No video on MKVs
marculos
Post Sat Oct 22, 2011 3:09 pm
No video on MKVs
I decided this is worth a new thread, looks like issue with stuttering MKVs is resolved, next issue is some MKVs play with no video, maybe issue with the resolution of the MKV ? Some play with no video at all whilst other have weird blocks of colour, is there a recommended open source reauthoring tools for MKVs ? Any idea would be appreciated on how to resolve this one ..
marculos
Post Sat Oct 22, 2011 3:12 pm
Re: No video on MKVs
Media info screenshot
Post Sat Oct 22, 2011 4:03 pm
Please, with MediaInfo, could you select "text" view, copy and past result here?
marculos
Post Sat Oct 22, 2011 9:50 pm
Unique ID : 249192527498720632825909825989821600687 (0xBB78BC2D123CED25A933B978BF0013AF)
Complete name : E:\Media\Videos\Films\Transporter.3.mkv
Format : Matroska
Format version : Version 1
File size : 7.92 GiB
Duration : 1h 43mn
Overall bit rate : 10.9 Mbps
Movie name : Transporter 3 (2008) - Release for HDCLUB
Encoded date : UTC 2009-03-07 12:31:11
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 43mn
Bit rate : 8 409 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.504
Stream size : 5.95 GiB (75%)
Title : Release for HDCLUB
Writing library : x264 core 67 r1120M 8544346
Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=0 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=8409 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Language : English
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 1h 43mn
Bit rate mode : Constant
Bit rate : 755 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 561 MiB (7%)
Title : DTS 5.1 @ 768 kbps
Language : Russian
Audio #2
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 1h 43mn
Bit rate : 1 510 Kbps
Channel(s) : 7 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Stream size : 1.10 GiB (14%)
Title : DTS 5.1 @ 1536 kbps
Language : English
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : A_AC3
Duration : 1h 43mn
Bit rate : 224 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 167 MiB (2%)
Title : AC3 5.1 @ 224 kbbs - Комментарии
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Russian
Text #2
Format : UTF-8
Language : English
marculos
Post Tue Oct 25, 2011 11:45 am
Am I right in thinking for MKVs the resolution must ve 1280 x 720 or 1920 x 1080 for them to play on the Bravia ? It seems most of my MKVs play with no video, I used Win FF to convert a MKV to MP4 with 1280 x 720 resolution and it plays fine .. if this is the case, any recommened software to change MKV resolution , I have tried handbrake but doesnt seem possible to change resolution. Thanks
marculos
Post Thu Oct 27, 2011 9:16 am
I have found a great tool called RipBot264. If I reencode the video with 1920 x 1280, or 1280 x 720 then I can play them on my bravia, happy days !
