Sat Nov 05, 2011 4:58 pm by Janne
Hi Domaingu,
Another Mac user here!
The profiles are located within the Serviio bundle. Easiest way to access them is by right-clicking on the Serviio icon and select Show Package Contents.
Then look inside the folder Contents/Resources/Java/config and there You have profiles.xml.
I'm also using Handbreak to create suitable files for Serviio, and if I have understood correctly You can use both MKV and MP4 containers (i use MP4).
I use the x264 codec and I have found out that my TV likes to have a "standard" framerate of 23.976 (NTSC Film) to get the smoothes display.
The Quality have I set to Constant and RF:20, if I have a higher quality source than DVD I might set RF to 22, I've read some arguments on the net that even 18 will give You no visible degradation from a DVD.
In the Sound tab I have set the output to AC3 and mix down to Dolby Pro Logic II.
I also uses the subtitle tab to burn in the subtitles from any DVD source since my Sony doesn't handle soft-subtitles.
Unfortunately, Handbreak can't render .srt files as bitmaps, but it can include them as soft-subtitles if Your DLNA device supports it.
I hope that this will give me none, or as little transcoding as possible. If someone have any better ideas, please let me know!
HTH!
Janne
