Samsung LN40D550 FLAC
CraigD
Post Wed Nov 09, 2011 2:07 am
Just want to report that flac does not seem to transcode for the Samsung d series LCD TVs
Post Wed Nov 09, 2011 9:53 am
Re: Samsung LN40D550 FLAC
do you see errors in the log?
CraigD
Post Wed Nov 09, 2011 12:17 pm
No I haven't had a chance to look into it yet. I will tonight.
CraigD
Post Thu Nov 10, 2011 1:54 am
Well here is something quite interesting to do with this issue: when I initiate FLAC playback on the LN40D550 using my regular TV remote, everything works perfectly and there is nothing in the log.
Now, when I initiate playback on my Samsung Captivate using BubbleUPNP acting as a DMC, the playback fails and the following is in the logs:
2011-11-09 20:47:09,622 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: No media description available for required version: FLAC
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: FLAC
        at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:202)
        at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:144)
        at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:107)
        at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:149)
        at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:122)
Appears to some sort of issue with the DMC initiating the playback... Let me know if there is any more information I can provide on this. Just want to point out that MP3s seem to work fine when initiated by the DMC.
YTMY
Post Thu Nov 10, 2011 8:33 am
From my experience I haven't found a single android media controller to be able stream flac's to a sammy TV from serviio.
Maybe setting Samsung profile for DMC could work?
edit:
ok, there is another topic http://forum.serviio.org/viewtopic.php?f=10&t=3988#p26203
Setting samsung profile for android device should help.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
CraigD
Post Thu Nov 10, 2011 11:36 am
Interesting. Maybe zip can comment on why this is necessary. I would expect serviio to use the profile for the renderer and not the controller.
Post Thu Nov 10, 2011 11:40 am
The incoming traffic for browsing files is coming from the controller's IP. Profiles are linked to IPs. This unfortunately means you will be only able to use one type of device with a controller.
CraigD
Post Thu Nov 10, 2011 12:11 pm
Understandable. Is there no other means to detect what is rendering the content?
Post Thu Nov 10, 2011 2:09 pm
I have not read the controller spec yet, but from what data is coming in - no.
