Veetle.com - Online video streaming portal
bakthi
Post Mon Nov 07, 2011 4:24 pm
Hi, I like to get a plugin for veetle.com channels.
I am able to get the channels played through VLC. I am able to stream the channel played to a local port - http://127.0.0.1:1234 using the methods explained in the site. I don't know how to stream this to my Sony VIERA TV. I am not able to stream through Serviio. Even I thought if we get direct plugin for the site content - veetle.com then there is no pain in capturing and streaming through VLC.
Post Mon Nov 07, 2011 5:15 pm
Re: Veetle.com - Online video streaming portal
live stream access incl. VLC streaming should be possible in 0.6.1
GuillauG
Post Fri Dec 02, 2011 8:25 pm
Do you know when this option will be enabled?
What i need to do is to stream a desktop (which i can using vlc) to many Samsung screen.
Refresh and Quality don't need to be good because it's a mostly static low-resolution display.
I'm very interested in making this work because it will save our company many $$$ instead of pluging a thin client with VNC on each tv screen.
Can you give us a timeline for the next release?
Thank you.
Return to Plugin requests
