Issue with Pause for Panasonic Blueray - BDT110
msj
Post Mon Oct 31, 2011 2:40 am
I have a panasonic blue-ray player DMP-BDT110 and I'm trying to get it working using Serviio. I found it easy to install and I have it working.
To get it working I created the profile from this item - and it seemed to work! Fantasic
viewtopic.php?f=13&t=1218&start=40
I was able to browse my library of files and play a file. It played well with no issues until I tried to pause or fast forward it.
When I did this, it change the aspect ratio to a 4:3 (old small format) from the wide screen one 16:9, and the playback stopped. No matter what I did, I couldn't get it to restart (i.e. pressed play, etc)
I'm running on XP also.
I turned on debug and this is what I saw, I've tried to put in the log around the time of selecting MovieA.avi.
thanks,
MSJ
2011-10-31 13:09:14,781 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-10-31 13:09:14,796 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-10-31 13:09:14,796 DEBUG [EventDispatcher] Sending event notification #0 for subscription df799be1-cf91-48f0-bd30-ffc8a3d121d6 to endpoint http://192.168.0.12:60605/event_0
2011-10-31 13:09:14,796 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.12:60605
2011-10-31 13:09:14,796 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-10-31 13:09:14,796 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-10-31 13:09:14,796 DEBUG [EventDispatcher] Sending event notification #1 for subscription dd7d642b-da17-4fdf-9b8b-04fd858cdb4d to endpoint http://192.168.0.10:2869/upnp/eventing/ssfbvdnajb
2011-10-31 13:09:14,796 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.10:2869
2011-10-31 13:09:14,812 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-10-31 13:09:16,687 DEBUG [WebServer] Incoming connection from /192.168.0.12:1987
2011-10-31 13:09:16,687 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.12:
2011-10-31 13:09:16,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-31 13:09:16,687 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 21) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @childCount,dc:date,dc:creator,upnp:channelNr,upnp:channelName,upnp:genre,upnp:album,res,res@duration,res@size,res@bitrate,res@dlna:ifoFileURI,res@protocolInfo, startIndex = 0, count = 5, sortCriteria =
2011-10-31 13:09:16,703 DEBUG [VideoDAOImpl] Retrieving number of video initials
2011-10-31 13:09:16,718 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2011-10-31 13:09:16,734 DEBUG [SeriesDAOImpl] Retrieving number of series
2011-10-31 13:09:16,734 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-10-31 13:09:16,750 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2011-10-31 13:09:16,750 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-10-31 13:09:16,750 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-10-31 13:09:19,125 DEBUG [WebServer] Incoming connection from /192.168.0.12:1988
2011-10-31 13:09:19,125 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.12:
2011-10-31 13:09:19,125 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-31 13:09:19,125 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 21) with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = @childCount,dc:date,dc:creator,upnp:channelNr,upnp:channelName,upnp:genre,upnp:album,res,res@duration,res@size,res@bitrate,res@dlna:ifoFileURI,res@protocolInfo, startIndex = 0, count = 5, sortCriteria =
2011-10-31 13:09:19,125 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=5)
2011-10-31 13:09:19,140 DEBUG [GenreDAOImpl] Reading a Genre (id = 6)
2011-10-31 13:09:19,156 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2011-10-31 13:09:19,156 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2011-10-31 13:09:19,156 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2011-10-31 13:09:19,171 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7 and profile Panasonic DMP-BDT110
2011-10-31 13:09:19,171 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_PAL
2011-10-31 13:09:19,171 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_NTSC
2011-10-31 13:09:19,171 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2011-10-31 13:09:19,187 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2011-10-31 13:09:19,187 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2011-10-31 13:09:19,187 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2011-10-31 13:09:19,187 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2011-10-31 13:09:19,187 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 24 and profile Panasonic DMP-BDT110
2011-10-31 13:09:19,187 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 10,000 BC[2008]R5 DvDrip AC3[Eng]-FXG.avi: MPEG_PS_PAL
2011-10-31 13:09:19,187 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 10,000 BC[2008]R5 DvDrip AC3[Eng]-FXG.avi: MPEG_PS_NTSC
2011-10-31 13:09:19,187 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 24)
2011-10-31 13:09:19,187 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2011-10-31 13:09:19,203 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2011-10-31 13:09:19,203 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-10-31 13:09:19,843 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-10-31 13:09:20,906 DEBUG [WebServer] Incoming connection from /192.168.0.12:1989
2011-10-31 13:09:20,906 DEBUG [ResourceTransportRequestHandler] GET /resource/7/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,HOST: 192.168.0.14:8895,transferMode.dlna.org: Streaming,getcontentFeatures.dlna.org: 1]]
2011-10-31 13:09:20,906 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-31 13:09:20,906 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:20,906 DEBUG [ResourceTransportRequestHandler] Request for resource 7 and type 'MEDIA_ITEM' received
2011-10-31 13:09:20,906 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7 (local)
2011-10-31 13:09:20,906 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2011-10-31 13:09:20,906 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2011-10-31 13:09:20,906 DEBUG [VideoDeliveryEngine] Delivering item '7' for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:20,906 DEBUG [VideoDeliveryEngine] Delivering file 'MovieA.avi' using transcoding
2011-10-31 13:09:20,906 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:20,906 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2011-10-31 13:09:20,906 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: D:\DivX\Movies\Kids\MovieA.avi
2011-10-31 13:09:20,906 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\DivX\Movies\Kids\MovieA.avi -y -threads 2 -vcodec mpeg2video -sameq -r 24000/1001 -g 15 -copyts -acodec copy -map 0:0 -map 0:1 -sn -f vob C:\WINDOWS\TEMP\Serviio\transcoding-temp-7-MPEG2PS.stf
2011-10-31 13:09:21,406 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_PAL
2011-10-31 13:09:21,406 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_NTSC
2011-10-31 13:09:21,406 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-10-31 13:09:21,421 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7) as read
2011-10-31 13:09:21,437 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-10-31 13:09:21,437 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-10-31 13:09:21,437 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-10-31 13:09:21,437 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-31 13:09:21,437 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-6421.0/6421,Date: Mon, 31 Oct 2011 02:09:21 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-10-31 13:09:21,593 DEBUG [WebServer] Incoming connection from /192.168.0.12:1990
2011-10-31 13:09:21,593 DEBUG [ResourceTransportRequestHandler] GET /resource/7/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,HOST: 192.168.0.14:8895,transferMode.dlna.org: Streaming,getcontentFeatures.dlna.org: 1]]
2011-10-31 13:09:21,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] Request for resource 7 and type 'MEDIA_ITEM' received
2011-10-31 13:09:21,609 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7 (local)
2011-10-31 13:09:21,609 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2011-10-31 13:09:21,609 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2011-10-31 13:09:21,609 DEBUG [VideoDeliveryEngine] Delivering item '7' for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:21,609 DEBUG [VideoDeliveryEngine] Delivering file 'MovieA.avi' using transcoding
2011-10-31 13:09:21,609 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:21,609 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_PAL
2011-10-31 13:09:21,609 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_NTSC
2011-10-31 13:09:21,609 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-10-31 13:09:21,609 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7) as read
2011-10-31 13:09:21,609 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-31 13:09:21,609 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-6421.0/6421,Date: Mon, 31 Oct 2011 02:09:21 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-10-31 13:09:22,562 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-10-31 13:09:33,343 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Intel(R) 82566DM-2 Gigabit Network Connection - Packet Scheduler Miniport) and address 192.168.0.14, timeout = 0
2011-10-31 13:09:33,343 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 33a806e5-df8a-3086-bdee-a45ec476debd
2011-10-31 13:09:35,156 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:15
2011-10-31 13:09:37,046 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-10-31 13:09:42,687 DEBUG [WebServer] Incoming connection from /192.168.0.12:1991
2011-10-31 13:09:42,687 DEBUG [ResourceTransportRequestHandler] GET /resource/7/MEDIA_ITEM/MPEG_PS_PAL$0 HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=10.079-,HOST: 192.168.0.14:8895,transferMode.dlna.org: Streaming,getcontentFeatures.dlna.org: 1]]
2011-10-31 13:09:42,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-31 13:09:42,687 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:42,687 DEBUG [ResourceTransportRequestHandler] Request for resource 7 and type 'MEDIA_ITEM' received
2011-10-31 13:09:42,687 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7 (local)
2011-10-31 13:09:42,687 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2011-10-31 13:09:42,687 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2011-10-31 13:09:42,687 DEBUG [VideoDeliveryEngine] Delivering item '7' for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:42,687 DEBUG [VideoDeliveryEngine] Delivering file MovieA.avi' using transcoding
2011-10-31 13:09:42,687 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.12, Profile=Panasonic DMP-BDT110'
2011-10-31 13:09:42,687 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_PAL
2011-10-31 13:09:42,687 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MovieA.avi: MPEG_PS_NTSC
2011-10-31 13:09:42,687 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-10-31 13:09:43,000 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1743397815
2011-10-31 13:09:43,000 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-10-31 13:09:43,000 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-10-31 13:09:43,000 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=10.079-6421.0/6421,Date: Mon, 31 Oct 2011 02:09:43 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-10-31 13:09:54,718 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-10-31 13:09:59,718 DEBUG [WebServer] Incoming connection from /192.168.0.12:1992
2011-10-31 13:09:59,718 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ContentDirectory and subscription uuid:df799be1-cf91-48f0-bd30-ffc8a3d121d6
2011-10-31 13:09:59,718 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=df799be1-cf91-48f0-bd30-ffc8a3d121d6) removed for service urn:upnp-org:serviceId:ContentDirectory
2011-10-31 13:10:00,265 DEBUG [WebServer] Incoming connection from /192.168.0.12:1993
2011-10-31 13:10:00,265 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ContentDirectory and subscription uuid:df799be1-cf91-48f0-bd30-ffc8a3d121d6
2011-10-31 13:10:13,203 DEBUG [WebServer] I/O error: Connection reset
2011-10-31 13:10:19,843 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-10-31 13:10:50,765 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Intel(R) 82566DM-2 Gigabit Network Connection - Packet Scheduler Miniport) and address 192.168.0.14, timeout = 0
2011-10-31 13:10:50,765 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 33a806e5-df8a-3086-bdee-a45ec476debd
2011-10-31 13:10:52,578 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:25
msj
Post Tue Nov 01, 2011 2:04 am
Re: Issue with Pause for Panasonic Blueray - BDT110
just an update, and a bit of help for those other Panasonic Blue-ray owners with BDT110.
I played around with a number of settings and options and I found I could just map my servers shared drive to the blueray.
Not quite DLNA, but it allowed me to directly play the files, no need for transcoding etc. So it is virtually the same as connecting a usb drive into the played.
To do this, you need to "enable" networking drive mappings, in the settings, then it appears when you select "network".
You then enter the credentials for the share and bam..done.
So I'll be using this and not Serviio mainly due to the lack of ability of the BlueRay to support DLNA than ability of Serviio. I found it an excellent product, and, if my device supported it, would have used it.
Thanks,
MSJ
Post Wed Nov 02, 2011 11:04 am
msj wrote:... I found I could just map my servers shared drive to the blueray.
Good tips.
When format is supported by your player, its probably better, for other not supported format, you will need to manually transcode them or use serviio on the fly;
Return to Panasonic
