"no titles" for online feed
susieorisa
Post Sat Nov 19, 2011 5:20 pm
I've just started using serviio, and I can see all of my personal content (photos, video, audio) but I cannot see any videos from online feeds. I've read all the other forum posts and support pages, downloaded groovy, updated java, and made sure that the ffmpeg file is updated. I still get this log entry:
2011-11-19 12:11:55,421 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtsp://v8.cache2.c.youtube.com/CiQLENy7 ... /video.3gp. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
... 1 more
Honestly, I don't quite understand yet how to create the links to the online feeds. But I copied two youtube and hulu links from the online forum into the consule library. For example, http://gdata.youtube.com/feeds/api/stan ... /top_rated.
I'm streaming to a Ps3 that is connected to my Panasonic Viera.
Any guidance would be appreciated. It doesn't look like anyone else has this problem.
Thank you,
Susan
Post Sat Nov 19, 2011 7:41 pm
Re: "no titles" for online feed
Well that feed did not come from top rated so without further info it is impossible to diagnose what broke between your rss and the playback of the selected video. Did you try different quality settings. Looks to me like you have low quality selected.
Post Sun Nov 20, 2011 11:40 am
I think it's related to this ticket: https://bitbucket.org/xnejp03/serviio/i ... 263-videos
You could try changing video quality for the feeds in the console so that it picks a different (supported) file type for now.
susieorisa
Post Mon Nov 21, 2011 1:01 am
Thanks so much for responding so quickly. I read the log more closely, and it looks like some of the plug-ins aren't running correctly. Here is part of the log:
2011-11-20 19:50:24,734 WARN [PluginCompilerThread] Unexpected error during adding plugin GameTrailers.groovy: null
at org.serviio.library.online.OnlineLibraryManager.removeFeedFromCache(OnlineLibraryManager.java:194)
at org.serviio.library.online.feed.PluginCompilerThread.compilePluginFile(PluginCompilerThread.java:156)
at org.serviio.library.online.feed.PluginCompilerThread.searchForPlugins(PluginCompilerThread.java:144)
at org.serviio.library.online.feed.PluginCompilerThread.run(PluginCompilerThread.java:86)
2011-11-20 19:50:26,531 WARN [PluginCompilerThread] Unexpected error during adding plugin Hulu.groovy: null
Youtube isn't one of the plugins where there is an unexpected error. I'm still getting this error, and the only online feed in the library is the top rated feed as listed above:
2011-11-20 19:50:39,062 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtsp://v4.cache3.c.youtube.com/CiQLENy7 ... /video.3gp. It might not play.
... 1 more
2011-11-20 19:59:18,015 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtsp://v4.cache3.c.youtube.com/CiQLENy7 ... /video.3gp. It might not play.
... 1 more
Any thoughts?
Susan
Post Mon Nov 21, 2011 11:45 am
that's what I said, if it starts with rtsp:// then it will be fixed in the related ticket. Didn't changing the quality help?
Users browsing this forum: Baidu [Spider], Google [Bot] and 14 guests
