Samsung UE40D6100 disconnects and cant re connect
ratyip4
Post Wed Nov 02, 2011 3:47 pm
Hi all!
I tryed this twice, i install the program run it, select Samsung TV / player (C/D-series). (the router is already configured IP is fixed, ports are open 1900, 8895, 23423)
I use Nod32 5.0.94.0 (added TVs IP to trusted zone + ports), have windows 7, file sharing is enabled, "C:\Program Files\Windows Media Player\wmpnetwk.exe" (service disabled)
I tryed WiFi / LAN cable also.
With fresh install i can connect to serviio with no problems (was very happy about that). I open a movie play it, after 10 minutes i decide to try another movie,i go back , to select another movie, than it says "device disconnected" and now i dont see servio in the source list of the TV , i have a Linksys Wireless-N WRT160NL router.
I checked TV it has network + internet, in the routers setup i can see the TV, with "network magic" also.
I hit refresh + restart service still nothing. Sometimes it helps when i remove the TV from the status page, and reenter the IP from the Tv.
I looked hours on net maybe some 1 have the same problem but no luck yet. :cry:
serviio log (debug)
(68.32 KiB) Downloaded 802 times
ratyip4
Post Thu Nov 03, 2011 5:41 am
Re: Samsung UE40D6100 disconnects and cant re connect
any1 have some tips :?: :roll:
Post Thu Nov 03, 2011 8:23 am
:idea: Change the channel of your Wireless-N WRT160NL router.
ratyip4
Post Thu Nov 03, 2011 9:34 am
Illico wrote::idea: Change the channel of your Wireless-N WRT160NL router.
Thanks, wich 1 did you mean :?:
(see attachments)
Basic Wireless Settings
Basic Wireless Settings.JPG (11.25 KiB) Viewed 16326 times
Advanced Wireless Settings
Advanced Wireless Settings.JPG (23.97 KiB) Viewed 16326 times
Post Thu Nov 03, 2011 9:59 am
http://netlink.com.ua/media/products/01 ... 076662.pdf
Page 10.
Try change Channel Width with "Wide - 40MHz Channel" or "Standard - 20MHz Channel."
ratyip4
Post Thu Nov 03, 2011 10:52 am
Illico wrote:http://netlink.com.ua/media/products/0157416001262076662.pdf
Page 10.
I changed it this way, after i go home i will try it. Hope it helps.
Thanks anyways :)
Basic
Basic Wireless Settings.JPG (12.65 KiB) Viewed 16318 times
Post Thu Nov 03, 2011 11:18 am
Also run run the tool from this post.
http://forum.serviio.org/viewtopic.php?f=17&t=2439
You might be using a channel that one of your neighbors is using at the same time. I recommend everyone that is using wireless and has close neighbors to run this. If two routers are on the same channel and close together they have to share time slices on the channel.
ratyip4
Post Thu Nov 03, 2011 12:55 pm
moltra wrote:Also run run the tool from this post.
I used the tool that you linked, no other WiFis found.
And still my TV cant see serviio. :x
ratyip4
Post Sat Nov 05, 2011 5:08 am
Any1 other ideas :?: :roll:
YTMY
Post Mon Nov 07, 2011 11:15 am
ratyip4 wrote:Any1 other ideas :?: :roll:
If I see correctly "AP isolation" is enabled. You should disable it (as by default) because with this option enabled your network devices cannot see each other (no homegroup, no communication between devices, no nothing, except access to internet for all devices).
Hope this helps.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
ratyip4
Post Sun Nov 13, 2011 1:38 pm
Hope this helps.
Nope, i have set it to disabled, and now cant even se serviio :x
Thanks anyways
YTMY
Post Mon Nov 14, 2011 7:27 pm
If I were You I would reset router to factory default and start everything clean and see if it works without any changes to router settings. For wireless security use WPA2 personal with AES encryption (if You use any at all). Maybe something went wrong with router settings.
Is signal near TV strong or is it variable? Have You tried cable connection to TV? ;)
ratyip4
Post Tue Nov 15, 2011 7:39 am
YTMY wrote:If I were You I would reset router to factory default and start everything clean and see if it works without any changes to router settings. For wireless security use WPA2 personal with AES encryption (if You use any at all). Maybe something went wrong with router settings.
Done, reseted the router: i use WPA2 with AES.
Signal isnt weak the router is 2m from the TV, cable also tryed. Still not working :x
Thanks anyways 8-)
YTMY
Post Tue Nov 15, 2011 11:21 am
Strange, if its failing on cable, it might be firewall issue, QoS settings on router, and I'm out of ideas.. :) Maybe another router would help to rule out (or confirm) the router issue.
I hope You will rule it out eventually. ;)
ratyip4
Post Tue Nov 15, 2011 12:58 pm
YTMY wrote:Strange, if its failing on cable, it might be firewall issue, QoS settings on router, and I'm out of ideas.. :) Maybe another router would help to rule out (or confirm) the router issue.
Thanks for help again! :)
Try'd to turn off firewall also (Windows 7 and ESET 5 also).
Well this is my 4. router this year :D and wasnt cheap, so i try to borrow one...
My last try will be to reinstall the windows, but Serviio can detect my TV, status green on the main page, but after i hit refresh, i still cant see Serviio on my TV :( )
QoS settings below:
QoS settings
YTMY
Post Wed Nov 16, 2011 8:18 pm
If it is indeed a router fault, I would not throw it away, I would try tomatousb (toastman edit) firmware. Works very well for both of my linksys routers. ;)
br
ratyip4
Post Fri Nov 18, 2011 1:51 pm
YTMY wrote:If it is indeed a router fault, I would not throw it away, I would try tomatousb (toastman edit) firmware. Works very well for both of my linksys routers. ;)
br
i upgraded to "Firmware: DD-WRT v24-sp2 (08/07/10) std"
but still not working :( , later i try to reinstall the opsys maybe it helps :(
Users browsing this forum: Baidu [Spider] and 20 guests
