INCOMPLETE LIBRARY UPDATE
SnowyB
Post Thu Oct 20, 2011 4:58 am
I am trying to use Serviio with sony 32EX520 TV and D-Link DSM 320 Media Player. I have ticked all the Library boxes as advised in this Forum. I find the audio files all seem to download from the My Music folder OK, but only one Image folder (which shows No Content) has downloaded - there are many more folders in the My Pictures master folder. Can anyone advise what to do? How do you tell that Serviio is actively finding the files requested? (other media servers I have used all seem to show this action as it happens).
Ian
Post Thu Oct 20, 2011 5:36 am
Re: INCOMPLETE LIBRARY UPDATE
you can look at the serviio.log file in the log directory or in the serviio console you can see the status.
SnowyB
Post Thu Oct 20, 2011 10:01 am
That's a help, thanks. But can anyone explain why music files download but not .jpg's?
iAN
Post Thu Oct 20, 2011 10:26 am
what's the resolution of the JPGs? Check the log to see if all your music files have been added, it adds file in the same order you specify them (folders) in the console
SnowyB wrote:That's a help, thanks. But can anyone explain why music files download but not .jpg's?
With the detailed logging file (see signature link) we could probably explain why...
SnowyB
Post Fri Oct 21, 2011 1:24 am
Petr,
Yes, it appears all the music files have downloaded.
The jpg's vary from 10Mpixels down to 250kB. Is there a size limit? I am used to the media server apparently re-sizing for viewing on the TV; at least that's what I think happens as I have not run up against a size restriction before.
Ian
SnowyB
Post Fri Oct 21, 2011 4:57 am
Hi Petr,
Further to above, I have tested using an Image folder containing files no larger than 1920 x 1080 pixels. The Folder is found but no content files get downloaded.
Ian
Post Fri Oct 21, 2011 8:20 am
Did you look at the log?
SnowyB
Post Fri Oct 21, 2011 9:33 am
Yes. I change the log to the DEBUG status. I am not literate in interpreting the log, but a careful reading doesn't seem to show anything resembling my Image files,
Ian
The following is an extract to the point where it seems to be repeating:
2011-10-21 11:57:18,703 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-10-21 11:57:18,718 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-10-21 11:57:18,718 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-10-21 11:57:18,718 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-10-21 11:57:18,718 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-21 11:57:18,718 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-10-21 11:57:18,718 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1319162238718, LastAccessTime = 1319162238718, getTimeToLiveSeconds() = -1, createTime = 1319162238718 ]
2011-10-21 11:57:18,750 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-10-21 11:57:18,750 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-21 11:57:18,750 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-10-21 11:57:18,750 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-21 11:57:18,750 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-10-21 11:57:18,750 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-10-21 11:57:18,750 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-21 11:57:18,750 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-10-21 11:57:18,750 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-10-21 11:57:18,750 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-10-21 11:57:18,750 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-10-21 11:57:18,750 INFO [CompositeCacheConfigurator] Finished configuration in 32 ms.
2011-10-21 11:57:18,765 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-10-21 11:57:18,765 INFO [WebServer] Socket buffer set to 65535 bytes
2011-10-21 11:57:18,765 INFO [Device] Created UPnP Device with UUID: a4c41d51-7d1b-3d26-a28c-f158e84c81bc, bound address: 192.168.0.191
2011-10-21 11:57:18,812 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2011-10-21 11:57:18,812 INFO [PluginCompilerThread] Started looking for plugins
2011-10-21 11:57:18,828 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-10-21 11:57:18,828 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2011-10-21 11:57:19,109 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-10-21 11:57:19,140 INFO [WebServer] WebServer starting on port 8895
2011-10-21 11:57:19,140 DEBUG [DiscoveryManager] UPNP device a4c41d51-7d1b-3d26-a28c-f158e84c81bc (192.168.0.191) is available
2011-10-21 11:57:19,140 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-10-21 11:57:19,140 INFO [EventDispatcher] Starting EventDispatcher
2011-10-21 11:57:19,140 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-10-21 11:57:19,171 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport) and address 192.168.0.191, timeout = 0
2011-10-21 11:57:19,171 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-10-21 11:57:19,171 INFO [RendererSearchSender] Searching for Renderer devices
2011-10-21 11:57:19,296 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport) and address 192.168.0.191, timeout = 0
2011-10-21 11:57:19,296 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport) and address 192.168.0.191, timeout = 0
2011-10-21 11:57:19,312 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-10-21 11:57:19,312 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a4c41d51-7d1b-3d26-a28c-f158e84c81bc
2011-10-21 11:57:19,312 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.191:2111
2011-10-21 11:57:19,484 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.121:55769/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-10-21 11:57:19,484 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer av00:13:46:fe:12:37 from address /192.168.0.121:1024
2011-10-21 11:57:19,500 DEBUG [RendererManager] Adding renderer Renderer [uuid=av00:13:46:fe:12:37, ipAddress=192.168.0.121, name=Wireless Media Player, profileId=1, manuallyAdded=false] to list of active renderers
2011-10-21 11:57:21,125 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-10-21 11:57:21,609 DEBUG [WebServer] Incoming connection from /192.168.0.121:63670
2011-10-21 11:57:21,609 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device a4c41d51-7d1b-3d26-a28c-f158e84c81bc from 192.168.0.121 (headers = [Host: 192.168.0.191:8895,User-Agent: POSIX, UPnP/1.0, Intel MicroStack/1.0.1423])
2011-10-21 11:57:21,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 11:57:21,609 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.0.191:8895,User-Agent: POSIX, UPnP/1.0, Intel MicroStack/1.0.1423]
2011-10-21 11:57:21,812 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-10-21 11:57:22,484 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.121:55769/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-10-21 11:57:22,484 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer av00:13:46:fe:12:37 from address /192.168.0.121:1024
2011-10-21 11:57:24,078 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2011-10-21 11:57:24,078 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-10-21 11:57:24,093 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-10-21 11:57:24,109 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-10-21 11:57:24,156 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-10-21 11:57:24,156 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-10-21 11:57:25,312 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-10-21 11:57:31,125 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport) and address 192.168.0.191, timeout = 0
2011-10-21 11:57:31,125 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a4c41d51-7d1b-3d26-a28c-f158e84c81bc
2011-10-21 11:57:31,718 DEBUG [ActionsServerResource] Action with name 'startServer' was requested
2011-10-21 11:57:32,937 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-10-21 11:57:42,953 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport) and address 192.168.0.191, timeout = 0
Post Fri Oct 21, 2011 9:55 am
That would probably be earlier/later in the log. Try to rename an image file and check the log then (after like 5 mins)
SnowyB
Post Fri Oct 21, 2011 11:39 am
Hi Petr,
It's working!
Log is:
startIndex = 49, count = 1, sortCriteria =
2011-10-21 21:35:19,156 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 143
2011-10-21 21:35:19,156 DEBUG [ImageDAOImpl] Retrieving list of images for folder 143 (from=49, count=1)
2011-10-21 21:35:19,171 DEBUG [FolderDAOImpl] Reading a Folder (id = 143)
2011-10-21 21:35:19,171 DEBUG [ImageDAOImpl] Reading an Image (id = 1114)
2011-10-21 21:35:19,171 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1114 and profile Generic DLNA profile
2011-10-21 21:35:19,171 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file 02_08_09_6 x 4 050.jpg
2011-10-21 21:35:19,171 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 170)
2011-10-21 21:35:19,171 DEBUG [FolderDAOImpl] Getting number of IMAGE sub-folders and media items in folder 143
2011-10-21 21:35:19,171 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-10-21 21:35:19,187 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-10-21 21:35:20,671 DEBUG [WebServer] I/O error: Connection reset
2011-10-21 21:35:20,671 DEBUG [WebServer] Incoming connection from /192.168.0.121:1142
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] GET /resource/1136/MEDIA_ITEM/JPEG_LRG$0 HTTP/1.0, headers = [Host: 192.168.0.191:8895,Range: bytes=0-,User-Agent: dma/1.0 redsonic]]
2011-10-21 21:35:20,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] Request for resource 1136 and type 'MEDIA_ITEM' received
2011-10-21 21:35:20,671 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1136 (local)
2011-10-21 21:35:20,671 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1136)
2011-10-21 21:35:20,671 DEBUG [ImageDAOImpl] Reading an Image (id = 1136)
2011-10-21 21:35:20,671 DEBUG [ImageDeliveryEngine] Delivering item '1136' for client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:20,671 DEBUG [ImageDeliveryEngine] Delivering file '02_10_09_6 x 4 072.jpg' in native format
2011-10-21 21:35:20,671 DEBUG [MediaItemDAOImpl] Getting file of media item 1136
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 644941
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-21 21:35:20,671 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: image/jpeg,Content-Range: bytes 0-644940/644941,Content-Length: 644941,Date: Fri, 21 Oct 2011 11:35:20 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-10-21 21:35:25,171 DEBUG [WebServer] Incoming connection from /192.168.0.121:56143
2011-10-21 21:35:25,171 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.121:
2011-10-21 21:35:25,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 21:35:25,218 DEBUG [WebServer] I/O error: Connection reset
2011-10-21 21:35:25,234 DEBUG [WebServer] Incoming connection from /192.168.0.121:1143
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] GET /resource/1263/MEDIA_ITEM/JPEG_LRG$0 HTTP/1.0, headers = [Host: 192.168.0.191:8895,User-Agent: dma/1.0 (http://www.redsonic.com/dma)]]
2011-10-21 21:35:25,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] Request for resource 1263 and type 'MEDIA_ITEM' received
2011-10-21 21:35:25,250 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1263 (local)
2011-10-21 21:35:25,250 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1263)
2011-10-21 21:35:25,250 DEBUG [ImageDAOImpl] Reading an Image (id = 1263)
2011-10-21 21:35:25,250 DEBUG [ImageDeliveryEngine] Delivering item '1263' for client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:25,250 DEBUG [ImageDeliveryEngine] Delivering file '02_17_13_6 x 4 199.jpg' in native format
2011-10-21 21:35:25,250 DEBUG [MediaItemDAOImpl] Getting file of media item 1263
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 367556
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-21 21:35:25,250 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 367556,Date: Fri, 21 Oct 2011 11:35:25 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-10-21 21:35:25,250 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-10-21 21:35:25,250 DEBUG [WebServer] Incoming connection from /192.168.0.121:1144
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] GET /resource/1263/MEDIA_ITEM/JPEG_LRG$0 HTTP/1.0, headers = [Host: 192.168.0.191:8895,Range: bytes=0-,User-Agent: dma/1.0 redsonic]]
2011-10-21 21:35:25,265 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] Request for resource 1263 and type 'MEDIA_ITEM' received
2011-10-21 21:35:25,265 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1263 (local)
2011-10-21 21:35:25,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1263)
2011-10-21 21:35:25,265 DEBUG [ImageDAOImpl] Reading an Image (id = 1263)
2011-10-21 21:35:25,265 DEBUG [ImageDeliveryEngine] Delivering item '1263' for client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:25,265 DEBUG [ImageDeliveryEngine] Delivering file '02_17_13_6 x 4 199.jpg' in native format
2011-10-21 21:35:25,265 DEBUG [MediaItemDAOImpl] Getting file of media item 1263
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 367556
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-21 21:35:25,265 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: image/jpeg,Content-Range: bytes 0-367555/367556,Content-Length: 367556,Date: Fri, 21 Oct 2011 11:35:25 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-10-21 21:35:25,390 DEBUG [ContentDirectory] Browse() called for renderer Wireless Media Player (profile 1) with parameters: objectID = I_F#FOL_R8$F143, browseFlag = BrowseDirectChildren, filter = *, startIndex = 79, count = 1, sortCriteria =
2011-10-21 21:35:25,390 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 143
2011-10-21 21:35:25,390 DEBUG [ImageDAOImpl] Retrieving list of images for folder 143 (from=79, count=1)
2011-10-21 21:35:25,406 DEBUG [FolderDAOImpl] Reading a Folder (id = 143)
2011-10-21 21:35:25,406 DEBUG [ImageDAOImpl] Reading an Image (id = 1144)
2011-10-21 21:35:25,406 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1144 and profile Generic DLNA profile
2011-10-21 21:35:25,406 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file 02_10_14_6 x 4 080.jpg
2011-10-21 21:35:25,406 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 200)
2011-10-21 21:35:25,406 DEBUG [FolderDAOImpl] Getting number of IMAGE sub-folders and media items in folder 143
2011-10-21 21:35:25,406 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-10-21 21:35:25,406 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-10-21 21:35:26,125 DEBUG [WebServer] I/O error: Connection reset
2011-10-21 21:35:26,125 DEBUG [WebServer] Incoming connection from /192.168.0.121:1145
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] GET /resource/1263/MEDIA_ITEM/JPEG_LRG$0 HTTP/1.0, headers = [Host: 192.168.0.191:8895,Range: bytes=0-,User-Agent: dma/1.0 redsonic]]
2011-10-21 21:35:26,125 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.121
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] Request for resource 1263 and type 'MEDIA_ITEM' received
2011-10-21 21:35:26,125 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1263 (local)
2011-10-21 21:35:26,125 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1263)
2011-10-21 21:35:26,125 DEBUG [ImageDAOImpl] Reading an Image (id = 1263)
2011-10-21 21:35:26,125 DEBUG [ImageDeliveryEngine] Delivering item '1263' for client 'IPAddress=/192.168.0.121, Profile=Generic DLNA profile'
2011-10-21 21:35:26,125 DEBUG [ImageDeliveryEngine] Delivering file '02_17_13_6 x 4 199.jpg' in native format
2011-10-21 21:35:26,125 DEBUG [MediaItemDAOImpl] Getting file of media item 1263
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 367556
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-21 21:35:26,125 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: image/jpeg,Content-Range: bytes 0-367555/367556,Content-Length: 367556,Date: Fri, 21 Oct 2011 11:35:26 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
What has changed? Do I need to do anything in the future?
Many thanks for your perseverance,
Ian
Post Fri Oct 21, 2011 1:34 pm
Not sure ;-) Maybe it just took some time. In the log it only shows browsing for files, not file additions.
klaus_moers
Post Mon Nov 07, 2011 5:01 pm
I also have a problem with the update information on file. I use a Sony BDV-E 380 device and connected to serviio. But when I add files, they do not appear. Also the button force refresh is not applicable. When I push the button show status I never see green lights. For me very complicated to understand. Also did not find documentation. Any ideas for me?
Post Mon Nov 07, 2011 5:12 pm
Read the FAQ: http://www.serviio.org/component/content/article/21#q5
Also the HOWTO documents in Support forum
Return to User experiences
