DailyMotion
Post Mon Nov 07, 2011 2:15 pm
DailyMotion
DailyMotion.com plugin
Added 07/11/2011
Updated 5/8/2012
Updated 18/2/2016
Updated 4/12/2016
DailyMotion.groovy
(2.65 KiB) Downloaded 1590 times
martyn
Post Tue Nov 08, 2011 9:10 am
Re: DailyMotion
brilliant m8 works great Image
martyn
Post Tue Nov 08, 2011 10:19 am
Re: DailyMotion
couple of tips for daily motion
you can also view the other pages for each category or user etc so you would have this say ----> http://dailymotion.com/rss/user/fatherted/1 all you do is change 1 for the next page number :D
also if you register you can add seperate videos to your favourites list and use that feed , so really you can view seperate videos :D
ak78
Post Fri May 25, 2012 2:58 am
Re: DailyMotion
How to watch private videos on Dailymotion? for example - the URl http://www.dailymotion.com/rss/video/k6 ... LbOMI32rki can be opened in browser, but does not work when added in serviio.
zsiv
Post Mon Aug 06, 2012 1:40 pm
Re: DailyMotion
This Plug in no longer works.
Throws Java.lang.IndexOutOfBoundsException : index is out of range 0..-1 (index = 0)
at DailyMotion.extractUrl(DailyMotion.groovy:38)
at DailyMotion$extractUrl.call(Unknown Source)
at DailyMotion.main(DailyMotion.groovy:67)
A quick fix is appreciated. :)
thanks,
zsiv
Post Mon Aug 06, 2012 4:11 pm
Re: DailyMotion
I fixed it yesterday hopefully. Download it again.
zsiv
Post Mon Aug 06, 2012 11:42 pm
Re: DailyMotion
Petr,
That was fast.
Plug in works now.
Thanks much.
zsiv
Ned Flanders
Post Fri Nov 02, 2012 11:11 pm
Re: DailyMotion
Hi, great work for this plugin.
Number of results seems to be fixed to 20. Is there a way like a suffix to add in order to level up this limit ?
sheikh73
Post Thu Feb 07, 2013 2:29 am
Re: DailyMotion
I can not get it to work... Here is what I added as onlin rss https://dailymotion.com/rss/user/PakDramas2012/1
but nothing is showing up in serviio onlin folder...
jdegreef
Post Sat Apr 06, 2013 3:47 pm
Re: DailyMotion
I have a problem with dailymotion.groovy.
Some videos don't show in the "Online" folder.
Here's my rss feed : http://www.dailymotion.com/rss/user/Mediapart/1
and I've attached the Serviio log file.
Let me know if you need additional information.
Thanks for your help,
Jérôme
dailymotion.groovy.serviio.log
(21.62 KiB) Downloaded 1671 times
jdegreef
Post Tue Apr 09, 2013 6:04 pm
Re: DailyMotion
So, nobody has an idea ?
Or maybe this is the wrong forum...
tstrike
Post Tue May 14, 2013 11:21 pm
Re: DailyMotion
Try to setup up multiple libraries...
I have different ones for one user (they do fine), but for another DM user I get the unplayable file. Is there a permissions issue?
jdegreef
Post Wed May 15, 2013 9:33 am
Re: DailyMotion
It's not a permission problem as it works for the same user with other streams.
The problem is the same on Win and Linux
The file plays ok in local but not from DM.
There's more about this problem here viewtopic.php?f=5&t=9991
siriusblack
Post Thu May 30, 2013 2:37 pm
Re: DailyMotion
HI ZIP
Is DailyMotion Down ?
Here is my log
DailyMotion.txt
(2.46 KiB) Downloaded 1496 times
ive downloaded the DailyMotion and put it in the plugin
and its not working for me
can you sent me a different plugin please to try
Beta Tester
Post Sun Jun 02, 2013 2:02 pm
Re: DailyMotion
You se it up as a Web Resource in the console. It has to be RSS/Atom feed.
siriusblack
Post Wed Jul 24, 2013 5:39 pm
Re: DailyMotion
DailyMotion not working for me
I tried installing another DailyMotion plugin in case there was a bug
Here is my log
DailyMotion new.txt
(1.11 KiB) Downloaded 1497 times
Screenshot
Screenshot (18).png (201.56 KiB) Viewed 45248 times
Thanks Zip
Beta Tester
tstrike
Post Wed Jul 24, 2013 8:29 pm
Re: DailyMotion
Hi Zip...
Is there a way to recode the plugin so that we can sort/order the videos by upload date, alphabetical, or otherwise?
Thanks in advance.
haamro
Post Fri Aug 23, 2013 4:58 pm
Re: DailyMotion
Can somebody verify if this plugin is still working ? I am getting error "Cannot parse resource from http://www.dailymotion.com/rss/user/Mediapart/1. Message: No plugin for web resource http://www.dailymotion.com/rss/user/Mediapart/1 has been found." even when using the example here.
thanx
siriusblack
Post Fri Aug 23, 2013 5:58 pm
Re: DailyMotion
I made the same mistake before
You set it up as a Web Resource in the console. It has to be RSS/Atom feed.
Beta Tester
haamro
Post Fri Aug 23, 2013 10:19 pm
Re: DailyMotion
Can you share a working URL ? I have spent more than 4 hours figuring this :cry:
Return to Available plugins
