External Subtitles and transcoded media
thiagoguedes
Post Tue Nov 15, 2011 2:45 am
Hi There,
Got a new Panasonic TC-L32U30B. Everything is working well but there is just one thing that bugs me.
Some MKV's play directly, with everything ok: Multiple audio channels, Subtitles etc. And some, just don't. I'll provide media info for both.
This one is ok:
Unique ID                        : 203957376096882162055348872805192452802 (0x9970C305593F3B4899F2B17353064AC2)
Complete name                    : E:\Movies\Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP\Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 5.00 GiB
Duration                         : 1h 57mn
Overall bit rate mode            : Variable
Overall bit rate                 : 6 088 Kbps
Movie name                       : Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP
Encoded date                     : UTC 2011-09-30 09:19:01
Writing application              : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                  : libebml v1.2.1 + libmatroska v1.1.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 57mn
Bit rate mode                    : Variable
Bit rate                         : 5 000 Kbps
Maximum bit rate                 : 25.0 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.226
Stream size                      : 4.01 GiB (80%)
Title                            : Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP
Writing library                  : x264 core 114 r1924 08d04a4
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Default                          : Yes
Forced                           : Yes
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 57mn
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 377 MiB (7%)
Title                            : AC3 5.1
Language                         : Portuguese
Default                          : Yes
Forced                           : Yes
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 57mn
Bit rate                         : 640 Kbps
Bit depth                        : 16 bits
Stream size                      : 538 MiB (11%)
Title                            : AC3 5.1
Language                         : English
Default                          : No
Forced                           : No
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Title                            : Legenda
Language                         : English
Default                          : No
Forced                           : No
This one, doesn't:
Unique ID                        : 93684503294867150833126418153523980009 (0x467AFAA1309E596C9BCA3EAE9F1926E9)
Complete name                    : E:\Movies\Quintologia X-Men 720p DualAudio\X-Men - Primeira Classe 720p DualAudio\X-Men - Primeira Classe 720p DualAudio.mkv
Format                           : Matroska
File size                        : 5.97 GiB
Duration                         : 2h 11mn
Overall bit rate                 : 6 489 Kbps
Movie name                       : BY ZMG
Encoded date                     : UTC 2011-08-25 16:14:04
Writing application              : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 22:46:04
Format settings, ReFrames        : 12 frames
Duration                         : 2h 11mn
Bit rate                         : 5 592 Kbps
Height                           : 544 pixels
Display aspect ratio             : 2.35:1
Bits/(Pixel*Frame)               : 0.335
Stream size                      : 5.03 GiB (84%)
Writing library                  : x264 core 116 r2057 0ba8a9c
Encoding settings                : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=1 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5592 / ratetol=1.0 / qcomp=0.70 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=2:1.00
Language                         : English
Default                          : Yes
Forced                           : Yes
Audio #1
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 11mn
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Stream size                      : 422 MiB (7%)
Default                          : Yes
Forced                           : Yes
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 11mn
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Language                         : English
Default                          : No
Forced                           : No
Any idea why?
But ok, after a lot of tries, I went to plan B. Created a profile to transcode this media so it can be played. It goes like:
   <Profile id="12" name="Pana Viera MKV Pure" extendsProfileId="1">
      <MediaFormatProfiles>
      </MediaFormatProfiles>
          <!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
            <Matches container="matroska" vCodec="h264" aCodec="dca" />
            <Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
         <!-- Remux all h264 video to MPEG-TS stream -->
            <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Audio targetContainer="mp3">
            <Matches container="mp4" />
            <Matches container="flac" />
         </Audio>
But thing is, transcoded media plays fine but doesn't load external Subtitles! I've placed the .srt file in the same dir. If fact, I confirmed they are recognized in the logs, but it seems the "get" operation is not done. Other media plays absolutely normal.
[b]2011-11-14 23:29:18,399 DEBUG [SubtitlesService] Found subtitle file: E:\Movies\Quintologia X-Men 720p DualAudio\X-Men - Primeira Classe 720p DualAudio\X-Men - Primeira Classe 720p DualAudio.srt[/b]
2011-11-14 23:29:18,401 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:29:18,419 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 14 and profile Pana Viera MKV pra Mpeg2
2011-11-14 23:29:18,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:29:18,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:29:18,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:29:18,424 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2011-11-14 23:29:18,446 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:29:18,447 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2011-11-14 23:29:18,448 DEBUG [SubtitlesService] Found subtitle file: E:\Movies\Quintologia X-Men 720p DualAudio\X-Men - Primeira Classe 720p DualAudio\X-Men - Primeira Classe 720p DualAudio.srt
2011-11-14 23:29:18,456 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 11
2011-11-14 23:29:18,479 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-14 23:29:18,512 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-14 23:29:18,634 DEBUG [WebServer] Incoming connection from /192.168.1.100:18447
2011-11-14 23:29:18,635 DEBUG [ResourceTransportRequestHandler] GET /resource/14/MEDIA_ITEM/MPEG_TS_SD_EU_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.101:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-11-14 23:29:18,635 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:29:18,636 DEBUG [WebServer] Incoming connection from /192.168.1.100:45673
2011-11-14 23:29:18,637 DEBUG [ResourceTransportRequestHandler] GET /resource/14/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,transferMode.dlna.org: Interactive]]
2011-11-14 23:29:18,638 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:29:18,638 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,639 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,641 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'COVER_IMAGE' received
2011-11-14 23:29:18,644 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'MEDIA_ITEM' received
2011-11-14 23:29:18,645 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 14 (local)
2011-11-14 23:29:18,645 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:29:18,646 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:29:18,647 DEBUG [VideoDeliveryEngine] Delivering item '14' for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,647 DEBUG [VideoDeliveryEngine] Delivering file 'X-Men - Primeira Classe 720p DualAudio.mkv' using transcoding
2011-11-14 23:29:18,648 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,648 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2011-11-14 23:29:18,650 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Movies\Quintologia X-Men 720p DualAudio\X-Men - Primeira Classe 720p DualAudio\X-Men - Primeira Classe 720p DualAudio.mkv
2011-11-14 23:29:18,643 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2011-11-14 23:29:18,655 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 14
2011-11-14 23:29:18,657 DEBUG [ProcessExecutor] Starting E:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Movies\Quintologia X-Men 720p DualAudio\X-Men - Primeira Classe 720p DualAudio\X-Men - Primeira Classe 720p DualAudio.mkv -y -threads 2 -vcodec mpeg2video -sameq -r 24000/1001 -g 15 -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts E:\tmp\Serviio\transcoding-temp-14-MPEG2TS.stf
2011-11-14 23:29:18,657 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5887
2011-11-14 23:29:18,658 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:29:18,658 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5887,Date: Tue, 15 Nov 2011 01:29:18 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-11-14 23:29:18,948 DEBUG [WebServer] Incoming connection from /192.168.1.100:31155
2011-11-14 23:29:18,949 DEBUG [ResourceTransportRequestHandler] GET /resource/14/MEDIA_ITEM/MPEG_TS_SD_EU_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.101:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-11-14 23:29:18,949 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:29:18,953 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,953 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'MEDIA_ITEM' received
2011-11-14 23:29:18,954 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 14 (local)
2011-11-14 23:29:18,954 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:29:18,956 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:29:18,957 DEBUG [VideoDeliveryEngine] Delivering item '14' for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:18,957 DEBUG [VideoDeliveryEngine] Delivering file 'X-Men - Primeira Classe 720p DualAudio.mkv' using transcoding
2011-11-14 23:29:19,151 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:19,152 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:29:19,152 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:29:19,152 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:29:19,152 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-11-14 23:29:19,152 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 14) as read
2011-11-14 23:29:19,176 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:29:19,177 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:29:19,177 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:29:19,177 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-11-14 23:29:19,177 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 14) as read
2011-11-14 23:29:19,180 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-14 23:29:19,181 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-11-14 23:29:19,181 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-11-14 23:29:19,181 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:29:19,181 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-7902.0/7902,Date: Tue, 15 Nov 2011 01:29:19 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-11-14 23:29:19,236 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-14 23:29:19,237 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-11-14 23:29:19,237 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-11-14 23:29:19,237 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:29:19,237 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-7902.0/7902,Date: Tue, 15 Nov 2011 01:29:19 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-11-14 23:29:19,240 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-14 23:29:19,405 DEBUG [WebServer] Incoming connection from /192.168.1.100:12289
2011-11-14 23:29:19,407 DEBUG [ResourceTransportRequestHandler] GET /resource/14/MEDIA_ITEM/MPEG_TS_SD_EU_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.101:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-11-14 23:29:19,409 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:29:19,410 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:19,410 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'MEDIA_ITEM' received
2011-11-14 23:29:19,410 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 14 (local)
2011-11-14 23:29:19,411 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:29:19,412 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:29:19,413 DEBUG [VideoDeliveryEngine] Delivering item '14' for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:19,413 DEBUG [VideoDeliveryEngine] Delivering file 'X-Men - Primeira Classe 720p DualAudio.mkv' using transcoding
2011-11-14 23:29:19,413 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:29:19,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:29:19,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:29:19,413 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:29:19,413 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-11-14 23:29:19,414 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 14) as read
2011-11-14 23:29:19,416 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-14 23:29:19,417 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-11-14 23:29:19,417 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-11-14 23:29:19,417 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:29:19,417 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-7902.0/7902,Date: Tue, 15 Nov 2011 01:29:19 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-11-14 23:29:20,277 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-11-14 23:29:37,922 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-14 23:30:16,325 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.101, timeout = 0
2011-11-14 23:30:16,325 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 29e0c7b2-e2bf-3f96-91e2-08c360085651
2011-11-14 23:30:17,053 DEBUG [WebServer] Incoming connection from /192.168.1.100:27690
2011-11-14 23:30:17,054 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 29e0c7b2-e2bf-3f96-91e2-08c360085651 from 192.168.1.100 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-11-14 23:30:17,054 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:17,054 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
2011-11-14 23:30:17,055 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:17,057 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:18,126 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:11
2011-11-14 23:30:37,924 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-14 23:30:48,986 DEBUG [WebServer] Incoming connection from /192.168.1.100:37238
2011-11-14 23:30:48,987 DEBUG [ResourceTransportRequestHandler] GET /resource/14/MEDIA_ITEM/MPEG_TS_SD_EU_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.101:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-11-14 23:30:48,991 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:48,991 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:48,992 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'MEDIA_ITEM' received
2011-11-14 23:30:48,992 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 14 (local)
2011-11-14 23:30:48,992 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:30:48,993 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:30:48,995 DEBUG [VideoDeliveryEngine] Delivering item '14' for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:48,995 DEBUG [VideoDeliveryEngine] Delivering file 'X-Men - Primeira Classe 720p DualAudio.mkv' using transcoding
2011-11-14 23:30:48,995 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:48,995 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:30:48,995 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:30:48,995 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:30:48,995 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-11-14 23:30:48,995 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 14) as read
2011-11-14 23:30:48,999 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-14 23:30:48,999 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-11-14 23:30:48,999 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-11-14 23:30:48,999 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:30:48,999 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-7902.0/7902,Date: Tue, 15 Nov 2011 01:30:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-11-14 23:30:49,041 DEBUG [WebServer] Incoming connection from /192.168.1.100:40064
2011-11-14 23:30:49,047 DEBUG [ResourceTransportRequestHandler] GET /resource/14/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,transferMode.dlna.org: Interactive]]
2011-11-14 23:30:49,047 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:49,048 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:49,048 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'COVER_IMAGE' received
2011-11-14 23:30:49,048 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2011-11-14 23:30:49,049 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 14
2011-11-14 23:30:49,049 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5887
2011-11-14 23:30:49,049 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:30:49,049 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5887,Date: Tue, 15 Nov 2011 01:30:49 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2011-11-14 23:30:49,418 DEBUG [WebServer] Incoming connection from /192.168.1.100:38877
2011-11-14 23:30:49,418 DEBUG [ResourceTransportRequestHandler] GET /resource/14/MEDIA_ITEM/MPEG_TS_SD_EU_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.101:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-11-14 23:30:49,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:49,419 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:49,420 DEBUG [ResourceTransportRequestHandler] Request for resource 14 and type 'MEDIA_ITEM' received
2011-11-14 23:30:49,420 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 14 (local)
2011-11-14 23:30:49,420 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 14)
2011-11-14 23:30:49,421 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2011-11-14 23:30:49,421 DEBUG [VideoDeliveryEngine] Delivering item '14' for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:49,422 DEBUG [VideoDeliveryEngine] Delivering file 'X-Men - Primeira Classe 720p DualAudio.mkv' using transcoding
2011-11-14 23:30:49,422 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.100, Profile=Pana Viera MKV pra Mpeg2 '
2011-11-14 23:30:49,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_EU_ISO
2011-11-14 23:30:49,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_NA_ISO
2011-11-14 23:30:49,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file X-Men - Primeira Classe 720p DualAudio.mkv: MPEG_TS_SD_KO_ISO
2011-11-14 23:30:49,422 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-11-14 23:30:49,422 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 14) as read
2011-11-14 23:30:49,453 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-14 23:30:49,453 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2011-11-14 23:30:49,453 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-11-14 23:30:49,454 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-14 23:30:49,454 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-7902.0/7902,Date: Tue, 15 Nov 2011 01:30:49 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-11-14 23:30:49,578 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-14 23:30:50,596 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-14 23:30:51,396 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-14 23:30:54,051 DEBUG [WebServer] Incoming connection from /192.168.1.100:59393
2011-11-14 23:30:54,052 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.100:
2011-11-14 23:30:54,052 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:30:54,058 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 22) with parameters: objectID = V_F#FOL_R2, browseFlag = BrowseDirectChildren, filter = dc:title,dc:date,res,res@protocolInfo,res@size,res@duration,res@resolution,res@dlna:ifoFileURI,res@pv:subtitleFileType,res@pv:subtitleFileUri,upnp:albumArtURI,upnp:album,upnp:artist, startIndex = 0, count = 20, sortCriteria =
2011-11-14 23:30:54,058 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2011-11-14 23:30:54,071 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null (from=0, count=20)
2011-11-14 23:30:54,084 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 12
2011-11-14 23:30:54,135 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15
2011-11-14 23:30:54,158 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 18
2011-11-14 23:30:54,182 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 27
2011-11-14 23:30:54,276 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 30
2011-11-14 23:30:54,303 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 88
2011-11-14 23:30:54,345 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 92
2011-11-14 23:30:54,370 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 108
2011-11-14 23:30:54,411 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-11-14 23:30:54,461 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-14 23:30:54,469 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-14 23:31:29,917 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.101, timeout = 0
2011-11-14 23:31:29,917 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 29e0c7b2-e2bf-3f96-91e2-08c360085651
2011-11-14 23:31:30,641 DEBUG [WebServer] Incoming connection from /192.168.1.100:56244
2011-11-14 23:31:30,641 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 29e0c7b2-e2bf-3f96-91e2-08c360085651 from 192.168.1.100 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-11-14 23:31:30,641 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:31:30,641 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
2011-11-14 23:31:30,641 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Pana Viera MKV pra Mpeg2 '
2011-11-14 23:31:31,725 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:24
2011-11-14 23:31:37,925 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-14 23:32:37,926 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-14 23:32:57,186 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.101, timeout = 0
2011-11-14 23:32:57,187 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 29e0c7b2-e2bf-3f96-91e2-08c360085651
2011-11-14 23:32:57,917 DEBUG [WebServer] Incoming connection from /192.168.1.100:58242
2011-11-14 23:32:57,917 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 29e0c7b2-e2bf-3f96-91e2-08c360085651 from 192.168.1.100 (headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50])
2011-11-14 23:32:57,917 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2011-11-14 23:32:57,917 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.101:8895,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50]
2011-11-14 23:32:57,917 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Pana Viera MKV pra Mpeg2 '
2011-11-14 23:32:58,987 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:00
2011-11-14 23:33:37,934 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-14 23:33:43,557 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-11-14 23:33:43,558 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies
2011-11-14 23:33:43,559 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP
2011-11-14 23:33:43,579 DEBUG [LibraryAdditionsCheckerThread] Found file 'Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP.mkv', checking if it's already in the Library
2011-11-14 23:33:43,579 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP.mkv
2011-11-14 23:33:43,580 DEBUG [MediaItemDAOImpl] Media item Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP.mkv already exists in DB
2011-11-14 23:33:43,581 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Blade.Runner.The.Final.Cut.1982.BDRip-720p.AC3 5.1.Dual.x264-PEDECANAJP\Legenda
2011-11-14 23:33:43,581 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Clube da Luta (Fight Club)Dual Audio
2011-11-14 23:33:43,602 DEBUG [LibraryAdditionsCheckerThread] Found file 'Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd1.divx', checking if it's already in the Library
2011-11-14 23:33:43,602 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd1.divx
2011-11-14 23:33:43,603 DEBUG [MediaItemDAOImpl] Media item Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd1.divx already exists in DB
2011-11-14 23:33:43,623 DEBUG [LibraryAdditionsCheckerThread] Found file 'Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd2.divx', checking if it's already in the Library
2011-11-14 23:33:43,623 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd2.divx
2011-11-14 23:33:43,624 DEBUG [MediaItemDAOImpl] Media item Filmes - Clube_da_Luta.Dvdrip.Container.DivX50.2Audios.EN.PT.1_SUB.PT.AC3(6CH).lore.cd2.divx already exists in DB
2011-11-14 23:33:43,625 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Harry potter e as reliaquias da morte 1,37 dual audio
2011-11-14 23:33:43,645 DEBUG [LibraryAdditionsCheckerThread] Found file 'Harry potter e as relliquias da morte by maioroberto22.avi', checking if it's already in the Library
2011-11-14 23:33:43,645 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Harry potter e as relliquias da morte by maioroberto22.avi
2011-11-14 23:33:43,646 DEBUG [MediaItemDAOImpl] Media item Harry potter e as relliquias da morte by maioroberto22.avi already exists in DB
2011-11-14 23:33:43,647 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Harry Potter e o enigma do príncipe
2011-11-14 23:33:43,667 DEBUG [LibraryAdditionsCheckerThread] Found file 'Harry Potter and the Half Blood Prince.avi', checking if it's already in the Library
2011-11-14 23:33:43,667 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Harry Potter and the Half Blood Prince.avi
2011-11-14 23:33:43,668 DEBUG [MediaItemDAOImpl] Media item Harry Potter and the Half Blood Prince.avi already exists in DB
2011-11-14 23:33:43,669 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG
2011-11-14 23:33:43,689 DEBUG [LibraryAdditionsCheckerThread] Found file 'Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG.mkv', checking if it's already in the Library
2011-11-14 23:33:43,689 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG.mkv
2011-11-14 23:33:43,691 DEBUG [MediaItemDAOImpl] Media item Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG.mkv already exists in DB
2011-11-14 23:33:43,691 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG\Legenda
2011-11-14 23:33:43,692 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Harry.Potter.e.as.Reliquias.da.Morte.Parte.2.2011.720p-CHD.DUAL-ZMG\Legenda Forcada
2011-11-14 23:33:43,692 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Lanterna Verde_santacruz
2011-11-14 23:33:43,712 DEBUG [LibraryAdditionsCheckerThread] Found file 'Lanterna.Verde.DVDRip_santacruz.avi', checking if it's already in the Library
2011-11-14 23:33:43,712 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Lanterna.Verde.DVDRip_santacruz.avi
2011-11-14 23:33:43,713 DEBUG [MediaItemDAOImpl] Media item Lanterna.Verde.DVDRip_santacruz.avi already exists in DB
2011-11-14 23:33:43,733 DEBUG [LibraryAdditionsCheckerThread] Found file 'santacruz [A Torcida Mais Apaixonada do Brasil] ;P.png', checking if it's already in the Library
2011-11-14 23:33:43,734 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item santacruz [A Torcida Mais Apaixonada do Brasil] ;P.png
2011-11-14 23:33:43,735 DEBUG [MediaItemDAOImpl] Media item santacruz [A Torcida Mais Apaixonada do Brasil] ;P.png already exists in DB
2011-11-14 23:33:43,736 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Movies\Padre (Priest) [2011] Terror (Dual) DVDRip DivX AC3 [R4nd0lph]
2011-11-14 23:33:43,756 DEBUG [LibraryAdditionsCheckerThread] Found file 'Padre.(Priest).2011.Terror.Dual.DVDRip.DivX.AC3-By.R4nd0lph.avi', checking if it's already in the Library
2011-11-14 23:33:43,756 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Padre.(Priest).2011.Terror.Dual.DVDRip.DivX.AC3-By.R4nd0lph.avi
2011-11-14 23:33:43,757 DEBUG [MediaItemDAOImpl] Media item Padre.(Priest).2011.Terror.Dual.DVDRip.DivX.AC3-t
Any lights?
Thanks,
Post Tue Nov 15, 2011 8:03 am
Re: External Subtitles and transcoded media
thiagoguedes wrote:This one, doesn't:
You could try to remux all track with another version of mkvmerge.
thiagoguedes wrote:... but it seems the "get" operation is not done.
Are you sure that your device support external srt files?
thiagoguedes
Post Tue Nov 15, 2011 11:17 am
Hi Illico,
Illico wrote:You could try to remux all track with another version of mkvmerge.
Done that already. I've even tried to extract the video from the old mkv container and build a new one. My only suspicion lies on the resolution, it's not a standard one.
Illico wrote:Are you sure that your device support external srt files?
[/quote]
Absolutely :) The external srt exist in both cases, but plays only on the first.
Thing is, there is some "hidden problem" on the second file. It doesn't play directly (despite being a mkv and using the first case we are sure the TV is compatible with them) and when transcoded, doesn't show subtitles.
Regards,
Post Tue Nov 15, 2011 12:55 pm
It's possible that the TV only supports srt for certain file types. In this case it's mpegts - the TV doesn't make any request for it. You might try to transcode the file manually to mpegts and add the file to the library and play it natively to see it subs appear.
thiagoguedes
Post Tue Nov 15, 2011 1:15 pm
Hi Zip,
Is there any other type to transcode into on the fly? I was trying to avoid a full conversion for time purposes. Should the need arise, I think I´ll stick with the PS3 for this type of .mkv only.
Anyway, if you have any idea why one of these .mkvs is not playing directly it would be really appreciated.
Thank you,
Post Tue Nov 15, 2011 1:22 pm
you can transcode into mpegps, like the DirecTV profile does
thiagoguedes
Post Tue Nov 15, 2011 3:16 pm
Hi Zip,
Just did that, but no luck.
I'm really curious about that .mkv. It doesn't seem so different from the other.
Regards,
Post Tue Nov 15, 2011 5:00 pm
It seems like High@4.1 AVC file, but still 12 ref frames is on the edge and it's possible the TV cannot play that.
Return to Panasonic
Users browsing this forum: Google [Bot] and 23 guests
