Playstation 3 "The data type is not supported"
joelkaberg
Post Tue Nov 08, 2011 8:39 pm
First of, Thanks alot zip for serviio. Great work, loving it lots! :)
But I got a small problem with a few of my films/series, when trying to play some of them i get a "The data type is not supported"
Now among the files im trying to play is
MEDIA INFO
Unique ID                        : 232039255405421637181390199727326307736 (0xAE9122910E0D1B9C8C88BB7685912598)
Complete name                    : E:\Film\Rise of the Planet of the Apes (2011)\Rise of the Planet of the Apes.mkv
Format                           : Matroska
Format version                   : Version 1
File size                        : 10.9 GiB
Duration                         : 1h 44mn
Overall bit rate                 : 14.8 Mbps
Encoded date                     : UTC 2011-11-07 12:47:46
Writing application              : mkvmerge v2.3.0 ('Freak U') built on Sep  8 2008 18:32:16
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 44mn
Bit rate                         : 12.9 Mbps
Width                            : 1 920 pixels
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.343
Stream size                      : 9.22 GiB (85%)
Title                            : Rise.of.the.Planet.of.the.Apes.2011
Writing library                  : x264 core 116 r2074 2641b9e
Encoding settings                : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=12877 / ratetol=1.0 / qcomp=0.70 / qpmin=1 / qpmax=63 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=45000 / vbv_bufsize=40000 / nal_hrd=none / ip_ratio=1.40 / aq=2:0.90
Language                         : English
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 44mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 1.11 GiB (10%)
Title                            : DTS-CORE 1536K
Language                         : English
Audio #2
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 44mn
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Stream size                      : 336 MiB (3%)
Language                         : English
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : Dutch
FFMPEG INFO
ffmpeg version N-34549-g13b7781, Copyright (c) 2000-2011 the FFmpeg developers
  built on Nov  6 2011 22:08:46 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
  libavutil    51. 24. 0 / 51. 24. 0
  libavcodec   53. 28. 0 / 53. 28. 0
  libavformat  53. 19. 0 / 53. 19. 0
  libavfilter   2. 47. 0 /  2. 47. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'E:\Film\Rise of the Planet of the Apes (2011)\Ris
e of the Planet of the Apes.mkv':
  Duration: 01:44:56.48, start: 0.000000, bitrate: 14834 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : Rise.of.the.Planet.of.the.Apes.2011
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
      title           : DTS-CORE 1536K
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s
    Stream #0:3(dut): Subtitle: text (default)
MEDIA INFO
Unique ID                        : 238486632632226444311860216397717628932 (0xB36ADACE6C01F2F5A91101FEE9E8E804)
Complete name                    : E:\Film\Crazy, Stupid, Love (2011)\Crazy, Stupid, Love.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 10.3 GiB
Duration                         : 1h 58mn
Overall bit rate                 : 12.5 Mbps
Encoded date                     : UTC 2011-10-18 22:01:51
Writing application              : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Duration                         : 1h 58mn
Bit rate                         : 11.0 Mbps
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Bits/(Pixel*Frame)               : 0.299
Stream size                      : 8.86 GiB (86%)
Writing library                  : x264 core 116 r2057 0ba8a9c
Encoding settings                : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=11000 / ratetol=1.0 / qcomp=0.65 / qpmin=0 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.25 / pb_ratio=1.25 / aq=1:0.65
Language                         : English
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 58mn
Bit depth                        : 24 bits
Stream size                      : 1.25 GiB (12%)
Language                         : English
Text #1
Format                           : UTF-8
Language                         : English
Text #2
Format                           : UTF-8
Language                         : Portuguese
Menu
00:00:00.000                     : en:00:00:00.000
00:08:25.714                     : en:00:08:25.714
00:20:56.422                     : en:00:20:56.422
00:28:40.552                     : en:00:28:40.552
00:38:32.560                     : en:00:38:32.560
00:51:33.674                     : en:00:51:33.674
01:02:41.007                     : en:01:02:41.007
01:11:00.548                     : en:01:11:00.548
01:21:12.117                     : en:01:21:12.117
01:28:07.199                     : en:01:28:07.199
01:40:51.963                     : en:01:40:51.963
01:48:00.808                     : en:01:48:00.808
01:52:20.525                     : en:01:52:20.525
FFMPEG INFO
Input #0, matroska,webm, from 'E:\Film\Crazy, Stupid, Love (2011)\Crazy, Stupid,
 Love.mkv':
  Duration: 01:58:07.08, start: 0.000000, bitrate: 12502 kb/s
    Chapter #0.0: start 0.000000, end 505.714000
      title           : 00:00:00.000
    Chapter #0.1: start 505.714000, end 1256.422000
      title           : 00:08:25.714
    Chapter #0.2: start 1256.422000, end 1720.552000
      title           : 00:20:56.422
    Chapter #0.3: start 1720.552000, end 2312.560000
      title           : 00:28:40.552
    Chapter #0.4: start 2312.560000, end 3093.674000
      title           : 00:38:32.560
    Chapter #0.5: start 3093.674000, end 3761.007000
      title           : 00:51:33.674
    Chapter #0.6: start 3761.007000, end 4260.548000
      title           : 01:02:41.007
    Chapter #0.7: start 4260.548000, end 4872.117000
      title           : 01:11:00.548
    Chapter #0.8: start 4872.117000, end 5287.199000
      title           : 01:21:12.117
    Chapter #0.9: start 5287.199000, end 6051.963000
      title           : 01:28:07.199
    Chapter #0.10: start 6051.963000, end 6480.808000
      title           : 01:40:51.963
    Chapter #0.11: start 6480.808000, end 6740.525000
      title           : 01:48:00.808
    Chapter #0.12: start 6740.525000, end 7087.083000
      title           : 01:52:20.525
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5],
ault)
    Stream #0:2(eng): Subtitle: text
    Stream #0:3(por): Subtitle: text
MEDIA INFO
Unique ID                        : 243820242397309851571003035850653941500 (0xB76E12120F5A73B0BF4BAD8016BDBEFC)
Complete name                    : D:\Serier\Fringe\Season 02\Fringe S02E01 A New Day in the Old Town.mkv
Format                           : Matroska
File size                        : 2.21 GiB
Duration                         : 43mn 57s
Overall bit rate                 : 7 183 Kbps
Encoded date                     : UTC 2010-10-10 20:00:31
Writing application              : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Attachment                       : Yes
Format settings, ReFrames        : 9 frames
Duration                         : 43mn 57s
Bit rate                         : 6 400 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.290
Stream size                      : 1.97 GiB (89%)
Title                            : H.264 720p BluRay
Writing library                  : x264 core 105 r1724 b02df7b
Encoding settings                : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-4 / threads=12 / sliced_threads=0 / nr=10 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf_max=0.0 / ip_ratio=1.10 / aq=1:1.00 / nal_hrd=none
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 43mn 57s
Bit rate                         : 640 Kbps
Bit depth                        : 16 bits
Stream size                      : 201 MiB (9%)
Title                            : Dolby Digital 5.1
Language                         : English
Text #1
Format                           : ASS
Codec ID                         : S_TEXT/ASS
Codec ID/Info                    : Advanced Sub Station Alpha
Compression mode                 : Lossless
Title                            : Styled
Language                         : English
Text #2
Format                           : UTF-8
Title                            : Unstyled
Language                         : English
Menu
00:05:49.975                     : en:00:05:49.975
00:14:02.467                     : en:00:14:02.467
00:21:39.924                     : en:00:21:39.924
00:29:34.606                     : en:00:29:34.606
00:37:40.884                     : en:00:37:40.884
00:43:17.804                     : en:00:43:17.804
MEDIA INFO
Unique ID                        : 182015705405445754134425455464752192391 (0x88EEF32216DC0CA4B3F8AECD2AE59B87)
Complete name                    : D:\Serier\Fringe\Season 02\Fringe S02E02 Night of Desirable Objects.mkv
Format                           : Matroska
File size                        : 1.84 GiB
Duration                         : 43mn 58s
Overall bit rate                 : 5 984 Kbps
Encoded date                     : UTC 2010-10-10 20:00:06
Attachment                       : Yes
Duration                         : 43mn 58s
Bit rate                         : 5 225 Kbps
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.236
Stream size                      : 1.61 GiB (87%)
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 43mn 58s
Bit rate                         : 640 Kbps
Bit depth                        : 16 bits
Stream size                      : 201 MiB (11%)
Language                         : English
Text #1
Format                           : ASS
Title                            : Styled
Language                         : English
Text #2
Format                           : UTF-8
Title                            : Unstyled
Language                         : English
Menu
00:02:30.525                     : en:00:02:30.525
00:05:03.303                     : en:00:05:03.303
00:13:28.224                     : en:00:13:28.224
00:19:48.396                     : en:00:19:48.396
00:27:25.477                     : en:00:27:25.477
00:32:28.155                     : en:00:32:28.155
00:43:19.013                     : en:00:43:19.013
So anyone with any pointers for me? Would rly help alot, everything else working like a charm
Im using the latest Serviio (0.6.0.1) and Playstation 3 with FW 3,72 (or .73?) :p (using the standard unmodified ps3 profile for Serviio)
joelkaberg
Post Thu Nov 10, 2011 3:30 pm
Re: Playstation 3 "The data type is not supported"
I've tried editing the profile.xml but it went from semi working (some files playing) to none :p Could someone please help me out?
Post Thu Nov 10, 2011 3:51 pm
mkv with "Muxing mode : Header stripping" are not supported by PS3 in native format
Look at this: viewtopic.php?f=6&t=1132
You could try to remux in a new mkv file using mkvmerge tool, or into m2ts with Tsmuxer. But if its a video codec or audio codec problem, you have to reencode files.
joelkaberg
Post Thu Nov 10, 2011 4:07 pm
Illico wrote:mkv with "Muxing mode : Header stripping" are not supported by PS3 in native format
It seems that "header stripping" is the problem then? I viewd a few movies with Mediainfo and found that working movies also has the header stripping, eg
Unique ID                        : 175237708752547147254985845812592835290 (0x83D58E18E2E102298BE00F1D84FEFADA)
Complete name                    : E:\Film\Captain America The First Avenger (2011)\Captain America The First Avenger.mkv
Format                           : Matroska
File size                        : 5.46 GiB
Duration                         : 2h 4mn
Overall bit rate                 : 6 294 Kbps
Encoded date                     : UTC 2011-10-14 11:11:07
Duration                         : 2h 4mn
Bit rate                         : 4 787 Kbps
Height                           : 544 pixels
Bits/(Pixel*Frame)               : 0.287
Stream size                      : 4.04 GiB (74%)
Writing library                  : x264 core 118 r2085 8a62835
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4787 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 4mn
Bit depth                        : 24 bits
Stream size                      : 1.31 GiB (24%)
Language                         : English
But could i "transcode away" the issue somehow? My movie collection is about 6 TB big, lots of movies, most of them HD content.. To find and fix all the none working films would take alot of time (they work just fine on XBMC/WMP etc)
Post Thu Nov 10, 2011 4:30 pm
joelkaberg wrote:(they work just fine on XBMC/WMP etc)
VLC, XBMC or WMP are more permissive because there are based on software codec...PS3 is probably base to a chip so more "static".
Solution could be to force mpeg2 video encoding with better PS3 support.
joelkaberg
Post Thu Nov 10, 2011 4:48 pm
How would you edit it for best compability then? Encoding shouldnt be a problem for me (i7 2600k processor, 8b ram, 460 gtx X 2 sli etc)
My current profile is as follows (just the playstation part)
<Profile id="4" name="Playstation 3" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2">
            <Matches container="mp4" />
            <Matches container="asf" />
            <Matches container="avi" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <Matches container="3gp" />
      <OnlineTranscoding>
         </Audio>
      </OnlineTranscoding>
Im assuming I should use the "forceVTranscoding" tag? But where? Abit of a noob to this hehe
Post Thu Nov 10, 2011 5:04 pm
joelkaberg wrote:How would you edit it for best compability then?
I would suggest to stream into MPEGTS with MPEG2video (forced) and AC3-320kbps audio forced also like this.
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" forceVTranscoding="true" targetACodec="ac3" aBitrate="320">
      <OnlineTranscoding>
         </Audio>
But targetContainer="mpeg" should be fine too.
joelkaberg
Post Sat Nov 19, 2011 4:49 pm
Okay so I've ran with that profile for a few days and it works with most videos, but some heavier movies like Avatar stutter the audio in a few scenes where the network load goes rocking. Now with that in mind I tried to limit the vbitrate to 25mb/sec but with no change (tried to set the abitrate to 192bit with no change), anything im overseeing? My profile is as follows for PS3,
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="25840" forceVTranscoding="true" targetACodec="ac3" aBitrate="192">
      <OnlineTranscoding>
         </Audio>
MovieInfo for Avatar
Unique ID                        : 199703501839617131298234867644764791663 (0x963D7ED3CAC73013986275ED4EB8236F)
Complete name                    : F:\Film\Avatar (2009)\Avatar.mkv
Format                           : Matroska
File size                        : 15.0 GiB
Duration                         : 2h 41mn
Overall bit rate mode            : Variable
Overall bit rate                 : 13.3 Mbps
Encoded date                     : UTC 2010-04-24 16:57:03
Writing application              : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library                  : libebml v0.7.9 + libmatroska v0.8.1
Format settings, ReFrames        : 3 frames
Duration                         : 2h 41mn
Bit rate mode                    : Variable
Bit rate                         : 11.4 Mbps
Nominal bit rate                 : 9 111 Kbps
Maximum bit rate                 : 40.0 Mbps
Height                           : 1 072 pixels
Bits/(Pixel*Frame)               : 0.232
Stream size                      : 12.9 GiB (86%)
Title                            : Avatar
Writing library                  : x264 core 80 r1376M 3feaec2
Encoding settings                : cabac=1 / ref=4 / deblock=1:-1:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=24 / keyint_min=2 / scenecut=40 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=9111 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00
Format                           : DTS
Format profile                   : MA / Core
Codec ID                         : A_DTS
Duration                         : 2h 41mn
Bit rate                         : 1 561 Kbps / 1 510 Kbps
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Delay relative to video          : 2ms
Text
Format                           : UTF-8
Oh and I got a few movies where there are several audio languages, but Serviio seems to pick of the first one in the file, which dosnt work for me, anyway to set this to for ex. always english?
Post Sat Nov 19, 2011 8:41 pm
joelkaberg wrote:Now with that in mind I tried to limit the vbitrate to 25mb/sec but with no change (tried to set the abitrate to 192bit with no change),
Suggest to set maxVBitrate="17000"
joelkaberg wrote:Oh and I got a few movies where there are several audio languages, but Serviio seems to pick of the first one in the file, which dosnt work for me, anyway to set this to for ex. always english?
Yes, you're right, this feature is already requested.
