New D Series Samsung
Post Thu Oct 20, 2011 9:57 pm
Re: New D Series Samsung
Try adding this to the 7.- Samsung C/D profile after </Transcoding>
<OnlineTranscoding>
        <Matches container="mp4"/>
    <Audio targetContainer="mp3">
        <Matches container="flv"/>
    </Audio>
</OnlineTranscoding>
this will override the B profile rule which is screwing up the medium file transcoding.
luigui
Post Fri Oct 21, 2011 1:55 pm
jhb50 wrote:Try adding this to the 7.- Samsung C/D profile after </Transcoding>
<OnlineTranscoding>
    </Audio>
Yes, I already had that code in my profiles.xml file, and didn't work.
Post Fri Oct 21, 2011 11:27 pm
OK. Step by Step.
1. Click on link
2. Menu should open showing all the you tube clips
3. Click on Clip
4. Clip should play.
I take it you get to #4 and it says Invalid File format.
Things to do.
1. Stop Serviio,
2. Delete C:\Program Files (x86)\Serviio\log\serviio.log
3. Start serviio and do the above 4 steps.
4. Stop Serviio and post the log as an attached file to your response.
5. OpenC:\Windows\Temp\Serviio\
6. You should see something like "transcoding-temp-4674-MPEG2TS.stf as the latest file.
7. Copy this file to somewhere and rename it to .mpg
8. Play it to ensure it is the YouTube clip.
9. Run ffmpeg -i and Mediainfo against it and post the results in your reply.
This should give us the info needed to identify your problem.
luigui
Post Sat Oct 22, 2011 10:00 am
I attach the serviio.log and profiles.xml files, and I think that the problem is this ("Video xxx does not match any supported DLNA profile"):
2011-10-22 11:45:46,331 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Video http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=907518%2C914055%2C916700%2C912603%2C910206&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=135FB10108107576BCF69FB978CD5E1B8FC007DE.73EF40B1FE080B6A1F2989543457237BF7BC4097&source=youtube&expire=1319299200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlJUV19FSkNOMF9KTkFDOk9KSHdxX1llVTdB&id=8f9fb22a10ddeb8b [b]does not match any supported DLNA profile[/b]
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: Video http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=907518%2C914055%2C916700%2C912603%2C910206&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=135FB10108107576BCF69FB978CD5E1B8FC007DE.73EF40B1FE080B6A1F2989543457237BF7BC4097&source=youtube&expire=1319299200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlJUV19FSkNOMF9KTkFDOk9KSHdxX1llVTdB&id=8f9fb22a10ddeb8b does not match any supported DLNA profile
   at org.serviio.dlna.MediaFormatProfileResolver.resolveVideoFormat(MediaFormatProfileResolver.java:106)
   at org.serviio.dlna.MediaFormatProfileResolver.resolve(MediaFormatProfileResolver.java:48)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:71)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveOriginalMediaInfo(VideoDeliveryEngine.java:37)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:109)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:152)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:122)
Finally, the serviio temp path is empty. Is this normal?
Thanks for your support!!
Just to show my profiles selection in Serviio console
profiles.xml
To check my profiles.xml with OnlineTranscoding modification
(55.18 KiB) Downloaded 935 times
Serviio.log when playing youtube online feeds (INFO level)
(16.16 KiB) Downloaded 693 times
Post Sat Oct 22, 2011 12:59 pm
It looks like you never even got to the menu of videos .. #2 above.
Also, was http://gdata.youtube.com/feeds/api/standardfeeds/top_rated
the only feed you had setup or are there others? If so what were they?
The url that failed http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=907518%2C914055%2C916700%2C912603%2C910206&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=135FB10108107576BCF69FB978CD5E1B8FC007DE.73EF40B1FE080B6A1F2989543457237BF7BC4097&source=youtube&expire=1319299200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlJUV19FSkNOMF9KTkFDOk9KSHdxX1llVTdB&id=8f9fb22a10ddeb8b is not part of any of the youtube videos in the top-rated feed so you must have asked for something else. I've never seen "tiws" in a yt link before.
2011-10-22 11:44:34,187 INFO  [PluginCompilerThread] Added plugin YouTubeUrlExctractor (Youtube.groovy)
2011-10-22 11:44:41,254 INFO  [Messages] Loaded console message bundle for locale: en
2011-10-22 11:44:41,364 INFO  [UpdateChecker] Checking if a new version is available
2011-10-22 11:44:48,181 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-10-22 11:44:48,555 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
2011-10-22 11:45:00,117 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-10-22 11:45:46,331 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Video http://o-o.preferred.tiws-par1.v17.lscache2.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=907518%2C914055%2C916700%2C912603%2C910206&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=135FB10108107576BCF69FB978CD5E1B8FC007DE.73EF40B1FE080B6A1F2989543457237BF7BC4097&source=youtube&expire=1319299200&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlJUV19FSkNOMF9KTkFDOk9KSHdxX1llVTdB&id=8f9fb22a10ddeb8b does not match any supported DLNA profile
luigui
Post Sat Oct 22, 2011 5:28 pm
Yes, I did all the steps, and I only have the youtube top rated feeds to test (on other feeds and no other local files in library). I think that the "tiws" server of youtube it's not the problem, because I have used an sniffer while watching a youtube video in my computer, and that is the internal host used to get the video.
I did the test again, with full debug option in the log, and I watch another important thing... the videos are in the format "AVC_TS_MP_SD_AC3_ISO" ¿?
I copy the line and the full log:
2011-10-22 19:20:32,261 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000050002, format AVC_TS_MP_SD_AC3_ISO and profile Samsung TV / player (C/D-series)
Any ideas?
Serviio debug log file
(203.33 KiB) Downloaded 753 times
Post Sat Oct 22, 2011 7:27 pm
That is a better log and as far as I can see everythng is OK until the TV says it cannot handle that AVC_TS_MP_SD_AC3_ISO format.
That does not make sense since that is a standard format supported by Samsung D series TV's. I can't give you any more help than that. What exactly is your complete model number?
luigui
Post Sun Oct 23, 2011 7:26 am
jhb50 wrote:That is a better log and as far as I can see everythng is OK until the TV says it cannot handle that AVC_TS_MP_SD_AC3_ISO format.
My complete model number is UE40D8000YSXXC. The weird thing is that the format AVC_TS_MP_SD_AC3_ISO seems to be supported by the TV when I use the UPnP tool. I attach the GetProtocolInfo result.
GetProtocolInfo.txt
UPnP formats supported
(16.94 KiB) Downloaded 795 times
Post Sun Oct 23, 2011 1:47 pm
My model is PN64-D550 and my protocol info is identical to yours, so at least it looks like all the D series are the same.
Post Mon Oct 24, 2011 9:04 am
This problem is related to the fact the file includes codecs that together don't present a valid DLNA format, even after transcoding. If you can still reproduce it you have to get the URL (rtmp://...) from the log and try running
ffmpeg -i "rtmp:/....... svfWfy=1"
Post Mon Oct 24, 2011 2:30 pm
Hi Zip..help me learn here..
1. how do you know it is an rtmp...swf url. I see nothing in his logs.
2, Secondly this is a standard Youtube link, which your groovy would have scraped. I've not seen any rtmp links for the standard formats. Maybe yt uses them in other regions. I cannot access his video link from here, but I've not seen yt use anything but valid sets of codecs in .flv or .mp4 containers.
3. Lastly, I think his log shows a previous success with that video
2011-10-22 19:20:18,291 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000050002 and profile Samsung TV / player (C/D-series)
2011-10-22 19:20:18,291 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://o-o.preferred.tiws-par1.v21.lscache1.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=903114%2C908525%2C913527%2C910206&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=96AB7BE2C678A3AAADE93AF75699B1072A2DC69E.784ED385636BA09252B2F461B4631B902E65A98F&source=youtube&expire=1319328000&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlNNVl9FSkNOMF9LR1pBOmNIWkRjUXdLZ1JR&id=290eb3afa9023e3f: AVC_TS_MP_SD_AC3_ISO
And then a failure. How can that be?
2011-10-22 19:20:32,263 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Video http://o-o.preferred.tiws-par1.v21.lscache1.c.youtube.com
Post Mon Oct 24, 2011 2:55 pm
Sorry, my mistake, of course this is not rtmp.
I think it's because the feed expired in between these 2 operations:
2011-10-22 19:20:18,454 DEBUG [OnlineLibraryManager] Feed http://gdata.youtube.com/feeds/api/standardfeeds/top_rated expired, will reload it
therefore ID 1000000000050002 now represents a different file (URL).
It seems it expires very often though, maybe a bug in the plugin?
2011-10-22 19:20:22,849 DEBUG [FeedItemUrlExtractor] YouTubeUrlExctractor: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://o-o.preferred.tiws-par1.v2.lscache4.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Csource%2Calgorithm%2Cburst%2Cfactor%2Ccp&fexp=904542%2C916700&algorithm=throttle-factor&itag=34&ip=79.0.0.0&burst=40&sver=3&signature=B932C7E488A4BBC19C0B773E3B07B9D0908D3FDA.486A1BBF11FA2D0255C17A228EC600C9109B629D&source=youtube&expire=1319328000&key=yt1&ipbits=8&factor=1.25&cp=U0hQTlNNVl9FSkNOMF9LR1pBOndfd2tfa2FUZmVB&id=b781ff66887b1b90, thumbnailUrl=http://i1.ytimg.com/vi/t4H_Zoh7G5A/default.jpg, expiresOn=Sat Oct 22 17:00:00 PDT 2011, expiresImmediately=false]
This runs at 2011-10-22 19:20:22,849 (what time zone?) and it expires at Sat Oct 22 17:00:00 PDT 2011. The latter date must be after the first date, I'm not sure if that's true (the MOD has to confirm which time zone he's in)
Post Tue Oct 25, 2011 12:03 am
luigui, are you still having problems?
Post another log if you are.
What quality and feed expiry interval is set in your console?
Please also post what timezone you are in.
zip: he started posting on the 20th, so perhaps this expiry problem is different from his original failure, or perhaps he has set a short expiry in the console. I've had no problems with the YT feeds
luigui
Post Tue Oct 25, 2011 7:54 pm
jhb50 wrote:luigui, are you still having problems?
Now it's working!! Reading your tips about the dates and timezones, I realized that the time of my computer changed frecuently. Today I replaced the battery of the motherboard, and serviio it's working!! Not 100% of the youtube videos, some give me the invalid format error, but most of them play well.
Guys, thank you for your support!! I attach the serviio.log when all goes well.
serviioOk.log
(170.39 KiB) Downloaded 718 times
turnig56
Post Tue Dec 06, 2011 3:57 am
Here is a file that does not work with D:
The.Smurfs.2011.1080p.MKV.x264.AC3.DTS.NL.Subs.EE.Rel.NL
willsenaaa
Post Thu Dec 29, 2011 11:31 pm
I have a new d series Samsung t.v and they did all the steps, and i only have the you tube top rates feed to test. that the server of you tube it's not the problem. because i have used an sniffer while watching a you tube video in my computer, and that is the internal host used t get the video.
Previous
Return to General discussion
