Moving files from TV
macka601
Post Mon Nov 21, 2011 12:19 pm
Hi there,
Absolute newbie here... to everything. So i got my serviio installed on my linux mint box, and i can successfully browse the library with my D6600 TV.
However, i was wondering, the TV Has the ability to record TV, can i get the files off the TV? other than literally unpluggin the hard drive?
Grant
Post Mon Nov 21, 2011 2:11 pm
Re: Moving files from TV
No, not with DLNA.
Post Mon Nov 21, 2011 9:07 pm
yes you can samsung has a DMR function that allows you to access the file on your TV from your networked PC, look on your network page in windows and you should see your TV listed as a media device that you an access. :) (serviio has NO involvement in this as it is a samsung system)
