Server 0.4.1 stops responding after a while
stephendhill
Post Sun Jul 18, 2010 9:30 am
For some reason Serviio stops responding after a while. Both of my DLNA clients see this (Evoke Pure and Sammy B650). I have found that using the console to stop and start the server gets it working again. This problem never occurred on v0.4.0.
Looking in the log I see (which may or may not be related):
2010-07-08 19:25:13,060 INFO [EventDispatcher] Starting EventDispatcher
2010-07-08 19:25:21,088 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-07-08 19:25:22,004 WARN [LibraryAdditionsCheckerThread] Cannot read metadata for file 05 Soul Suckin' Jerk.mp3. Message: Cannot check if media item exists: 05 Soul Suckin' Jerk.mp3
org.serviio.db.dao.PersistenceException: Cannot check if media item exists: 05 Soul Suckin' Jerk.mp3
at org.serviio.library.dao.MediaItemDAOImpl.isMediaItemPresent(MediaItemDAOImpl.java:89)
at org.serviio.library.service.MediaService.isMediaPresentInLibrary(MediaService.java:36)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:147)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:132)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:78)
Caused by: java.sql.SQLTransactionRollbackException: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
Lock : TABLE, FOLDER, Tablelock
Waiting XID : {18527436, IS} , APP, SELECT media_item.file_name as file_name, media_item.folder_id as folder_id, repository.folder as root_folder FROM media_item, repository, folder WHERE folder.id = media_item.folder_id AND repository.id = folder.repository_id AND media_item.file_name = ?
Granted XID : {18527437, IX}
Lock : TABLE, MEDIA_ITEM, Tablelock
Waiting XID : {18527437, X} , APP, DELETE FROM folder WHERE id = ?
Granted XID : {18527436, IS}
. The selected victim is XID : 18527436.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown Source)
at org.serviio.library.dao.MediaItemDAOImpl.isMediaItemPresent(MediaItemDAOImpl.java:68)
... 5 more
Caused by: java.sql.SQLException: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
... 15 more
Caused by: ERROR 40001: A lock could not be obtained due to a deadlock, cycle of locks and waiters is:
at org.apache.derby.impl.services.locks.Deadlock.buildException(Unknown Source)
at org.apache.derby.impl.services.locks.ConcurrentLockSet.lockObject(Unknown Source)
at org.apache.derby.impl.services.locks.AbstractPool.lockObject(Unknown Source)
at org.apache.derby.impl.services.locks.ConcurrentPool.lockObject(Unknown Source)
at org.apache.derby.impl.store.raw.xact.RowLocking2.lockContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseContainerHandle.useContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.xact.Xact.openContainer(Unknown Source)
at org.apache.derby.impl.store.access.conglomerate.OpenConglomerate.init(Unknown Source)
at org.apache.derby.impl.store.access.heap.Heap.openScan(Unknown Source)
at org.apache.derby.impl.store.access.RAMTransaction.openScan(Unknown Source)
at org.apache.derby.impl.store.access.BackingStoreHashTableFromScan.<init>(Unknown Source)
at org.apache.derby.impl.store.access.RAMTransaction.createBackingStoreHashtableFromScan(Unknown Source)
at org.apache.derby.impl.sql.execute.HashScanResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.JoinResultSet.openRight(Unknown Source)
at org.apache.derby.impl.sql.execute.JoinResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 9 more
2010-07-08 19:25:26,222 INFO [LibraryUpdatesCheckerThread] Removing 'Caprica.S01E00.Pilot' from Library
2010-07-14 20:18:53,324 INFO [UpdateChecker] Checking if a new version is available
2010-07-14 20:19:25,660 INFO [WebServer] WebServer shutting down
2010-07-14 20:19:25,661 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2010-07-14 20:19:25,661 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-07-14 20:19:25,662 INFO [EventDispatcher] Leaving EventDispatcher
2010-07-14 20:19:25,819 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-07-14 20:19:27,177 INFO [Device] Created UPnP Device with UUID: 539f0fb7-eebe-3300-8eec-48caabf3c39a, bound address: 192.168.10.2
2010-07-14 20:19:27,184 INFO [WebServer] WebServer starting on port 8895
2010-07-14 20:19:27,209 INFO [EventDispatcher] Starting EventDispatcher
2010-07-14 20:19:27,223 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-07-14 20:19:27,235 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.10.2
2010-07-14 20:19:27,236 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-07-17 15:48:30,626 WARN [OutputTextReader] Error reading output of an external command:Bad file descriptor
2010-07-17 15:48:37,595 INFO [LibraryAdditionsCheckerThread] Added file 'Nanny McPhee And The Big Bang.mkv' to Library
2010-07-17 16:35:42,215 WARN [ProcessExecutor] Process ffmpeg has a return code of 134! This is a possible error.
2010-07-17 16:35:42,576 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Avid Serviio user
Pure Flow One | Samsung LE40B650 | Samsung UE40F6320 | Sony PS3 | Ubuntu 14.04
Post Sun Jul 18, 2010 10:11 am
Re: Server 0.4.1 stops responding after a while
What do you mean by that? The TV cannot see it anymore?
stephendhill
Post Mon Jul 19, 2010 7:54 am
Yes. Both my Sammy and Evoke Pure cannot see it.
Avid Serviio user
Brammers
Post Sat Jul 24, 2010 8:04 am
I too have this issue from my Sony S370 Blu-ray player.
Pressing "Stop server" and then "start server" from the console brings it back to life immediately.
Serviio 0.4.1 running on W7 x64, Java 1.6.0_20. Wired LAN between S370 and PC.
J
Brammers
Post Fri Jul 30, 2010 7:05 am
I have managed to capture my (this?) issue in debug-level logs, unfortunately I don't know what I'm looking for.
The logs I have run from service startup (at around 7 am) until it failed to stream a file at 7pm, when I did a stop-start from a remote console and then streamed a file just fine. All this is in the logs. 61MB of them (2mb RARed).
If you would like them zip, drop me a message (or reply) and I'll email them.
I do get a lot of these though which don't look good:
2010-07-29 08:21:03,953 WARN [LibraryUpdatesCheckerThread] Cannot search for updated metadata for title Avalanche!. Message: null
at org.serviio.library.metadata.extractor.embedded.EmbeddedMetadataExtractor.isMetadataUpdated(EmbeddedMetadataExtractor.java:82)
at org.serviio.library.metadata.LibraryUpdatesCheckerThread.searchForRemovedAndUpdatedFiles(LibraryUpdatesCheckerThread.java:193)
at org.serviio.library.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:97)
HTH
J
Post Fri Jul 30, 2010 8:19 am
Hi, create a issue on bitbucket.org and attach the zipped logs there, thanks.
The error you're seeing is known and will be fixed in 0.4.2 - but has nothing to do with your original problem.
Brammers
Post Sat Jul 31, 2010 9:32 am
Issue created with logs.
Can I ask if you have decided on a release timeframe for 0.4.2 yet?
J
Post Sat Jul 31, 2010 9:47 am
As soom as I fix subtitles on Samsungs... could be next week or next month
SRG
Post Sat Jul 31, 2010 9:49 pm
I really think that you should quickly release 0.4.2 (maybe postponing samsung subtitles fix for 0.4.3), the "java.lang.NullPointerException" exception while adding files is really annoying...
stephendhill
Post Sun Aug 01, 2010 8:07 am
I'm seeing:
"2010-08-01 09:06:13,856 INFO [AbstractModel] Remote exception occured, removing the listener: CORBA COMM_FAILURE 1398079689 No; nested exception is: org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No"
I don't know if this is related.
Avid Serviio user
Post Mon Aug 02, 2010 8:17 am
no, it's not
stephendhill
Post Mon Aug 16, 2010 5:43 am
I've managed to pin down when it happens.
When I moved to Serviio 0.4.1, I decided I no longer need mediatomb, therefore I uninstalled it. That's when the problems began. Reinstalling the mediatomb-daemon package 'magically' brings Serviio 'back to life' (that is dlna clients can see it). If I uninstall mediatomb-daemon, Serviio connections are not possible (strangely after some period of time).
My first suspicion was maybe installing the mediatomb-dameon package opened ports in the firewall (ufw), but as far as I know all ports are open. Still investigating.....
P.S. I'm running Ubuntu 9.10.
Avid Serviio user
stephendhill
Post Mon Aug 16, 2010 5:50 am
I believe it may have something to do with:
# The route command and arguments to be used if INTERFACE is defined.
# These variables should normally be left unmodified.
ROUTE_ADD="/sbin/route add -net 239.0.0.0 netmask 255.0.0.0"
ROUTE_DEL="/sbin/route del -net 239.0.0.0 netmask 255.0.0.0"
in /etc/default/mediatomb.
Avid Serviio user
stephendhill
Post Tue Aug 17, 2010 8:35 pm
The lack of the multicast route IS the problem.
I have added
up route add -net 239.0.0.0 netmask 255.0.0.0 dev eth1
to /etc/network/interfaces to fix the problem permanently.
Avid Serviio user
Post Wed Aug 18, 2010 8:30 am
great
Elvis71
Post Sat Aug 21, 2010 7:35 am
Ok, so i am having the same problem with W Vista and without mediatomb. What should I do to fix it?
Post Mon Aug 23, 2010 8:42 am
I'm hoping 0.4.2 might fix this.
jono26
Post Sat Aug 28, 2010 1:28 pm
I wonder if it has anything to do with running on Windows 7 64bit. I also have the same problem (restarting serviio fixes it).
mightymouse2045
Post Sun Jan 15, 2012 12:43 pm
stephendhill wrote:The lack of the multicast route IS the problem.
I have added
I added the above when setting up Serviio, however my Yamaha Receiver RX-V3067 wouldn't see my Serviio service running under Ubuntu.
I noticed in Twonky setup guide they had a different multicast address of:
up route add -net 224.0.0.0 netmask 240.0.0.0 dev ethX (ethX is whatever you NIC is in your machine, mine is eth0).
For some reason this worked straight off for the Yamaha - perhaps that is why there are reports of Twonky being the only non windows based media server that works with Yamaha receivers? Looking at the wiki page for multicast addresses 224.x.x.x seems to be the correct address to be used though.
soohyun2222
Post Wed Jan 02, 2013 3:49 am
I use centos 6
and mine worked after typing
#route add -net 239.0.0.0 netmask 255.0.0.0 gw 192.168.0.1
for more information about this command cf) http://www.cyberciti.biz/faq/ubuntu-lin ... c-routing/
Finally I added this to /etc/networks
Users browsing this forum: Baidu [Spider], Google [Bot] and 34 guests
