Help- Samsung issues
seomra
Post Tue Oct 25, 2011 7:22 pm
Hi, I have been trying for a while now to get this sorted.
I have a Samsung DVD BD-D5300 and TV is SamsungLE46A6566 (model number).
I have the Samsung Wireless LAN adapter plugged into the DVD player, serviio console and app on the Mac, and when I try to access my Movies folder on the Mac, it persistently appears for maybe 3 minutes and drops connection.
Also, I seldom see the Movies folder and if I do it generally is empty. Sometime I can see the movie titles, but as soon as I click on a title it drops again.
Any ideas?
Post Thu Oct 27, 2011 9:41 am
Re: Help- Samsung issues
Can you try with wired connection to make sure it's not the network?
seomra
Post Sat Oct 29, 2011 6:31 pm
zip wrote:Can you try with wired connection to make sure it's not the network?
Hi , I suspect it is the wireless connection that is the problem. Unfortunately, the way I am set up here, it is not practical to run a cable.
thanks for your help.
Post Mon Oct 31, 2011 5:13 pm
Might not be practical but I need you to try it, just to make sure it's not something else.
Users browsing this forum: Google [Bot] and 22 guests
