Sony BDP-S370 flv H.264 support on Buffalo LS-WXL
regli
Post Thu Nov 10, 2011 2:24 am
I just finally got Serviio 6.0.1 to nicely work on a Buffalo LS-WXL device. However, I have many Flash flv files that I like to play. With the present profile, these files are transcoded and the WXL with its 600 Mhz CPU is severely overtaxed and only processes 10 fps leading to stop and go viewing. FFmpeg reports them as :
aacaot : 2
audiochannels : 2
audiocodecid : mp4a
audiosamplerate : 32000
avclevel : 30
avcprofile : 77
duration : 880
height : 240
moovPosition : 32
videocodecid : avc1
videoframerate : 25
width : 432
However, I discovered that running:
ffmpeg -vcodec copy -acodec copy -i test.flv out.mp4
simply remuxes the stream and the player is able to play "out.mp4" perfectly. This seems to imply that a few fixes in the profile should fix this issue permanently. However, I checked out the profiles.xml and am not quite clear how to enable that.
Any help would be greatly appreciated.
Post Thu Nov 10, 2011 7:59 am
Re: Sony BDP-S370 flv H.264 support on Buffalo LS-WXL
For the moment, Serviio doesn't support transcoding to mp4 in the fly.
But you could transcode locally with your command and add the result into serviio library.
Could you provide "ffmpeg -i" result of this file?
Post Thu Nov 10, 2011 10:08 am
I assume remuxing to mpeg2ts should work as well (h264 flv videos only).
regli
Post Thu Nov 10, 2011 8:19 pm
Illico wrote:For the moment, Serviio doesn't support transcoding to mp4 in the fly.
Here are the complete results:
root@NASLS2:/mnt/disk1/tmp# ffmpeg -i test.flv
ffmpeg version 0.8.git, Copyright (c) 2000-2011 the FFmpeg developers
built on Nov 8 2011 21:21:41 with gcc 4.2.3
configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags='-L/opt/lib:/lib' --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[flv @ 0xcd6440] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'test.flv':
aacaot : 2
audiochannels : 2
audiocodecid : mp4a
avclevel : 30
avcprofile : 77
duration : 880
height : 240
moovPosition : 32
videocodecid : avc1
videoframerate : 25
width : 432
Duration: 00:14:39.92, start: 0.000000, bitrate: N/A
Stream #0.0: Video: h264 (Main), yuv420p, 432x240 [PAR 1:1 DAR 9:5], 25 tbr, 1k tbn, 50 tbc
Stream #0.1: Audio: aac, 32000 Hz, stereo, s16
FFmpeg is compiled from the source at the Serviio site.
I'll play around with profile.xml. I assume that all I'd need to do is add a correct MediaFormatProfile to implement zip's suggestion.
Thanks for your help!
regli
Post Thu Nov 10, 2011 8:56 pm
Should this do it in the transcoding section?
         <!-- allow flv/H.264 files to be remuxed -->
regli
Post Fri Nov 11, 2011 6:03 am
This works quite well now. Thanks for the help.
However, on a 4:3 TV it cuts off the sides instead of formatting it into 16:9 with black bars.
Any option to force that?
Post Fri Nov 11, 2011 10:51 am
that is a known problem and will be fixed at some point
regli
Post Fri Nov 11, 2011 4:24 pm
Thanks again and kudos for a great system.
BTW should that section of code be added to the general Sony BD profile? There are still a lot of YouTube capture programs out there and horsepower starved processors on many NAS boxes can this way still handle them handily.
