Sony 46ex523, playback controls
I can get the playback to work fine on the TV, but if I pause or fast forward or any of the controls , the playback stops and says it cannot find the file.. Any ideas?
Thanks,
Illico wrote:Could you provide information about the media ? "ffmpeg -i" or MediaInfo result (see signature links)
ffmpeg version 0.7.2-4:0.7.2-1ubuntu1, Copyright (c) 2000-2011 the Libav developers
built on Oct 2 2011 15:12:32 with gcc 4.6.1
configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
WARNING: library configuration mismatch
avutil configuration: --extra-version='4:0.7.2.1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdirac --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libvo-aacenc --enable-version3 --enable-libvo-amrwbenc --enable-version3 --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avcodec configuration: --extra-version='4:0.7.2.1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdirac --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libvo-aacenc --enable-version3 --enable-libvo-amrwbenc --enable-version3 --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avformat configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avdevice configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
avfilter configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
swscale configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
postproc configuration: --extra-version='4:0.7.2-1ubuntu1' --arch=i386 --prefix=/usr --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavutil 51. 7. 0 / 51. 7. 0
libavcodec 53. 5. 0 / 53. 5. 0
libavformat 53. 2. 0 / 53. 2. 0
libavdevice 53. 0. 0 / 53. 0. 0
libavfilter 2. 4. 0 / 2. 4. 0
libswscale 2. 0. 0 / 2. 0. 0
libpostproc 52. 0. 0 / 52. 0. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'The Pacific Ep 01.mp4':
major_brand : mp42
minor_version : 0
creation_time : 2010-05-01 18:22:41
encoder : HandBrake 0.9.4 2009112300
Duration: 00:54:44.69, start: 0.000000, bitrate: 1241 kb/s
Stream #0.0(und): Video: h264 (Main), yuv420p, 720x400 [PAR 713:720 DAR 713:400], 1077 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1(und): Audio: aac, 48000 Hz, stereo, s16, 159 kb/s
creation_time : 2010-05-01 18:22:412011-11-15 05:57:49,920 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:117)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2011-11-15 06:00:16,974 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:187)ffmpeg version git-2011-11-15-7ea3963, Copyright (c) 2000-2011 the FFmpeg developers
built on Nov 15 2011 04:09:50 with gcc 4.6.1
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx
libavutil 51. 25. 0 / 51. 25. 0
libavcodec 53. 34. 0 / 53. 34. 0
libavformat 53. 20. 0 / 53. 20. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 48. 1 / 2. 48. 1
libswscale 2. 1. 0 / 2. 1. 0
This release includes FFmpeg compiled using this source code.
Illico wrote:Try with this one:
http://www.serviio.org/downloadThis release includes FFmpeg compiled using this source code.
zip wrote:enable detailed logging to see what ffmpeg command is crashing, then try to run that command manually and post the error
zip wrote:the command is above this error message in the log
2011-11-16 07:30:46,960 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.142:51703
2011-11-16 07:30:46,961 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.142:51703
2011-11-16 07:30:54,733 DEBUG [WebServer] Incoming connection from /192.168.1.103:52137
2011-11-16 07:30:54,734 DEBUG [ResourceTransportRequestHandler] HEAD /resource/4/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO$0 HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX523";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX523"; mv="1.7";,Host: 192.168.1.118:8895]]
2011-11-16 07:30:54,734 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2011-11-16 07:30:54,734 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.103, Profile=Sony Bravia TV 2011'
2011-11-16 07:30:54,735 DEBUG [ResourceTransportRequestHandler] Request for resource 4 and type 'MEDIA_ITEM' received
2011-11-16 07:30:54,735 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4 (local)
2011-11-16 07:30:54,735 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2011-11-16 07:30:54,736 DEBUG [VideoDAOImpl] Reading a Video (id = 4)
2011-11-16 07:30:54,737 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4, format AVC_TS_MP_SD_AC3_ISO and profile Sony Bravia TV 2011
2011-11-16 07:30:54,737 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file The Pacific Ep 10.mp4
2011-11-16 07:30:54,737 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The Pacific Ep 10.mp4: AVC_TS_MP_SD_AC3_ISO
2011-11-16 07:30:54,737 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-11-16 07:30:54,737 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 16 Nov 2011 13:30:54 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-16 07:30:54,743 DEBUG [WebServer] Incoming connection from /192.168.1.103:52138
2011-11-16 07:30:54,743 DEBUG [ResourceTransportRequestHandler] GET /resource/4/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO$0 HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX523";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX523"; mv="1.7";,Host: 192.168.1.118:8895]]
2011-11-16 07:30:54,744 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2011-11-16 07:30:54,744 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.103, Profile=Sony Bravia TV 2011'
2011-11-16 07:30:54,745 DEBUG [ResourceTransportRequestHandler] Request for resource 4 and type 'MEDIA_ITEM' received
2011-11-16 07:30:54,745 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 4 (local)
2011-11-16 07:30:54,745 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2011-11-16 07:30:54,746 DEBUG [VideoDAOImpl] Reading a Video (id = 4)
2011-11-16 07:30:54,746 DEBUG [VideoDeliveryEngine] Delivering item '4' for client 'IPAddress=/192.168.1.103, Profile=Sony Bravia TV 2011'
2011-11-16 07:30:54,746 DEBUG [VideoDeliveryEngine] Delivering file 'The Pacific Ep 10.mp4' using transcoding
2011-11-16 07:30:54,747 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.103, Profile=Sony Bravia TV 2011'
2011-11-16 07:30:54,747 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2011-11-16 07:30:57,257 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
zip wrote:even further up
Illico wrote:Suggest:
- Enable detailed logging (see signature)
- Stop serviio services
- Clean the log file (removed or edit then clean)
- Start serviio services
- Browse then Start movie
- Edit log file and look at ffmpeg command line
