problems transcoding some .wtv files?
nisse666
Post Mon Nov 07, 2011 11:00 pm
Hello
I'm having problems transcoding some .wtv files
(other .wtv files transcode just fine)
I'm running win7 64bit, serviio-0.6.0.1, java version "1.6.0_29"
I'm having problems with the same files on all my devices (PS3, Sony KDL-EX700, LG PZ950W).
All devices have the same definition for .wtv in the profile
<Matches container="wtv" />
parts from log
2011-11-07 23:46:43,763 INFO  [MediaServer] ------------------------------------------------------------------------
2011-11-07 23:46:43,763 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-11-07 23:46:43,763 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-11-07 23:46:43,763 INFO  [MediaServer] http://www.serviio.org
2011-11-07 23:46:43,763 INFO  [MediaServer] Java 1.6.0_29-Sun Microsystems Inc.
2011-11-07 23:46:43,763 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-11-07 23:46:43,763 INFO  [MediaServer] File encoding: windows-1252
2011-11-07 23:46:43,763 INFO  [MediaServer] Headless mode enabled: true
2011-11-07 23:46:43,764 INFO  [MediaServer] User home dir: C:\
2011-11-07 23:46:43,764 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2011-11-07 23:46:43,764 INFO  [MediaServer] ------------------------------------------------------------------------
2011-11-07 23:47:44,709 DEBUG [VideoDeliveryEngine] Delivering item '35' for client 'IPAddress=/192.168.1.54, Profile=Playstation 3'
2011-11-07 23:47:44,709 DEBUG [VideoDeliveryEngine] Delivering file 'Sagor från zoo_SVTB-SVT24_2011_11_07_13_58_00.wtv' using transcoding
2011-11-07 23:47:44,709 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.54, Profile=Playstation 3'
2011-11-07 23:47:44,709 DEBUG [MediaItemDAOImpl] Getting file of media item 35
2011-11-07 23:47:44,710 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: \\192.168.1.100\mediacenter\Recorded TV\Sagor från zoo_SVTB-SVT24_2011_11_07_13_58_00.wtv
2011-11-07 23:47:44,710 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i \\192.168.1.100\mediacenter\Recorded TV\Sagor från zoo_SVTB-SVT24_2011_11_07_13_58_00.wtv -y -vcodec copy -acodec copy -map 0:1 -map 0:2 -sn -f mpegts C:\Windows\Temp\Serviio\transcoding-temp-35-MPEG2TS.stf
2011-11-07 23:47:44,906 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2011-11-07 23:47:44,906 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-11-07 23:47:45,211 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:117)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
ffmpeg -i
nfig
[mpeg2video @ 00359b40] mpeg_decode_postinit() failure
    Last message repeated 7 times
[wtv @ 00358b60] max_analyze_duration 5000000 reached at 5016000
Input #0, wtv, from '\\192.168.1.100\mediacenter\Recorded TV\Sagor från zoo_SVT
B-SVT24_2011_11_07_13_58_00.wtv':
    Tuner ID        : 1A518063-CF1B-4A66-AB5C-1443E6858743
    WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
    WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
    Title           : Sagor fr├Ñn zoo
    WM/SubTitleDescription: Lucy ├ñr en liten flicka som bor vid en djurpark. Va
rje kv├ñll ber├ñttar hennes fyrfota v├ñnner en godnattsaga f├Âr henne.
    WM/OriginalReleaseTime: 0
    WM/MediaCredits : ;;;
    service_provider: SVTB/SVT24
    service_name    : SVTB/SVT24
    WM/MediaNetworkAffiliation: dvblink
    WM/MediaOriginalChannel: 98
    WM/MediaOriginalChannelSubNumber: 0
    WM/MediaOriginalBroadcastDateTime: 0001-01-01T00:00:00Z
    WM/MediaOriginalRunTime: 8939137623
    WM/MediaIsStereo: false
    WM/MediaIsRepeat: false
    WM/MediaIsLive  : false
    WM/MediaIsTape  : false
    WM/MediaIsDelay : false
    WM/MediaIsSubtitled: false
    WM/MediaIsMovie : false
    WM/MediaIsPremiere: false
    WM/MediaIsFinale: false
    WM/MediaIsSAP   : false
    WM/MediaIsSport : false
    WM/Provider     : MediaCenterDefault
    WM/VideoClosedCaptioning: false
    WM/WMRVEncodeTime: 2011-11-07 12:58:06
    WM/WMRVSeriesUID: !GenericSeries!Sagor fr├Ñn zoo
    WM/WMRVServiceID: !Generated!a50a1f5e233442218ef6ebaf7804c9bd
    WM/WMRVProgramID: !MCProgram!8162774326772943!eitscanner:522000:8945:1021:87
0!1320670800
    WM/WMRVRequestID: 0
    WM/WMRVScheduleItemID: 0
    WM/WMRVQuality  : 0
    WM/WMRVOriginalSoftPrePadding: 240
    WM/WMRVOriginalSoftPostPadding: 180
    WM/WMRVHardPrePadding: -120
    WM/WMRVHardPostPadding: 0
    WM/WMRVATSCContent: false
    WM/WMRVDTVContent: true
    WM/WMRVHDContent: false
    Duration        : 8939139515
    WM/WMRVEndTime  : 2011-11-07 13:13:00
    WM/WMRVBitrate  : 8.073216
    WM/WMRVKeepUntil: -1
    WM/WMRVActualSoftPrePadding: 233
    WM/WMRVActualSoftPostPadding: 180
    WM/WMRVContentProtected: false
    WM/WMRVContentProtectedPercent: 0
    WM/WMRVExpirationSpan: 9223372036854775807
    WM/WMRVInBandRatingSystem: 255
    WM/WMRVInBandRatingLevel: 255
    WM/WMRVInBandRatingAttributes: 0
    WM/WMRVWatched  : false
  Duration: 00:14:53.68, start: 1.436746, bitrate: 4963 kb/s
    Stream #0.0[0x1f](swe): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.1[0x20]: Video: mpeg2video (Main), yuv420p, 720x576 [PAR 64:45 DAR
 16:9], 15000 kb/s, 26.41 fps, 25 tbr, 10000k tbn, 50 tbc
    Stream #0.2[0x21]: Audio: mp2, 48000 Hz, stereo, s16, 256 kb/s
manually running serviio ffmpeg command
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "\\192.168.1.100\mediacenter\Re
corded TV\Sagor från zoo_SVTB-SVT24_2011_11_07_13_58_00.wtv" -y -vcodec copy -ac
odec copy -map 0:1 -map 0:2 -sn -f mpegts "C:\Windows\Temp\Serviio\transcoding-t
emp-35-MPEG2TS.stf"
nfig
[mpeg2video @ 0120aee0] mpeg_decode_postinit() failure
[wtv @ 01798f40] max_analyze_duration 5000000 reached at 5016000
0!1320670800
    WM/WMRVRequestID: 0
    WM/WMRVQuality  : 0
[mpegts @ 03516ac0] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'C:\Windows\Temp\Serviio\transcoding-temp-35-MPEG2TS.stf':
0!1320670800
    WM/WMRVRequestID: 0
    WM/WMRVQuality  : 0
    encoder         : Lavf53.6.0
    Stream #0.0: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=2-3
1, 15000 kb/s, 90k tbn, 25 tbc
    Stream #0.1: Audio: mp2, 48000 Hz, stereo, 256 kb/s
Stream mapping:
  Stream #0.1 -> #0.0
  Stream #0.2 -> #0.1
[mpegts @ 03516ac0] Application provided invalid, non monotonically increasing d
ts to muxer in stream 0: 25090 >= 25090
av_interleaved_write_frame(): Invalid argument
Post Mon Nov 07, 2011 11:21 pm
Re: problems transcoding some .wtv files?
Looks like the FFmpeg 807 bug. I'll try to patch FFmpeg for 0.6.1 to get around this issue. Try then or join betatesters group to validate the fix.
nisse666
Post Tue Nov 08, 2011 11:27 am
zip wrote:Looks like the FFmpeg 807 bug. I'll try to patch FFmpeg for 0.6.1 to get around this issue. Try then or join betatesters group to validate the fix.
I'll be happy to become a beta tester! How do I apply?
How will i know that You have had the time to patch, and there is something to test?
Post Tue Nov 08, 2011 11:46 am
I've added you. Details will be in the Betatesting forum.
Post Tue Nov 08, 2011 12:07 pm
A workaround should be to force mpeg2video transcoding.
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
nisse666
Post Tue Nov 08, 2011 8:07 pm
Illico wrote:A workaround should be to force mpeg2video transcoding.
Workaround is working perfect :)
Can't complain about the level of support, this is excellent!
looking forward to do some beta testing.
lightsailpro
Post Mon Nov 14, 2011 12:53 am
I tried the workaround by setting forceVTranscoding="true". It does not work very well. The videos stutter a lot. With the default setting, some of the WTV files work fine, while with other wtv files, I get "format not supported" error. Zip, could you add me to the betatester group.
Users browsing this forum: Bing [Bot] and 7 guests
