Can't open Serviio app in Synology DSM
erikradix
Post Sun Oct 30, 2011 7:39 pm
As the title states, I can't open to the Serviio app in my DiskStation Manager.
I'm running a DS211J and just installed Serviio 0.6.0.1 v3.
Everything worked fine at first. The after viewing an mkv file on my Panasonic Viera I couldn't access my DSM at all. A window told me the hard drive was full and I couldn't log in unless I rebooted. So I rebooted the NAS and tried again a couple of times without any luck.
I then went into the Serviio app and stopped it from running and uninstalled it and JAVA 6.
Then I reinstalled everything, but now I can't open to the Serviio app in my DSM. (The window opens but it doesn't show anything.)
I can see the server on both my TV and on my PS3, but without any content.
What do I do?
/Erik
patters
Post Tue Nov 01, 2011 8:24 am
Re: Can't open Serviio app in Synology DSM
Sorry, only just seen this. My guess is that you forgot the step in my instructions to change the transcoding temp folder from its default of /tmp to /volume1/@tmp.
To clean up after the mistake, you'll need to go into /tmp and remove the Serviio folder in there (which probably contains a .stf file that's several gigabytes in size).
erikradix
Post Tue Nov 01, 2011 4:28 pm
Yeah, that's probably the cause of evil. I don't think I got that directory right.
I can't find the /tmp folder though... I've never even seen the folder.
patters
Post Tue Nov 01, 2011 5:18 pm
You can't see it unless you connect via Telnet or SSH and use the command line.
So something like:
rm -r /tmp/Serviio
Be very careful using rm -r - you can easily trash your system.
erikradix
Post Tue Nov 01, 2011 9:49 pm
I tried the command but Terminal just told me the directory didn't exist.
