ffmpeg checking
WildRushSykes
Post Fri Oct 28, 2011 10:15 am
ffmpeg checking
Ive downloaded the latest version of ffmpeg but need to find out what services are enable within the static .exe how do i go about this within windows like gpu transcoding and librmtp?
Post Fri Oct 28, 2011 10:22 am
Re: ffmpeg checking
librtmp you can check by running ffmpeg.exe and checking the output, it should say --enable-librtmp, similarly for any other linked library
WildRushSykes
Post Fri Oct 28, 2011 10:26 am
Re: ffmpeg checking
ive tried running it and the command screen pops up with a load of info then dissappears a split second later and cant read that fast is there anyway to stop it from auto closing like that and if theres options disabled how do i enable them ? i must say though its much faster at indexing files than the ffmpeg bundled with serviio cut my indexing time in half almost :lol:
Post Fri Oct 28, 2011 10:40 am
Re: ffmpeg checking
WildRushSykes wrote:ive tried running it and the command screen pops up with a load of info then dissappears a split second later ...
Windows OS: create "Info.bat" file under ./serviio/lib/ folder with this code
ffmpeg.exe
pause
WildRushSykes
Post Fri Oct 28, 2011 10:41 am
Re: ffmpeg checking
How do i create a bat file :lol: nevermind i googled it :)
all services enabled awesome
Thanks!
Post Fri Oct 28, 2011 2:56 pm
Re: ffmpeg checking
WildRushSykes wrote:How do i create a bat file :lol:
wow. :shock:
under ../serviio/lib folder
right click ...new text document...named Test.bat
rigth click on created .bat document
edit with previous code, save, close
double-click on .bat file;
WildRushSykes
Post Fri Oct 28, 2011 3:06 pm
Re: ffmpeg checking
for dumb people like me googles awesome :lol:
Return to General discussion
