Serviio patch for Turnkey linux appliance.
Bertbass
Post Sat Oct 08, 2011 12:01 pm
I hope I have not broken any rules , but I have recently made a serviio patch to install serviio to a turnkey linux appliance .
This patch can then create a full linux iso ready for installation on a bare metal server or a VM .
The patch is available at http://www.turnkeylinux.org/
Much appreciation for all your hard work .
Alex
Samsung 40C6000 ,win7 ,serviio & DLNA fileserver , various linux machines ,virtual machine box , various satellite recievers . and very little spare time .......lol
Post Sat Oct 08, 2011 6:03 pm
Re: Serviio patch for Turnkey linux appliance.
excellent what version of linux is this as i was planning on doing this but you have save me from having to :)
Bertbass
Post Sat Oct 08, 2011 8:16 pm
Turnkey file server and torrent server are using Base distribution: Ubuntu 10.04.1 with Long Term Support until April 2015.
If wanted I will try to upload somewhere completed iso's or the patch can be downloaded from the Turnkey site
Post Sat Oct 08, 2011 8:33 pm
Bertbass wrote:Turnkey file server and torrent server are using Base distribution: Ubuntu 10.04.1 with Long Term Support until April 2015.
looks great not sure about the torrent server ( they dont support the use of illegal file sharing here ) but coupling this with the fileserver looks very promising to me, can you provide an ISO with serviio 0.6 and your turnkey server so it can simply be installed and run out of the box ( webui too would be perfect ), so it can be tested by the team here would be great start i guess.
Bertbass
Post Sat Oct 08, 2011 10:52 pm
Here is a link to download the file server version.
link removed by Bertbass , will be re upped with licence and webui included
The file server version has webmin built in , just needs updating to the latest version.
It also has a Web based file manager .
adding a serviio webui will be the next part the puzzle that needs working on , allthough somebody on this forum has been looking at a java webui which may work well.
Post Sun Oct 09, 2011 3:13 pm
The patch is ok, but keep in mind Serviio has a particular licence which you should probably link to in your readme or the website.
Bertbass
Post Sun Oct 09, 2011 4:45 pm
ok I will include licence in the read me .
Bertbass
Post Sun Oct 09, 2011 5:30 pm
zip wrote:The patch is ok, but keep in mind Serviio has a particular licence which you should probably link to in your readme or the website.
If needed i will remove the link for now , as I am patching the iso with the java webui at the moment and i will re-upload a finished iso with the licence in the readme.
Bertbass
Post Mon Oct 17, 2011 8:38 pm
As promised a new patch including the webui .
http://www.filehosting.org/file/details ... atched.zip
Please let me know if there are any problems and i will try to sort them out if i can.
Neoromancer
Post Tue Oct 18, 2011 12:50 pm
I installed this distro on a virtual machine.I can access Webmin and others, but I do not know how to access Serviio via a URL. What URL should I enter?
Panasonic TX-P42G20E | Ubuntu server 10.04.3 64-bit | Serviio 0.6.2
Bertbass
Post Tue Oct 18, 2011 7:45 pm
try http://xxx.xxx.x.x:8123/serviio/console
enter the ip address given to the iso when first set up , usually on the configuration console at start up eg if webmin is http://192.168.1.1:12321 serviio console will be http://192.168.1.1:8123/serviio/console
it may be beneficial to read this thread: viewtopic.php?f=17&t=2427
Neoromancer
Post Wed Oct 19, 2011 7:14 am
Thanks. Working.
Neoromancer
Post Wed Oct 19, 2011 7:50 pm
Working but not all. I installed to USB, mounted NTFS partition. AVI files play just fine but does not play MKV files. TV show dialog "Pleas wite..." and then "Cannot read file". And so with all the MKV files. Through the web serviio console I selected Panasonic Viera profile. In the future I want to build a home media server, so I would like to solve all the problems now. Maybe there are some ideas on how to solve this problem?
Bertbass
Post Wed Oct 19, 2011 9:33 pm
This is a linux iso and really needs installing either in a virtual machine eg:virtualbox or a bare metal install on an old computer .
I have it working on both and have no problem playing ,mkv ,avi , mp4 , ts ,mp3 music .
Just make sure you have enough memory , minimum 512mb recommended 2gb
I have found using a static ip address for the serviio server in your router does help with the webui.
It also takes a little time for all files to be recognised on first loading , while the database is updated.
Neoromancer
Post Thu Oct 20, 2011 5:47 am
My PC spec.: AMD Athlon X2 3 GHz, 2 GB RAM , Turnkey installed for testing in to 8 GB USB as second OS. From another computer through a Web interface I log into Webmin and then mount the NTFS file system. In Serviio console I made ​​all the necessary settings. After all, and as I mentioned AVI files play fine, but not MKV. My movie collection is not large. Where could be my mistake?
Post Thu Oct 20, 2011 5:55 am
what are you trying to play the mkv on? you might need to customize the profile for the render. Can you post your serviio.log file.
Neoromancer
Post Thu Oct 20, 2011 6:08 am
I am using the Panasonic Viera profile. For example, in Windows 7 with the same profile work ok. My TV is Panasonic TX-P42G20E. TV show dialog "Pleas wite..." and then "Cannot read file". Now I can not give the serviio.log file.
Neoromancer
Post Thu Oct 20, 2011 4:56 pm
Ok. I re-installed Turnkey, mounted NTSF system and tell Serviio stream only 4 diferent files (.m2ts, .mkv, .avi, .mp4). All of these files is working perfectly in Win7 system.
Results:
.m2ts - Play OK
.avi - Play OK
.mp4 - not play
.mkv - not play
.mp4 - not play
I attaching Serviio Log.
turnkey_pc5dczc_log.zip
(4.63 KiB) Downloaded 882 times
kappclark
Post Mon Jan 30, 2012 9:03 pm
Neoromancer wrote:I installed this distro on a virtual machine.I can access Webmin and others, but I do not know how to access Serviio via a URL. What URL should I enter?
Late to this thread -
Are there any updates to this appliance ?? I was going to try on a virtualbox I just built ..
Post Mon Jan 30, 2012 10:20 pm
nope old thread i dont think original poster looks here anymore.
Return to General discussion
Users browsing this forum: Google [Bot] and 24 guests
