PS3 Aspect Ratio
WildRushSykes
Post Fri Oct 28, 2011 2:50 pm
PS3 Aspect Ratio
Is there anyway to change the aspect ratio serviio transcodes in as it seems that its transcoding in 4:3 on my 16:9 HD TV and im missing a lot of the action :(
Post Fri Oct 28, 2011 2:59 pm
Re: PS3 Aspect Ratio
WildRushSykes
Post Fri Oct 28, 2011 3:04 pm
Sorry forgot to mention im using a PS3 ive disabled trancoding within serviio its just online feeds that have the wrong aspect ratio
Post Fri Oct 28, 2011 3:20 pm
WildRushSykes wrote:Is there anyway to change the aspect ratio serviio transcodes in as it seems that its transcoding in 4:3 on my 16:9 HD TV and im missing a lot of the action :(
WildRushSykes wrote:Sorry forgot to mention im using a PS3 ive disabled trancoding within serviio its just online feeds that have the wrong aspect ratio
Not sure to understand.
You use serviio(transcoding disable) with your PS3 and there were aspect ratio issue, right?
Post Fri Oct 28, 2011 4:01 pm
Online content is always transcoded (or remuxed)
WildRushSykes
Post Fri Oct 28, 2011 4:48 pm
With transcoding disabled all my media play natively in the correct aspect ratio because they are XVID HD files but when it comes to online content everything is played with the wrong aspect ratio. Im assuming all online content is transcoded into 4:3 which is the wrong aspect ratio for my tv
