Media streaming to blackberry torch
does anyone know if serviio will stream to it over wifi?
Mart
Mart360 wrote:looking at a blackberry torch 9810 potentially
Mart
Item Description
Connect to TVersity
Tested on OS2.0 and OS2.0 compatible.
**NOTE: This applications was not developed by TVersity and is only designed to connect to their server software**
This connector allows your BlackBerry® PlayBook™ to connect to a TVersity server. For more information on setting up a TVersity server please refer to: http://tversity.com/
What does it do?
This lets you stream your Audio, Video and Pictures from your PC to your BlackBerry® PlayBook™. The TVersity Server is free to install and use. And is also compatible with: XBOX, PS3 and Wii.
Does it work over the internet?
Yes, you can configure TVersity to connect over the internet by IP address or a DNS.
Do I need to buy this app to use TVersity?
No, there are other ways of streaming TVersity to your devices. TVersity is a DLNA compliant sharing server - and this is just one of several ways to watch the videos.
Am I limited to only TVersity?
No you can customize this application to connect to any standard web server that can transcode video to flash. You can customize the IP and Port. TVersity however is one of the few servers that will convert the videos for you so they are compatible with your BlackBerry® PlayBook™.
