iptv.ORF.at (Austria only)
Ger-sh-win
Post Sat Oct 01, 2011 10:22 am
A plugin for http://iptv.orf.at/ (Austria only).
Feed path:
http://rss.orf.at/iptv.xml
Orf.groovy
(2.04 KiB) Downloaded 1569 times
muszaj
Post Fri Oct 14, 2011 9:57 am
Re: iptv.ORF.at (Austria only)
Thanks for this, working perfectly!
Panasonic Viera D25
sucka_punch
Post Sun Oct 23, 2011 6:44 am
Thank you.
Is it possiblie to limit the number of videos to the newest 10 or 15 by using parameters?
sucka_punch
Post Sun Oct 23, 2011 8:21 am
The videos in this feed aren't supported by Playstation 3 and Panasonic Viera TX-L32DT30E.
muszaj
Post Sun Oct 23, 2011 11:05 am
Hi sucka punch,
I think my Viera L32D25 should be identical to your TV; ORF IPTV works for me.
Have you tried using Samsung C/D profile?
Panasonic Viera D25
sucka_punch
Post Sun Oct 23, 2011 11:45 am
How can is set up or change to Samsung C/D profile? Is this an encoding profile?
muszaj
Post Sun Oct 23, 2011 3:49 pm
This is a renderer profile;
you can set is on Serviio console status window to "Samsung TV / Player (C/D-series)".
If this works for ORF iptv, I suggest adding this to your profiles.xml, so the advantages of Panasonic profile will remain,
and you'll be able to watch ORF iptv:
<Profile id="21" name="Panasonic Viera 2" extendsProfileId="1">
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<!-- Remux all h264 video to MPEG-TS stream -->
<!-- unsupported codecs will be transcoded into mpeg-ts,
mpeg2 video and ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video"
targetACodec="ac3">
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<Audio targetContainer="mp3">
<Matches container="mp4" />
<Matches container="flac" />
</Audio>
<OnlineTranscoding>
<Video targetContainer="mpeg" targetVCodec="mpeg2video"
targetACodec="ac3" aBitrate="384">
<Matches container="mp4"/>
<Matches container="flv"/>
</Audio>
</OnlineTranscoding>
After adding this to your profiles.xml and restarting Serviio choose "Panasonic Viera 2" as profile.
Good luck! :)
Panasonic Viera D25
sucka_punch
Post Sun Oct 23, 2011 4:46 pm
Okay thank you.
With the Samsung profiles the videos now play on my Panasonic.
But if i add the code you 've posted to the profiles.xml Servio doesn't start anymore. Maybe i'm doing something wrong there?
muszaj
Post Sun Oct 23, 2011 5:34 pm
I'm glad you got it working now.
Profile:
At the very end of profiles.xml there is a </Profiles> tag; you need to past the code right before it,
otherwise Serviio won't start.
Just to be sure I attached my profile, try to replace your profile.xml with this one in case Serviio still doesn't start,
and use "Panasonic 2"
profiles.xml
My profile
(57.21 KiB) Downloaded 1172 times
Panasonic Viera D25
sucka_punch
Post Tue Oct 25, 2011 11:41 am
muszaj wrote:I'm glad you got it working now.
Profile:
Thanks a lot. I gonna tried it.
Return to Available plugins
Users browsing this forum: Bing [Bot] and 26 guests
