You can of course copy the stf file, rename to .mpg and add it to your library manually and watch it then, but it sucks.
I assume Netcast is LG connected TV app and therefore different kind of fish altogether.
Return to LG
Users browsing this forum: Baidu [Spider] and 3 guests
