Online Feeds
mboronene
Post Wed Oct 26, 2011 10:47 am
Online Feeds
Hi serviio suscribers !
I'm still new and have got no idea of how to view online feeds... I tried from my own savoir faire (as there no much guide lines to do it) but did get the 'there is nothing to display' prompt...
Would you kindly guide me step by step through it... As I've downloaded the 0.6.0.1 and using the ex720 series of sony...
Thanks !
Post Wed Oct 26, 2011 11:34 am
Re: Online Feeds
You open the serviio console.
Select library tab
select online sources
pick a source from the forum group. Some online sources require a plugin. Look in the plugin directory for ones that have been made so far.
http://forum.serviio.org/viewforum.php?f=23
Paste it in the online source box.
Click save
After a short period of time they will show up in the online feed folder on your TV.
Post Wed Oct 26, 2011 12:21 pm
Re: Online Feeds
Did you read this link :
http://www.serviio.org/support
